GxEPD2 Waveshare Pico-ePaper-2.13 V3 & Raspberry Pico W
I need some assistance. I have a Raspberry Pi Pico W and a Waveshare Pico-ePaper-2.13 display. The display is marked as V3 and the label on the FPC cable reads FPC-7528B.
I've been trying to make it work with the GxEPD2 library under Arduino Pico.
Following the instructions in the "GxEPD2_Example.ino", I selected 'GxEPD2_213_BN' in I selected 'GxEPD2_213_BN' in 'GxEPD2_display_selection_new_style.h'.
And I modified the pin setting like this
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 9, /*DC=*/ 8, /*RST=*/ 12, /*BUSY=*/ 13));
Because the SPI0 was used in wifi. I selected SPI1 in the 'selectSPI'.
 // init spi
  SPI1.setCS(9);
  SPI1.setSCK(10);
  SPI1.setTX(11);
  // uncomment next line for use with GoodDisplay DESPI-PICO, or use the extended init method
  display.epd2.selectSPI(SPI1, SPISettings(4000000, MSBFIRST, SPI_MODE0));
Unfortunately, I've been trying for many days, but the display doesn't respond at all. I added some debug prints and found that after sending _writeCommand(0x12) //SWRESET , the display remains stuck in the 'busy' state."
void GxEPD2_213_BN::_InitDisplay()
  if (_hibernating) _reset();
  delay(10); // 10ms according to specs
  _waitWhileBusy("Before_SWRESET", 100); //for debug
  Serial.printf("_busy: %d\n",digitalRead(_busy)); //for debug
  _writeCommand(0x12);  //SWRESET //for debug
  _waitWhileBusy("After_SWRESET", 100); //for debug
void GxEPD2_EPD::_writeCommand(uint8_t c)
  Serial.printf("command: %02X\n", c); //for debug
  _pSPIx->beginTransaction(_spi_settings);
  if (_dc >= 0) digitalWrite(_dc, LOW);
  if (_cs >= 0) digitalWrite(_cs, LOW);
  _pSPIx->transfer(c);
  if (_cs >= 0) digitalWrite(_cs, HIGH);
  if (_dc >= 0) digitalWrite(_dc, HIGH);
  _pSPIx->endTransaction();
  Serial.printf("_busy: %d\n", digitalRead(_busy)); //for debug
console output
22:13:02.804 -> Before_SWRESET : 7
22:13:02.804 -> _busy: 0
22:13:02.804 -> command: 12
22:13:02.804 -> _busy: 1
22:13:22.824 -> Busy Timeout!
22:13:22.824 -> After_SWRESET : 20000951
I don't know where these come from. What board package do you use, which board do you select?
I prefer complete code to look at, not just snippets.
E.g. constructors and setup, to see the sequence of initialization.
Your busy timeout time does not correspond to GxEPD2_213_BN.
20000ms is used for most 3-color displays.
Could you have uncommented more than one display?
it comes from the document of arduino-pico.
Raspberry Pi Pico
sorry, I cannot upload attachment because of the limitation.
GxEPD2_Example_copy_20231001110141.ino
// Display Library example for SPI e-paper panels from Dalian Good Display and boards from Waveshare.
// Requires HW SPI and Adafruit_GFX. Caution: the e-paper panels require 3.3V supply AND data lines!
// Display Library based on Demo Example from Good Display: http://www.e-paper-display.com/download_list/downloadcategoryid=34&isMode=false.html
// Author: Jean-Marc Zingg
// Version: see library.properties
// Library: https://github.com/ZinggJM/GxEPD2
// Supporting Arduino Forum Topics:
// Waveshare e-paper displays with SPI: http://forum.arduino.cc/index.php?topic=487007.0
// Good Display ePaper for Arduino: https://forum.arduino.cc/index.php?topic=436411.0
// see GxEPD2_wiring_examples.h for wiring suggestions and examples
// NOTE for use with Waveshare ESP32 Driver Board:
// **** also need to select the constructor with the parameters for this board in GxEPD2_display_selection_new_style.h ****
// The Wavehare ESP32 Driver Board uses uncommon SPI pins for the FPC connector. It uses HSPI pins, but SCK and MOSI are swapped.
// To use HW SPI with the ESP32 Driver Board, HW SPI pins need be re-mapped in any case. Can be done using either HSPI or VSPI.
// Other SPI clients can either be connected to the same SPI bus as the e-paper, or to the other HW SPI bus, or through SW SPI.
// The logical configuration would be to use the e-paper connection on HSPI with re-mapped pins, and use VSPI for other SPI clients.
// VSPI with standard VSPI pins is used by the global SPI instance of the Arduino IDE ESP32 package.
