GxEPD2 GDEY1248Z51 (uc8179) - How to start?
Hi @ZinggJM ,
we had a small discussion about parallel panels - I did some more research. And found this product: https://x.alibaba.com/AwHoY4?ck=pdp
It’s quite cheap - 140$ exluding shipping.
I want to ask how should I start. It uses an esp32 board and I found out the pinout (I got it from GooDisplay):
int EPD_W21_SDA = T0;
int EPD_W21_SCL =T1;
int EPD_W21_CS_S2 = T2;
int EPD_W21_CS_M1 = T3;
int EPD_W21_RST_M2 = T4;
int EPD_W21_RST_M1 = T5;
int EPD_W21_DC_M2 = T6;
int EPD_W21_DC_M1 = T7;
int EPD_W21_CS_M2 = T8;
int EPD_W21_CS_S1 = T9;
//BUSY
int EPD_W21_BUSY_M1=A3;
Which example should I use if I order this panel + controller. The only problem I see is that the esp32 doesn’t have enough ram to handle such high resolution screen. I think the best way would be to download the whole image to the spiffs and write it to the panel.
Happy to hear your thoughts!
Per the data sheet it supports
Data 0x3F40_0000 0x3F7F_FFFF 4 MB External Flash Read
Data 0x3F80_0000 0x3FBF_FFFF 4 MB External SRAM Read and Write
If that is not enough you can go to memory banking.
This link will give you the details on the part. https://www.espressif.com/sites/default/files/documentation/esp32_technical_reference_manual_en.pdf This link goes back to the old days but may be easier to understand: arduino - How can 8-bit processor support more than 256 bytes of RAM? - Electrical Engineering Stack Exchange
Hi @gilshultz ,
I know that the esp32 has support for PSRAM. I also used boards with PSRAM. But I guess here the board doesn’t have psram.
So that’s why I asked @ZinggJM - if I should download the whole image to SPIFFS / NVS and write it as whole to the panel.
Edit: And how to general start with the library with the panel. I am not a complete beginner I built already esp32 projects but never touched displays.
Yes, if you want to present bitmaps or BMP files, this is the option of choice.
GxEPD2 has an example GxEPD2_Spiffs_Example.ino.
Take a look at GxEPD2_1248c.h.
And to your surprise, see:
// Panel: GDEY1248Z51 : https://www.good-display.com/product/422.html
// Controller: UC8179 : https://v4.cecdn.yun300.cn/100001_1909185148/UC8179.pdf
// Connection Module : e.g. DESPI-C1248 : https://buyepaper.com/products/connection-board-for-1248-inch-large-eaper-e-ink-display-demo-despi-c1248
// Demo Kit : e.g. DESPI-1248 : https://buy-lcd.com/products/demo-kit-driver-development-board-for-1248-inch-large-eaper-e-ink-display
// Waveshare Kit : https://www.waveshare.com/product/displays/e-paper/epaper-1/12.48inch-e-paper-module-b.htm
This panel is already supported.
Note however that I don't recommend this panel, nor the b/w version, as it uses 4 controllers to drive the TFT layer. The 4 controllers, two masters and two slaves, should run in synch. But this isn't perfect, and is noticeable during refresh.
And I never re-test GxEPD2 with these panels, as a consequence.
GxEPD2 uses paged drawing for graphics on this panel, with 4 pages:
// Waveshare 12.48 b/w/r SPI display board and frame or Good Display 12.48 b/w/r panel GDEY1248Z51
// general constructor for use with all parameters, e.g. for Waveshare ESP32 driver board mounted on connection board
//GxEPD2_3C < GxEPD2_1248c, GxEPD2_1248c::HEIGHT / 4 >
//display(GxEPD2_1248c(/*sck=*/ 13, /*miso=*/ 12, /*mosi=*/ 14, /*cs_m1=*/ 23, /*cs_s1=*/ 22, /*cs_m2=*/ 16, /*cs_s2=*/ 19,
//                             /*dc1=*/ 25, /*dc2=*/ 17, /*rst1=*/ 33, /*rst2=*/ 5, /*busy_m1=*/ 32, /*busy_s1=*/ 26, /*busy_m2=*/ 18, /*busy_s2=*/ 4));
Actual link: Large 12.48 inch E-paper Display Color E-ink Screen, GDEY1248Z51_Good Display (good-display.com)
-jz-
@smartielover
If you are looking for a challenge with e-paper displays, something not yet well supported:
9.7-inch and 13.3-inch Parallel Screen Test Board Development Kit, EPDiy_Good Display (good-display.com)
I bought this board, but didn't have time yet to experiment with it.
But I think the library GitHub - vroland/epdiy: EPDiy is a driver board for affordable e-Paper (or E-ink) displays. would be worth to look at.
And this board from Good Display could be a start.
Have fun!
-jz-
Hello @ZinggJM ,
thank you for the detailed response. I had a chat with GoodDisplay and the parallel panel looks really Cool especially the refresh rates are impressive. The big downside is that only the panel costs around 250$ without the case without the driver without shipping.
The linked board has the big advantage of the price (200$ incl. shipping).. The only downside I see is the slow refresh rate of 37 seconds. The parallel Display needs only 1second for a full refresh. Is it worth spending 100-150$ more?
I never saw a Pin-Config like that:
Can I ignore the T and use only the Numbers behind it? I want to use the controller which comes with the panel. To reduce the time to get this thing working.
The Code from Good-Display streams the Bitmap-Values and send it to the panel. For me it would be enough to download the whole Bitmap and refresh the panel afterwards. I don't want to display realtime-Data a refresh every 2mins would be fine.
I will think about the other options.
The link in your first post is pretty useless for me. What shop is it related to?
I order frequently through AliExpress. There I can see the shop that sells the product, and the rating of the shop.
It looks like the display your link relates to might be the 1304×984, 12.48inch E-Ink display module, red/black/white three-color, SPI interface (waveshare.com).
The 3-color displays do have long refresh times.
See arduino-esp32/variants/esp32/pins_arduino.h at master · espressif/arduino-esp32 · GitHub
The T* pins seem to be pins with trigger interrupt capability, so this is unusual name usage.
The Waveshare display comes with the Waveshare ESP32 Driver processor board, as far as I remember.
-jz-
Update:
Color WIFI Tag, 12.48 inch E-paper Display Label Sign, GDP1248RW1_Good Display (good-display.com)
Ok, now I found it. I don't usually look under signage.
The Link is the official GoodDisplay Shop on Alibaba. The send me the code for the esp32 and the Software for windows.
It includes:
  • Panel
  • Enclousure
  • Driver
They told me 140$ + 60$ shipping .. The other Panel cost without driver + enclosure 250$. The Problem I see here is: Is it worth paying so much more for faster refresh rates...
Thank you for the research with the Pin-Numbering its really weird that they doesn't use the normal numbers.
In order to provide better user experience for our 12.48-inch E-paper, we specially launched this GDP1248RW1 module, which is powered by Type-C and supports firmware updates.
I like e-paper displays from Good Display. But I questioned the usefulness of these 12.48" displays.
So maybe this is an attempt to get rid of some surplus panels?
Maybe you should state your motivation for looking for large e-paper displays. What are your needs?
I need to terminate with this response to this topic.
I try to give answers in this forum to questions and issues with my libraries.
But I no longer have time to answer questions in a broader scope.
-jz-
Totally understand that your free time is limited. I will do my homework and if I buy this panel I will create a new thread and ping you.
My use case: Displaying data from HomeAssistant, Pictures and other Values...
