Guys need Help for the delay function
My problem is, I wanna have a continuous reading for my sensor then after lets say 10 secs a message will appear....
Serial.println("readings"); //this should be continuous
delay(100);
Serial.println("message"); //every 10 seconds there should appear a message or something...
delay(10000);
the problem is the readings just print a single value not continuous
need help badly
may be your input pin is floating.. so int your internal pull-up resistors
Well, then get rid of the delays!. They are why you are not getting continuous readings. Look at the blink without delay example.
[/quote]
I'll try that one....