// uncomment next line to use HSPI for EPD (and e.g VSPI for SD), e.g. with Waveshare ESP32 Driver Board
//#define USE_HSPI_FOR_EPD
// base class GxEPD2_GFX can be used to pass references or pointers to the display instance as parameter, uses ~1.2k more code
// enable or disable GxEPD2_GFX base class
#define ENABLE_GxEPD2_GFX 0
// uncomment next line to use class GFX of library GFX_Root instead of Adafruit_GFX
//#include <GFX.h>
// Note: if you use this with ENABLE_GxEPD2_GFX 1:
//       uncomment it in GxEPD2_GFX.h too, or add #include <GFX.h> before any #include <GxEPD2_GFX.h>
#include <GxEPD2_BW.h>
#include <GxEPD2_3C.h>
#include <GxEPD2_4C.h>
#include <GxEPD2_7C.h>
#include <Fonts/FreeMonoBold9pt7b.h>
// select the display constructor line in one of the following files (old style):
#include "GxEPD2_display_selection.h"
#include "GxEPD2_display_selection_added.h"
// or select the display class and display driver class in the following file (new style):
#include "GxEPD2_display_selection_new_style.h"
#include "bitmaps/Bitmaps128x250.h" // 2.13" b/w
  // init serial
  Serial.begin(115200); //for debug
  Serial.println("init spi");
  // init spi
  SPI1.setCS(9);
  SPI1.setSCK(10);
  SPI1.setTX(11);
  // uncomment next 2 lines to allow recovery from configuration failures
  pinMode(15, INPUT_PULLUP); // safety pin
  Serial.println("wait pin15");
  while (!digitalRead(15)) delay(100); // check safety pin for fail recovery
  Serial.println("wait pin15 finished");
  Serial.println("init display");
  // init display
  //display.init(115200); // default 10ms reset pulse, e.g. for bare panels with DESPI-C02
  display.init(115200, true, 2, false); // USE THIS for Waveshare boards with "clever" reset circuit, 2ms reset pulse
  //display.init(115200, true, 10, false, SPI0, SPISettings(4000000, MSBFIRST, SPI_MODE0)); // extended init method with SPI channel and/or settings selection
  // first update should be full refresh
  Serial.println("init display finished");
  helloWorld();
  // partial refresh mode can be used to full screen,
  // effective if display panel hasFastPartialUpdate
  helloFullScreenPartialMode();
  //stripeTest(); return; // GDEH029Z13 issue
  helloArduino();
  helloEpaper();
  //helloValue(123.9, 1);
  //delay(1000);
  showFont("FreeMonoBold9pt7b", &FreeMonoBold9pt7b);
  if (display.epd2.WIDTH < 104)
    showFont("glcdfont", 0);
  drawBitmaps();
  drawGraphics();
  //return;
  if (display.epd2.hasPartialUpdate)
    showPartialUpdate();
  } // else // on GDEW0154Z04 only full update available, doesn't look nice
  //drawCornerTest();
  //showBox(16, 16, 48, 32, false);
  //showBox(16, 56, 48, 32, true);
  display.powerOff();
  deepSleepTest();
#if defined(ESP32) && defined(_GxBitmaps1304x984_H_)
  drawBitmaps1304x984();
  display.powerOff();
#endif
  Serial.println("setup done");
// note for partial update window and setPartialWindow() method:
// partial update window size and position is on byte boundary in physical x direction
// the size is increased in setPartialWindow() if x or w are not multiple of 8 for even rotation, y or h for odd rotation
// see also comment in GxEPD2_BW.h, GxEPD2_3C.h or GxEPD2_GFX.h for method setPartialWindow()
const char HelloWorld[] = "Hello World!";
const char HelloArduino[] = "Hello Arduino!";
const char HelloEpaper[] = "Hello E-Paper!";
void helloWorld()
  Serial.println("setRotation");
  display.setRotation(1);
  display.setFont(&FreeMonoBold9pt7b);
  if (display.epd2.WIDTH < 104) display.setFont(0);
  display.setTextColor(GxEPD_BLACK);
  int16_t tbx, tby; uint16_t tbw, tbh;
  display.getTextBounds(HelloWorld, 0, 0, &tbx, &tby, &tbw, &tbh);
  // center bounding box by transposition of origin:
  uint16_t x = ((display.width() - tbw) / 2) - tbx;
  uint16_t y = ((display.height() - tbh) / 2) - tby;
  display.setFullWindow();
  Serial.println("firstPage");
  display.firstPage();
  do
    Serial.println("fillScreen");
    Serial.println(digitalRead(13));
    display.fillScreen(GxEPD_WHITE);
    display.setCursor(x, y);
    Serial.println("print");
    display.print(HelloWorld);
  while (display.nextPage());
  //Serial.println("helloWorld done");
void helloWorldForDummies()
  //Serial.println("helloWorld");
  const char text[] = "Hello World!";
  // most e-papers have width < height (portrait) as native orientation, especially the small ones
  // in GxEPD2 rotation 0 is used for native orientation (most TFT libraries use 0 fix for portrait orientation)
  // set rotation to 1 (rotate right 90 degrees) to have enough space on small displays (landscape)
  // select a suitable font in Adafruit_GFX
  // on e-papers black on white is more pleasant to read
  // Adafruit_GFX has a handy method getTextBounds() to determine the boundary box for a text for the actual font
  int16_t tbx, tby; uint16_t tbw, tbh; // boundary box window
  display.getTextBounds(text, 0, 0, &tbx, &tby, &tbw, &tbh); // it works for origin 0, 0, fortunately (negative tby!)
