I'm using the GxEPD2 library for a black/white 2.9" Waveshare epaper v2 display. I was able to get the display drawn properly, including some lines and custom fonts. My first iteration did the basic drawing in setup()
and then in loop()
I would use display.setPartialWindow()
to update three partial areas every five minutes. Worked great, but the ESP8266 had to be constantly plugged in. I refactored the code so that all the display interaction ran within setup()
and then the ESP would deep sleep for five minutes. When I deployed this new code, the initial cold start drawing all worked properly, but when the display woke up from deep sleep and tried to use display.setPartialWindow()
the epaper became a screen full of static.
I was able to trim down the code I'm using to something that is as bare-bones as I can make it while still demonstrating the issue:
#include <Arduino.h>
#include <GxEPD2_BW.h>
#include <user_interface.h>
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSansBold9pt7b.h>
#include "GxEPD2_display_selection_new_style.h"
struct {
uint8_t startup_count;
bool clean_start;
} startup_data;
uint32_t sleep_interval = 180e6;
uint16_t max_starts_between_refresh = 3;
pinMode(D0, WAKEUP_PULLUP);
Serial.begin(74880);
Serial.setTimeout(2000);
while (!Serial) { }
ESP.rtcUserMemoryRead(0, (uint32_t *)&startup_data, sizeof(startup_data));
rst_info *r_info = ESP.getResetInfoPtr();
if ((*r_info).reason == 6 || startup_data.startup_count >= max_starts_between_refresh)
startup_data.startup_count = 1;
startup_data.clean_start = true;
display.init(74880, startup_data.clean_start, 2, false);
display.setRotation(1);
display.setTextColor(GxEPD_BLACK);
if (startup_data.clean_start)
display.firstPage();
do {
display.setFont(&FreeSans9pt7b);
display.fillScreen(GxEPD_WHITE);
display.setCursor(1, 17);
display.print("Today is ");
display.setFont(&FreeSansBold9pt7b);
display.setCursor(1, 45);
display.print("Happening Now:");
display.setCursor(display.width() / 2, 45);
display.print("Up Next:");
} while (display.nextPage());
display.setPartialWindow(display.width() / 2, 0, display.width() / 2, 20);
do {
display.setCursor(display.width() / 2, 17);
display.print(millis());
startup_data.startup_count += 1;
startup_data.clean_start = false;
ESP.rtcUserMemoryWrite(0, (uint32_t *)&startup_data, sizeof(startup_data));
display.powerOff();
ESP.deepSleep(sleep_interval);
void loop () { }
On this code, the initial startup displays just fine; the next time it wakes from sleep, it turns to static, and it continues to be static until after three wake cycles, at which point I force it to redraw the entire screen and it fixes itself again.
Some additional troubleshooting I've done on here was trying to track down where in the code the static actually happens - seems like as soon as I use setPartialWindow()
, that's the issue - even if I do a full-screen partial display (eg. display.setPartialWindow(0, 0, display.width(), display.height())
). If I omit the partial window and just let it wake up and go to sleep again, the screen doesn't have any issues (I thought perhaps there was some electrical noise involved in waking up that was causing it to mess up).
My guess is there's something about the ESP8266 waking up and how I'm initing the display that's causing issues?
What it normally looks like:
What it looks like when waking from deep sleep:
