Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled
#include <car_detection_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
// Define the camera model
#define CAMERA_MODEL_XIAO_ESP32S3
#if defined(CAMERA_MODEL_XIAO_ESP32S3)
#define PWDN_GPIO_NUM     -1
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM     10
#define SIOD_GPIO_NUM     40
#define SIOC_GPIO_NUM     39
#define Y9_GPIO_NUM       48
#define Y8_GPIO_NUM       11
#define Y7_GPIO_NUM       12
#define Y6_GPIO_NUM       14
#define Y5_GPIO_NUM       16
#define Y4_GPIO_NUM       18
#define Y3_GPIO_NUM       17
#define Y2_GPIO_NUM       15
#define VSYNC_GPIO_NUM    38
#define HREF_GPIO_NUM     47
#define PCLK_GPIO_NUM     13
#else
#error "Camera model not selected"
#endif
/* Constant defines -------------------------------------------------------- */
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS           320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS           240
#define EI_CAMERA_FRAME_BYTE_SIZE                 3
/* Private variables ------------------------------------------------------- */
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
static bool is_initialised = false;
static uint8_t *snapshot_buf = nullptr; // points to the output of the capture
static camera_config_t camera_config = {
    .pin_pwdn = PWDN_GPIO_NUM,
    .pin_reset = RESET_GPIO_NUM,
    .pin_xclk = XCLK_GPIO_NUM,
    .pin_sscb_sda = SIOD_GPIO_NUM,
    .pin_sscb_scl = SIOC_GPIO_NUM,
    .pin_d7 = Y9_GPIO_NUM,
    .pin_d6 = Y8_GPIO_NUM,
    .pin_d5 = Y7_GPIO_NUM,
    .pin_d4 = Y6_GPIO_NUM,
    .pin_d3 = Y5_GPIO_NUM,
    .pin_d2 = Y4_GPIO_NUM,
    .pin_d1 = Y3_GPIO_NUM,
    .pin_d0 = Y2_GPIO_NUM,
    .pin_vsync = VSYNC_GPIO_NUM,
    .pin_href = HREF_GPIO_NUM,
    .pin_pclk = PCLK_GPIO_NUM,
    .xclk_freq_hz = 20000000,
    .ledc_timer = LEDC_TIMER_0,
    .ledc_channel = LEDC_CHANNEL_0,
    .pixel_format = PIXFORMAT_JPEG,
    .frame_size = FRAMESIZE_QVGA,
    .jpeg_quality = 12,
    .fb_count = 1,
    .fb_location = CAMERA_FB_IN_PSRAM,
    .grab_mode = CAMERA_GRAB_WHEN_EMPTY,
/* Function definitions ------------------------------------------------------- */
bool ei_camera_init(void);
void ei_camera_deinit(void);
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf);
static int ei_camera_get_data(size_t offset, size_t length, float *out_ptr);
* @brief      Arduino setup function
    while (!Serial);
    Serial.println("Edge Impulse Inferencing Demo");
    if (ei_camera_init() == false) {
        Serial.println("Failed to initialize Camera!");
        Serial.println("Camera initialized.");
    Serial.println("\nStarting continuous inference in 2 seconds...");
    delay(2000);
* @brief      Get data and run inferencing
* @param[in]  debug  Get debug info if true
    Serial.println("Entering loop");
    if (ei_sleep(5) != EI_IMPULSE_OK) {
        Serial.println("Sleep failed");
        return;
    Serial.println("Allocating buffer");
    snapshot_buf = (uint8_t*)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
    // check if allocation was successful
    if (snapshot_buf == nullptr) {
        Serial.println("ERR: Failed to allocate snapshot buffer!");
        return;
    ei::signal_t signal;
    signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT;
    signal.get_data = &ei_camera_get_data;
    Serial.println("Capturing image");
    if (ei_camera_capture((size_t)EI_CLASSIFIER_INPUT_WIDTH, (size_t)EI_CLASSIFIER_INPUT_HEIGHT, snapshot_buf) == false) {
        Serial.println("Failed to capture image");
        free(snapshot_buf);
        return;
    Serial.println("Running classifier");
    // Run the classifier
    ei_impulse_result_t result = { 0 };
    EI_IMPULSE_ERROR err = run_classifier(&signal, &result, debug_nn);
    if (err != EI_IMPULSE_OK) {
        Serial.printf("ERR: Failed to run classifier (%d)\n", err);
        free(snapshot_buf);
        return;
    // print the predictions
    Serial.printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
                result.timing.dsp, result.timing.classification, result.timing.anomaly);
#if EI_CLASSIFIER_OBJECT_DETECTION == 1
    Serial.println("Object detection bounding boxes:");
    for (uint32_t i = 0; i < result.bounding_boxes_count; i++) {
        ei_impulse_result_bounding_box_t bb = result.bounding_boxes[i];
        if (bb.value == 0) {
            continue;
        Serial.printf("  %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n",