  // full window mode is the initial mode, set it anyway
  // here we use paged drawing, even if the processor has enough RAM for full buffer
  // so this can be used with any supported processor board.
  // the cost in code overhead and execution time penalty is marginal
  // tell the graphics class to use paged drawing mode
  do
    // this part of code is executed multiple times, as many as needed,
    // in case of full buffer it is executed once
    // IMPORTANT: each iteration needs to draw the same, to avoid strange effects
    // use a copy of values that might change, don't read e.g. from analog or pins in the loop!
    display.fillScreen(GxEPD_WHITE); // set the background to white (fill the buffer with value for white)
    display.setCursor(x, y); // set the postition to start printing text
    display.print(text); // print some text
    // end of part executed multiple times
  // tell the graphics class to transfer the buffer content (page) to the controller buffer
  // the graphics class will command the controller to refresh to the screen when the last page has been transferred
  // returns true if more pages need be drawn and transferred
  // returns false if the last page has been transferred and the screen refreshed for panels without fast partial update
  // returns false for panels with fast partial update when the controller buffer has been written once more, to make the differential buffers equal
  // (for full buffered with fast partial update the (full) buffer is just transferred again, and false returned)
void helloFullScreenPartialMode()
  //Serial.println("helloFullScreenPartialMode");
  const char fullscreen[] = "full screen update";
  const char fpm[] = "fast partial mode";
  const char spm[] = "slow partial mode";
  const char npm[] = "no partial mode";
  display.setPartialWindow(0, 0, display.width(), display.height());
  const char* updatemode;
  if (display.epd2.hasFastPartialUpdate)
    updatemode = fpm;
  else if (display.epd2.hasPartialUpdate)
    updatemode = spm;
    updatemode = npm;
  // do this outside of the loop
  // center update text
  display.getTextBounds(fullscreen, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t utx = ((display.width() - tbw) / 2) - tbx;
  uint16_t uty = ((display.height() / 4) - tbh / 2) - tby;
  // center update mode
  display.getTextBounds(updatemode, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t umx = ((display.width() - tbw) / 2) - tbx;
  uint16_t umy = ((display.height() * 3 / 4) - tbh / 2) - tby;
  // center HelloWorld
  uint16_t hwx = ((display.width() - tbw) / 2) - tbx;
  uint16_t hwy = ((display.height() - tbh) / 2) - tby;
  do
    display.setCursor(hwx, hwy);
    display.setCursor(utx, uty);
    display.print(fullscreen);
    display.setCursor(umx, umy);
    display.print(updatemode);
  //Serial.println("helloFullScreenPartialMode done");
void helloArduino()
  //Serial.println("helloArduino");
  display.setTextColor(display.epd2.hasColor ? GxEPD_RED : GxEPD_BLACK);
  // align with centered HelloWorld
  // height might be different
  display.getTextBounds(HelloArduino, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t y = ((display.height() / 4) - tbh / 2) - tby; // y is base line!
  // make the window big enough to cover (overwrite) descenders of previous text
  uint16_t wh = FreeMonoBold9pt7b.yAdvance;
  uint16_t wy = (display.height() / 4) - wh / 2;
  display.setPartialWindow(0, wy, display.width(), wh);
  do
    //display.drawRect(x, y - tbh, tbw, tbh, GxEPD_BLACK);
    display.print(HelloArduino);
  //Serial.println("helloArduino done");
void helloEpaper()
  //Serial.println("helloEpaper");
  display.getTextBounds(HelloEpaper, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t y = ((display.height() * 3 / 4) - tbh / 2) - tby; // y is base line!
