GxEPD2 Partial refresh takes 3 seconds instead of 0.3 seconds. How come?
Correct! Known as "paging".
The size of these "slices" is set by the "page height". You set this when declaring your display:
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 9, /*DC=*/ 8, /*RST=*/ 12, /*BUSY=*/ 13));
(source)
Note the MAX_HEIGHT(GxEPD2_DRIVER_CLASS) argument in there. This sets page height to the same as the display height, meaning you only use one page. This will only work if your device has enough RAM (like the Pi Pico)
If you wanted to, for some reason, you could also manually set a different page height there.
