GxEPD not drawing out correct color
I am trying to draw christmas tree using GxEpd with following code:
#include <GxEPD.h>
#include <GxGDEW042Z15/GxGDEW042Z15.h>    // 4.2" b/w/r
#include <GxIO/GxIO_SPI/GxIO_SPI.h>
#include <GxIO/GxIO.h>
// FreeFonts from Adafruit_GFX
#include <Fonts/FreeMonoBold9pt7b.h>
#include GxEPD_BitmapExamples
// select one, depending on your CS connection
GxIO_Class io(SPI, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9); // arbitrary selection of 8, 9 selected for default of GxEPD_Class
//GxIO_Class io(SPI, /*CS=*/ 10, /*DC=*/ 8, /*RST=*/ 9); // arbitrary selection of 8, 9, CS on 10 (for CS same as on UNO, for SPI on ICSP use)
GxEPD_Class display(io, /*RST=*/ 9, /*BUSY=*/ 7); // default selection of (9), 7
//#define DEMO_DELAY 3*60 // seconds
//#define DEMO_DELAY 1*60 // seconds
#define DEMO_DELAY 10
void setup(void)
  Serial.println("setup");
  display.init(115200); // enable diagnostic output on Serial
  Serial.println("setup done");
  display.drawExampleBitmap(tree, sizeof(tree),GxEPD_RED);
  display.update();
  delay(30000);
I have three-colored 4.2’’ Waveshare E-Ink display.The tree is defined, and it is 400*292. But my tree is drawn out in black color instead of red.
(In code there are some libraries from example, which are additional)
Any ideas?
@rktech,
Ok, I see you are willing to learn. But the title of your topic and post is still wrong!
You didn’t take into consideration that the error might be in your code.
Take a look at GxEPD.h
// class GxEPD : Base Class for Display Classes for e-Paper Displays from Dalian Good Display Co., Ltd.: www.good-display.com
// based on Demo Examples from Good Display, available here: http://www.good-display.com/download_list/downloadcategoryid=34&isMode=false.html
// Author : J-M Zingg
// Version : see library.properties
// License: GNU GENERAL PUBLIC LICENSE V3, see LICENSE
// Library: https://github.com/ZinggJM/GxEPD
#ifndef _GxEPD_H_
#define _GxEPD_H_
#include <Arduino.h>
#include <SPI.h>
#include "GxIO/GxIO.h"
#include <Adafruit_GFX.h>
#include "GxFont_GFX.h"
// the only colors supported by any of these displays; mapping of other colors is class specific
#define GxEPD_BLACK     0x0000
#define GxEPD_DARKGREY  0x7BEF      /* 128, 128, 128 */
#define GxEPD_LIGHTGREY 0xC618      /* 192, 192, 192 */
#define GxEPD_WHITE     0xFFFF
#define GxEPD_RED       0xF800      /* 255,   0,   0 */
//class GxEPD : public Adafruit_GFX
class GxEPD : public GxFont_GFX
  public:
    // bitmap presentation modes may be partially implemented by subclasses
    enum bm_mode //BM_ModeSet
      bm_normal = 0,
      bm_default = 1, // for use for BitmapExamples
      // these potentially can be combined
      bm_invert = (1 << 1),
      bm_flip_x = (1 << 2),
      bm_flip_y = (1 << 3),
      bm_r90 = (1 << 4),
      bm_r180 = (1 << 5),
      bm_r270 = bm_r90 | bm_r180,
      bm_partial_update = (1 << 6),
      bm_invert_red = (1 << 7),
      bm_transparent = (1 << 8)
  public:
    //GxEPD(int16_t w, int16_t h) : Adafruit_GFX(w, h) {};
    GxEPD(int16_t w, int16_t h) : GxFont_GFX(w, h) {};
    virtual void drawPixel(int16_t x, int16_t y, uint16_t color) = 0;
    virtual void init(uint32_t serial_diag_bitrate = 0) = 0; // = 0 : disabled
    virtual void fillScreen(uint16_t color) = 0; // to buffer
    virtual void update(void) = 0;
    // to buffer, may be cropped, drawPixel() used, update needed, subclass may support some modes
    virtual void drawBitmap(const uint8_t *bitmap, uint16_t x, uint16_t y, uint16_t w, uint16_t h, uint16_t color, int16_t m = bm_normal) = 0;
    // to buffer, may be cropped, drawPixel() used, update needed, subclass may support some modes, default for example bitmaps
    virtual void drawExampleBitmap(const uint8_t *bitmap, uint16_t x, uint16_t y, uint16_t w, uint16_t h, uint16_t color, int16_t m = bm_default)
      drawBitmap(bitmap, x, y, w, h, color, m);