  uint16_t wy = (display.height() * 3 / 4) - wh / 2;
  do
    display.print(HelloEpaper);
  //Serial.println("helloEpaper done");
// test partial window issue on GDEW0213Z19 and GDEH029Z13
void stripeTest()
  helloStripe(104);
  delay(2000);
  helloStripe(96);
const char HelloStripe[] = "Hello Stripe!";
void helloStripe(uint16_t pw_xe) // end of partial window in physcal x direction
  //Serial.print("HelloStripe("); Serial.print(pw_xe); Serial.println(")");
  display.setRotation(3);
  display.getTextBounds(HelloStripe, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t wy = pw_xe - wh;
  uint16_t y = wy - tby;
  do
    display.print(HelloStripe);
  //Serial.println("HelloStripe done");
#if defined(ESP8266) || defined(ESP32)
#include <StreamString.h>
#define PrintString StreamString
#else
class PrintString : public Print, public String
  public:
    size_t write(uint8_t data) override
      return concat(char(data));
#endif
void helloValue(double v, int digits)
  //Serial.println("helloValue");
  PrintString valueString;
  valueString.print(v, digits);
  display.getTextBounds(valueString, 0, 0, &tbx, &tby, &tbw, &tbh);
  // show what happens, if we use the bounding box for partial window
  uint16_t wx = (display.width() - tbw) / 2;
  uint16_t wy = ((display.height() * 3 / 4) - tbh / 2);
  display.setPartialWindow(wx, wy, tbw, tbh);
  do
    display.print(valueString);
  delay(2000);
  // make the partial window big enough to cover the previous text
  uint16_t ww = tbw; // remember window width
  // adjust, because HelloEpaper was aligned, not centered (could calculate this to be precise)
  ww = max(ww, uint16_t(tbw + 12)); // 12 seems ok
  display.setPartialWindow(wx, wy, ww, wh);
  // alternately use the whole width for partial window
  //display.setPartialWindow(0, wy, display.width(), wh);
  do
  //Serial.println("helloValue done");
void deepSleepTest()
  //Serial.println("deepSleepTest");
  const char hibernating[] = "hibernating ...";
  const char wokeup[] = "woke up";
  const char from[] = "from deep sleep";
  const char again[] = "again";
  // center text
  display.getTextBounds(hibernating, 0, 0, &tbx, &tby, &tbw, &tbh);
  do
    display.print(hibernating);
  display.hibernate();
  delay(5000);
  display.getTextBounds(wokeup, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t wy = ((display.height() / 3) - tbh / 2) - tby; // y is base line!
  display.getTextBounds(from, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t fx = (display.width() - tbw) / 2;
  uint16_t fy = ((display.height() * 2 / 3) - tbh / 2) - tby; // y is base line!
  do
    display.setCursor(wx, wy);
    display.print(wokeup);
    display.setCursor(fx, fy);
    display.print(from);
  delay(5000);
  uint16_t hx = (display.width() - tbw) / 2;
  uint16_t hy = ((display.height() / 3) - tbh / 2) - tby; // y is base line!
  display.getTextBounds(again, 0, 0, &tbx, &tby, &tbw, &tbh);
  uint16_t ax = (display.width() - tbw) / 2;
  uint16_t ay = ((display.height() * 2 / 3) - tbh / 2) - tby; // y is base line!
  do
    display.setCursor(hx, hy);
    display.setCursor(ax, ay);
    display.print(again);
  //Serial.println("deepSleepTest done");
void showBox(uint16_t x, uint16_t y, uint16_t w, uint16_t h, bool partial)
  //Serial.println("showBox");
  if (partial)
    display.setPartialWindow(x, y, w, h);
  do
    display.fillRect(x, y, w, h, GxEPD_BLACK);
  //Serial.println("showBox done");
void drawCornerTest()
  for (uint16_t r = 0; r <= 4; r++)
    display.setRotation(r);
    do
      display.fillRect(0, 0, 8, 8, GxEPD_BLACK);
      display.fillRect(display.width() - 18, 0, 16, 16, GxEPD_BLACK);
      display.fillRect(display.width() - 25, display.height() - 25, 24, 24, GxEPD_BLACK);
      display.fillRect(0, display.height() - 33, 32, 32, GxEPD_BLACK);
      display.setCursor(display.width() / 2, display.height() / 2);
      display.print(display.getRotation());
    delay(2000);
void showFont(const char name[], const GFXfont* f)