                bb.label,
                bb.value,
                bb.x,
                bb.y,
                bb.width,
                bb.height);
#else
    Serial.println("Predictions:");
    for (uint16_t i = 0; i < EI_CLASSIFIER_LABEL_COUNT; i++) {
        Serial.printf("  %s: %.5f\n", ei_classifier_inferencing_categories[i], result.classification[i].value);
#endif
#if EI_CLASSIFIER_HAS_ANOMALY
    Serial.printf("Anomaly prediction: %.3f\n", result.anomaly);
#endif
#if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
    Serial.println("Visual anomalies:");
    for (uint32_t i = 0; i < result.visual_ad_count; i++) {
        ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
            continue;
                bb.label,
                bb.value,
                bb.x,
                bb.y,
                bb.width,
                bb.height);
#endif
    free(snapshot_buf);
    Serial.println("Loop done");
    delay(2000); // Add a delay to prevent rapid looping
 * @brief   Setup image sensor & start streaming
 * @retval  false if initialization failed
bool ei_camera_init(void) {
    if (is_initialised) return true;
    //initialize the camera
    esp_err_t err = esp_camera_init(&camera_config);
    if (err != ESP_OK) {
        Serial.printf("Camera init failed with error 0x%x\n", err);
        return false;
    sensor_t * s = esp_camera_sensor_get();
    // initial sensors are flipped vertically and colors are a bit saturated
    if (s->id.PID == OV3660_PID) {
        s->set_vflip(s, 1); // flip it back
        s->set_brightness(s, 1); // up the brightness just a bit
        s->set_saturation(s, 0); // lower the saturation
    is_initialised = true;
    return true;
 * @brief      Stop streaming of sensor data
void ei_camera_deinit(void) {
    //deinitialize the camera
    esp_err_t err = esp_camera_deinit();
        Serial.println("Camera deinit failed");
        return;
 * @brief      Capture, rescale and crop image
 * @param[in]  img_width     width of output image
 * @param[in]  img_height    height of output image
 * @param[in]  out_buf       pointer to store output image, NULL may be used
 *                           if ei_camera_frame_buffer is to be used for capture and resize/cropping.
 * @retval     false if not initialised, image captured, rescaled or cropped failed
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) {
    bool do_resize = false;
    if (!is_initialised) {
        Serial.println("ERR: Camera is not initialized");
        return false;
    camera_fb_t *fb = esp_camera_fb_get();
    if (!fb) {
        Serial.println("Camera capture failed");
        return false;
    bool converted = fmt2rgb888(fb->buf, fb->len, fb->format, snapshot_buf);
    esp_camera_fb_return(fb);
    if (!converted) {
        Serial.println("to rgb888 conversion failed");
        return false;
    // get size of the data
    size_t snapshot_size = EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE;
    Serial.printf("Snapshot size: %d\n", snapshot_size);
    if (img_width == EI_CAMERA_RAW_FRAME_BUFFER_COLS && img_height == EI_CAMERA_RAW_FRAME_BUFFER_ROWS) {
        Serial.println("No resize needed");
        do_resize = false;
    else {
        do_resize = true;
    if (do_resize) {
        Serial.println("Resizing image");
        ei::image::processing::crop_and_interpolate_image(
            snapshot_buf,
            EI_CAMERA_RAW_FRAME_BUFFER_COLS,
            EI_CAMERA_RAW_FRAME_BUFFER_ROWS,
            out_buf,
            img_width,
            img_height,
    else {
        memcpy(out_buf, snapshot_buf, snapshot_size);
    return true;
 * @brief      Get image from frame buffer
 * @param[in]  offset  offset in the frame buffer to get data
 * @param[in]  length  amount of bytes to get
 * @param[out] out_ptr pointer to store output data
 * @retval     0 if success
static int ei_camera_get_data(size_t offset, size_t length, float *out_ptr) {
    uint8_t *image = snapshot_buf + offset;
    for (size_t i = 0; i < length; i++) {
        out_ptr[i] = static_cast<float>(image[i]) / 255.0f;
    return 0;
This a Arduino code generated by edge impulse for car detection model.
I am using esp32s3 camera for this project .
When i try to upload this code into my device after uploading this error is occurring please help me to solve this error.
You're writing to an invalid pointer somewhere. Use the EspExceptionDecoder to look at the stack trace and see where it goes wrong.