    // monochrome or 4 gray or other to full screen, filled with white if size is less, no update needed
    virtual void drawPicture(const uint8_t *picture, uint32_t size) // b/w or grey is class specific
      drawBitmap(picture, size); // default is monochrome
    // to full screen, filled with white if size is less, no update needed, black  /white / red, for example bitmaps
    virtual void drawExamplePicture(const uint8_t* black_bitmap, const uint8_t* red_bitmap, uint32_t black_size, uint32_t red_size){};
    // to full screen, filled with white if size is less, no update needed, black  /white / red, general version
    virtual void drawPicture(const uint8_t* black_bitmap, const uint8_t* red_bitmap, uint32_t black_size, uint32_t red_size, int16_t mode = bm_normal){};
    // monochrome to full screen, filled with white if size is less, no update needed
    virtual void drawBitmap(const uint8_t *bitmap, uint32_t size, int16_t m = bm_normal) = 0; // monochrome
    virtual void drawExampleBitmap(const uint8_t *bitmap, uint32_t size, int16_t m = bm_default) // monochrome
      drawBitmap(bitmap, size, m);
    virtual void eraseDisplay(bool using_partial_update = false) {};
    // partial update of rectangle from buffer to screen, does not power off
    virtual void updateWindow(uint16_t x, uint16_t y, uint16_t w, uint16_t h, bool using_rotation = true) {};
    // partial update of rectangle at (xs,ys) from buffer to screen at (xd,yd), does not power off
    virtual void updateToWindow(uint16_t xs, uint16_t ys, uint16_t xd, uint16_t yd, uint16_t w, uint16_t h, bool using_rotation = true) {};
    // terminate cleanly updateWindow or updateToWindow before removing power or long delays
    virtual void powerDown() = 0;
  protected:
    void drawBitmapBM(const uint8_t *bitmap, uint16_t x, uint16_t y, uint16_t w, uint16_t h, uint16_t color, int16_t m);
    static inline uint16_t gx_uint16_min(uint16_t a, uint16_t b) {return (a < b ? a : b);};
    static inline uint16_t gx_uint16_max(uint16_t a, uint16_t b) {return (a > b ? a : b);};
#endif
Your method call matches to this method:
This method takes as third parameter a mode value, which is a set of mode bits, but not a color.
If you want your monochrome bitmap be shown in the color of your e-paper, you could use this method:
You can pass 0 for the black_bitmap parameter, if you have only a bitmap for red.
These methods draw to the controller and screen directly, you don’t need update().
Should work, as the bitmap width corresponds to screen width.
But you may need to use this method, as your bitmap dimensions differ from the screen dimensions:
The other option would be to use a bitmap drawing method of Adafruit_GFX, see Adafruit_GFX.h
Jean-Marc
Thanks, but it is not working anyway. With display.update() I've got an black rectangle on one side, but nothing else. Should I use paged drawing on Mega?
You didn't take into consideration that the error might be in your code.
I did, but I can´t find better title.
rktech: Thanks, but it is not working anyway. With display.update() I've got an black rectangle on one side, but nothing else. Should I use paged drawing on Mega?
Just add for me at the end. Then I can accept it.
And you need to learn to provide complete information, e.g. processor used. Post the bitmap you want to show, then I might provide "your personal example". BTW did you try the examples and try to understand what they do?
For MEGA you need to use paged drawing for buffered drawing.
I recommend GxEPD2 for Newbies.
Thanks, Image is in attachment, code is converted using image2cpp:
const unsigned char tree [] PROGMEM = {
  0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
(code is not complete, since it is more than 9000 characters)
ZinggJM: BTW did you try the examples and try to understand what they do?
Yes, but I didn't found how to do this