  display.setRotation(0);
  do
    drawFont(name, f);
void drawFont(const char name[], const GFXfont* f)
  //display.setRotation(0);
  display.setFont(f);
  display.setCursor(0, 0);
  display.println();
  display.println(name);
  display.println(" !\"#$%&'()*+,-./");
  display.println("0123456789:;<=>?");
  display.println("@ABCDEFGHIJKLMNO");
  display.println("PQRSTUVWXYZ[\\]^_");
  if (display.epd2.hasColor)
    display.setTextColor(GxEPD_RED);
  display.println("`abcdefghijklmno");
  display.println("pqrstuvwxyz{|}~ ");
// showPartialUpdate() purposely uses values that are not multiples of 8 to test this
void showPartialUpdate()
  // some useful background
  helloWorld();
  // use asymmetric values for test
  uint16_t box_x = 10;
  uint16_t box_y = 15;
  uint16_t box_w = 70;
  uint16_t box_h = 20;
  uint16_t cursor_y = box_y + box_h - 6;
  if (display.epd2.WIDTH < 104) cursor_y = box_y + 6;
  float value = 13.95;
  uint16_t incr = display.epd2.hasFastPartialUpdate ? 1 : 3;
  // show where the update box is
  for (uint16_t r = 0; r < 4; r++)
    display.setPartialWindow(box_x, box_y, box_w, box_h);
    do
      display.fillRect(box_x, box_y, box_w, box_h, GxEPD_BLACK);
      //display.fillScreen(GxEPD_BLACK);
    delay(2000);
    do
      display.fillRect(box_x, box_y, box_w, box_h, GxEPD_WHITE);
  //return;
  // show updates in the update box
    for (uint16_t i = 1; i <= 10; i += incr)
      do
        display.setCursor(box_x, cursor_y);
        display.print(value * i, 2);
    do
void drawBitmaps()
#ifdef _GxBitmaps80x128_H_
  drawBitmaps80x128();
#endif
#ifdef _GxBitmaps152x152_H_
  drawBitmaps152x152();
#endif
#ifdef _GxBitmaps104x212_H_
  drawBitmaps104x212();
#endif
#ifdef _GxBitmaps128x250_H_
  drawBitmaps128x250();
#endif
#ifdef _GxBitmaps128x296_H_
  drawBitmaps128x296();
#endif
#ifdef _GxBitmaps152x296_H_
  drawBitmaps152x296();
#endif
#ifdef _GxBitmaps176x264_H_
  drawBitmaps176x264();
#endif
#ifdef _GxBitmaps240x416_H_
  drawBitmaps240x416();
#endif
#ifdef _GxBitmaps400x300_H_
  drawBitmaps400x300();
#endif
#ifdef _GxBitmaps640x384_H_
  drawBitmaps640x384();
#endif
#ifdef _GxBitmaps648x480_H_
  drawBitmaps648x480();
#endif
#ifdef _GxBitmaps800x480_H_
  drawBitmaps800x480();
#endif
#ifdef _WS_Bitmaps800x600_H_
  drawBitmaps800x600();
#endif
#endif
  // 3-color
#ifdef _GxBitmaps3c104x212_H_
  drawBitmaps3c104x212();
#endif
#ifdef _GxBitmaps3c128x250_H_
  drawBitmaps3c128x250();
#endif
#ifdef _GxBitmaps3c128x296_H_
  drawBitmaps3c128x296();
#endif
#ifdef _GxBitmaps3c152x296_H_
  drawBitmaps3c152x296();
#endif
#ifdef _GxBitmaps3c176x264_H_
  drawBitmaps3c176x264();
#endif
#ifdef _GxBitmaps3c400x300_H_
  drawBitmaps3c400x300();
#endif
#ifdef _GxBitmaps3c648x480_H_
  drawBitmaps3c648x480();
#endif
#ifdef _GxBitmaps3c800x480_H_
  drawBitmaps3c800x480();
#endif
#ifdef _GxBitmaps3c880x528_H_
  drawBitmaps3c880x528();
#endif
#if defined(_WS_Bitmaps4c168x168_H_)
  drawBitmaps4c168x168();
#endif
#if defined(_WS_Bitmaps7c192x143_H_)
  drawBitmaps7c192x143();
#endif
#if defined(_GxBitmaps7c800x480_H_)
  drawBitmaps7c800x480();
#endif
#if defined(_WS_Bitmaps7c300x180_H_)
  drawBitmaps7c300x180();
#endif
  if ((display.epd2.WIDTH >= 200) && (display.epd2.HEIGHT >= 200))
    // show these after the specific bitmaps
#ifdef _GxBitmaps200x200_H_
    drawBitmaps200x200();
#endif
    // 3-color
#ifdef _GxBitmaps3c200x200_H_
    drawBitmaps3c200x200();
#endif
#if defined(ESP32) && defined(_GxBitmaps3c1304x984_H_)
  drawBitmaps3c1304x984();
#endif
void drawBitmaps80x128()
#if !defined(__AVR)
  const unsigned char* bitmaps[] =
    Bitmap80x128_1, Bitmap80x128_2, Bitmap80x128_3, Bitmap80x128_4, Bitmap80x128_5
#else
#endif
  if ((display.epd2.WIDTH == 80) && (display.epd2.HEIGHT == 128))
    for (uint16_t i = 0; i < sizeof(bitmaps) / sizeof(char*); i++)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 80, 128, GxEPD_BLACK);
      delay(2000);
    do
