Gustavo04
Hola tengo este Problema al compilar.
Por favor me pueden ayudar
Arduino: 1.6.4 (Windows 7), Board: “Arduino Uno”
sketch_aug21a.ino: In function ‘void setup()’:
sketch_aug21a:6: error: expected unqualified-id before ‘.’ token
Multiple libraries were found for “Scheduler.h”
Used: C:\Users\Gustavo Solano\Documents\Arduino\libraries\Scheduler
Not used: C:\Program Files (x86)\Arduino\libraries\Scheduler
“Show verbose output during compilation”
enabled in File > Preferences.
Adjunto el programa.
#include <Scheduler.h>
Scheduler.startLoop(loop1);
void loop1 () {
Multiple libraries were found for "Scheduler.h"
You have the header file in two places. They are probably not the same header file so the syntax you use for the scheduler object does not match what is in the header file being used.
Decide which one is the right one and delete other one.