      display.drawBitmap(0, 0, WS_Bitmap80x128, 80, 128, GxEPD_BLACK);
    delay(2000);
#endif
void drawBitmaps152x152()
#if !defined(__AVR)
    Bitmap152x152_1, Bitmap152x152_2, Bitmap152x152_3
#else
#endif
  if ((display.epd2.WIDTH == 152) && (display.epd2.HEIGHT == 152))
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 152, 152, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps200x200()
#if defined(ARDUINO_AVR_PRO)
    logo200x200
#elif defined(__AVR)
    logo200x200, //first200x200
#elif defined(_BOARD_GENERIC_STM32F103C_H_) || defined(STM32F1xx)
    logo200x200, first200x200, second200x200, third200x200, //fourth200x200, fifth200x200, sixth200x200, senventh200x200, eighth200x200
#else
    logo200x200, first200x200, second200x200, third200x200, fourth200x200, fifth200x200, sixth200x200, senventh200x200, eighth200x200
    //logo200x200, first200x200, second200x200, fourth200x200, third200x200, fifth200x200, sixth200x200, senventh200x200, eighth200x200 // ED037TC1 test
#endif
  if (display.epd2.hasColor) return; // to avoid many long refreshes
  if ((display.epd2.WIDTH == 200) && (display.epd2.HEIGHT == 200) && !display.epd2.hasColor)
    bool m = display.mirror(true);
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 200, 200, GxEPD_BLACK);
      delay(2000);
    display.mirror(m);
  //else
    bool mirror_y = (display.epd2.panel != GxEPD2::GDE0213B1);
    display.clearScreen(); // use default for white
    int16_t x = (int16_t(display.epd2.WIDTH) - 200) / 2;
    int16_t y = (int16_t(display.epd2.HEIGHT) - 200) / 2;
      display.drawImage(bitmaps[i], x, y, 200, 200, false, mirror_y, true);
      delay(2000);
    int16_t x = -60;
    int16_t y = -60;
    for (uint16_t j = 0; j < 10; j++)
      display.writeScreenBuffer(); // use default for white
      display.writeImage(bitmaps[i], x, y, 200, 200, false, mirror_y, true);
      display.refresh(true);
        // for differential update: set previous buffer equal to current buffer in controller
        display.epd2.writeScreenBufferAgain(); // use default for white
        display.epd2.writeImageAgain(bitmaps[i], x, y, 200, 200, false, mirror_y, true);
      delay(2000);
      x += display.epd2.WIDTH / 4;
      y += display.epd2.HEIGHT / 4;
      if ((x >= int16_t(display.epd2.WIDTH)) || (y >= int16_t(display.epd2.HEIGHT))) break;
    if (!display.epd2.hasFastPartialUpdate) break; // comment out for full show
  display.writeImage(bitmaps[0], int16_t(0), 0, 200, 200, false, mirror_y, true);
  display.writeImage(bitmaps[0], int16_t(int16_t(display.epd2.WIDTH) - 200), int16_t(display.epd2.HEIGHT) - 200, 200, 200, false, mirror_y, true);
  display.epd2.writeImageAgain(bitmaps[0], int16_t(0), 0, 200, 200, false, mirror_y, true);
  display.epd2.writeImageAgain(bitmaps[0], int16_t(int16_t(display.epd2.WIDTH) - 200), int16_t(display.epd2.HEIGHT) - 200, 200, 200, false, mirror_y, true);
  delay(2000);
#endif
void drawBitmaps104x212()
#if !defined(__AVR)
    WS_Bitmap104x212, Bitmap104x212_1, Bitmap104x212_2, Bitmap104x212_3
#else
#endif
  if ((display.epd2.WIDTH == 104) && (display.epd2.HEIGHT == 212) && !display.epd2.hasColor)
      do
        display.drawBitmap(0, 0, bitmaps[i], 104, 212, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps128x250()
#if !defined(__AVR)
    Bitmap128x250_1, logo128x250, first128x250, second128x250, third128x250
#else
#endif
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 250) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 128, 250, GxEPD_BLACK);
      delay(2000);
    display.mirror(m);
#endif
void drawBitmaps128x296()
#if !defined(__AVR)
    Bitmap128x296_1, logo128x296, first128x296, second128x296, third128x296
#else
    Bitmap128x296_1, logo128x296 //, first128x296, second128x296, third128x296
#endif
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 296) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 128, 296, GxEPD_BLACK);
      delay(2000);
    display.mirror(m);
#endif
void drawBitmaps152x296()
#if !defined(__AVR)
    Bitmap152x296_1, Bitmap152x296_2, Bitmap152x296_3
#else
#endif
  if ((display.epd2.WIDTH == 152) && (display.epd2.HEIGHT == 296) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 152, 296, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps176x264()
#if !defined(__AVR)
    Bitmap176x264_1, Bitmap176x264_2, Bitmap176x264_3, Bitmap176x264_4, Bitmap176x264_5
#else
    Bitmap176x264_1, Bitmap176x264_2 //, Bitmap176x264_3, Bitmap176x264_4, Bitmap176x264_5
#endif
  if ((display.epd2.WIDTH == 176) && (display.epd2.HEIGHT == 264) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 176, 264, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps240x416()
#if !defined(__AVR)
    Bitmap240x416_1, Bitmap240x416_2, Bitmap240x416_3
#else
    Bitmap240x460_1, Bitmap240x460_2, Bitmap240x460_3
#endif
  if ((display.epd2.WIDTH == 240) && (display.epd2.HEIGHT == 416) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 240, 416, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps400x300()
#if !defined(__AVR)
    Bitmap400x300_1, Bitmap400x300_2
#else
  const unsigned char* bitmaps[] = {}; // not enough code space
#endif
  if ((display.epd2.WIDTH == 400) && (display.epd2.HEIGHT == 300) && !display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 400, 300, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps640x384()
#if !defined(__AVR)
    Bitmap640x384_1, Bitmap640x384_2
#else
#endif
  if ((display.epd2.WIDTH == 640) && (display.epd2.HEIGHT == 384))
      do
        display.drawInvertedBitmap(0, 0, bitmaps[i], 640, 384, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps648x480()
#if !defined(__AVR)
    Bitmap648x480_1, Bitmap648x480_2, Bitmap648x480_3
#else
#endif
  if ((display.epd2.WIDTH == 648) && (display.epd2.HEIGHT == 480) && !display.epd2.hasColor)
      do
        display.drawBitmap(0, 0, bitmaps[i], 648, 480, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps800x480()
#if !defined(__AVR)
    Bitmap800x480_1, Bitmap800x480_2, Bitmap800x480_3, Bitmap800x480_4
#else
#endif
  if ((display.epd2.WIDTH == 800) && (display.epd2.HEIGHT == 480))
      do
        display.drawBitmap(0, 0, bitmaps[i], 800, 480, GxEPD_BLACK);
      delay(2000);
    if ((display.epd2.panel == GxEPD2::GDEW075T7) || (display.epd2.panel == GxEPD2::GDEY075T7))
      // avoid ghosting caused by OTP waveform
      display.refresh(false); // full update
#endif
void drawBitmaps800x600()
  if ((display.epd2.panel == GxEPD2::ED060SCT) || (display.epd2.panel == GxEPD2::ED060KC1) || (display.epd2.panel == GxEPD2::ED078KC2))
    //    Serial.print("sizeof(WS_zoo_800x600) is "); Serial.println(sizeof(WS_zoo_800x600));
    display.drawNative(WS_zoo_800x600, 0, 0, 0, 800, 600, false, false, true);
    delay(2000);
    //    Serial.print("sizeof(WS_pic_1200x825) is "); Serial.println(sizeof(WS_pic_1200x825));
    //    display.drawNative((const uint8_t*)WS_pic_1200x825, 0, 0, 0, 1200, 825, false, false, true);
    //    delay(2000);
    //    Serial.print("sizeof(WS_acaa_1024x731) is "); Serial.println(sizeof(WS_acaa_1024x731));
    //    display.drawNative(WS_acaa_1024x731, 0, 0, 0, 1024, 731, false, false, true);
    //    delay(2000);
#endif
#endif
void drawBitmaps1304x984()
  if (display.epd2.panel == GxEPD2::GDEW1248T3)
    display.drawImage(Bitmap1304x984, 0, 0, display.epd2.WIDTH, display.epd2.HEIGHT, false, false, true);
#endif
struct bitmap_pair
  const unsigned char* black;
  const unsigned char* red;
void drawBitmaps3c200x200()
  bitmap_pair bitmap_pairs[] =
    //{Bitmap3c200x200_black, Bitmap3c200x200_red},
    {WS_Bitmap3c200x200_black, WS_Bitmap3c200x200_red}
  if (display.epd2.panel == GxEPD2::GDEW0154Z04)
    do
      // Bitmap3c200x200_black has 2 bits per pixel
      // taken from Adafruit_GFX.cpp, modified
      int16_t byteWidth = (display.epd2.WIDTH + 7) / 8; // Bitmap scanline pad = whole byte
      uint8_t byte = 0;
      for (int16_t j = 0; j < display.epd2.HEIGHT; j++)
        for (int16_t i = 0; i < display.epd2.WIDTH; i++)
          if (i & 3) byte <<= 2;
#if defined(__AVR) || defined(ESP8266) || defined(ESP32)
            byte = pgm_read_byte(&Bitmap3c200x200_black[j * byteWidth * 2 + i / 4]);
#else
            byte = Bitmap3c200x200_black[j * byteWidth * 2 + i / 4];
#endif
          if (!(byte & 0x80))
            display.drawPixel(i, j, GxEPD_BLACK);
      display.drawInvertedBitmap(0, 0, Bitmap3c200x200_red, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_RED);
    delay(2000);
    for (uint16_t i = 0; i < sizeof(bitmap_pairs) / sizeof(bitmap_pair); i++)
      do
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].black, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_BLACK);
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_RED);
      delay(2000);
      display.drawImage(bitmap_pairs[i].black, bitmap_pairs[i].red, x, y, 200, 200, false, false, true);
      delay(2000);
      int16_t x = -60;
      int16_t y = -60;
        display.writeImage(bitmap_pairs[i].black, bitmap_pairs[i].red, x, y, 200, 200, false, false, true);
        display.refresh();
    display.writeImage(bitmap_pairs[0].black, bitmap_pairs[0].red, 0, 0, 200, 200, false, false, true);
    display.writeImage(bitmap_pairs[0].black, bitmap_pairs[0].red, int16_t(display.epd2.WIDTH) - 200, int16_t(display.epd2.HEIGHT) - 200, 200, 200, false, false, true);
    display.refresh();
    delay(2000);
#endif
void drawBitmaps3c104x212()
#if !defined(__AVR)
    {Bitmap3c104x212_1_black, Bitmap3c104x212_1_red},
    {Bitmap3c104x212_2_black, Bitmap3c104x212_2_red},
    {WS_Bitmap3c104x212_black, WS_Bitmap3c104x212_red}
#else
    //{Bitmap3c104x212_2_black, Bitmap3c104x212_2_red},
#endif
  if (display.epd2.panel == GxEPD2::GDEW0213Z16)
      do
        if (bitmap_pairs[i].red == WS_Bitmap3c104x212_red)
        else display.drawBitmap(0, 0, bitmap_pairs[i].red, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c128x250()
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 250) && display.epd2.hasColor)
    bool mirrored = display.mirror(true);
    do
      display.drawInvertedBitmap(0, 0, Bitmap3c128x250_1_black, 128, 250, GxEPD_BLACK);
      display.drawInvertedBitmap(0, 0, Bitmap3c128x250_1_red, 128, 250, GxEPD_RED);
    delay(2000);
#if !defined(__AVR)
    do
      display.drawInvertedBitmap(0, 0, Bitmap3c128x250_2_black, 128, 250, GxEPD_BLACK);
      display.drawBitmap(0, 0, Bitmap3c128x250_2_red, 128, 250, GxEPD_RED);
    delay(2000);
#endif
    display.mirror(mirrored);
#endif
void drawBitmaps3c128x296()
#if !defined(__AVR)
    {Bitmap3c128x296_1_black, Bitmap3c128x296_1_red},
    {Bitmap3c128x296_2_black, Bitmap3c128x296_2_red},
    {WS_Bitmap3c128x296_black, WS_Bitmap3c128x296_red}
#else
    //{Bitmap3c128x296_1_black, Bitmap3c128x296_1_red},
    //{Bitmap3c128x296_2_black, Bitmap3c128x296_2_red},
#endif
  if ((display.epd2.WIDTH == 128) && (display.epd2.HEIGHT == 296) && display.epd2.hasColor)
      do
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].black, 128, 296, GxEPD_BLACK);
        if (bitmap_pairs[i].red == WS_Bitmap3c128x296_red)
          display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, 128, 296, GxEPD_RED);
        else display.drawBitmap(0, 0, bitmap_pairs[i].red, 128, 296, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c152x296()
    {Bitmap3c152x296_black, Bitmap3c152x296_red}
  if (display.epd2.panel == GxEPD2::GDEY0266Z90)
      do
        display.drawBitmap(0, 0, bitmap_pairs[i].black, 152, 296, GxEPD_BLACK);
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, 152, 296, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c176x264()
    {Bitmap3c176x264_black, Bitmap3c176x264_red}
  if (display.epd2.panel == GxEPD2::GDEW027C44)
      do
        display.drawBitmap(0, 0, bitmap_pairs[i].black, display.epd2.WIDTH, display.epd2.HEIGHT, GxEPD_BLACK);
      delay(2000);
#endif
void drawBitmaps3c400x300()
#if !defined(__AVR)
    {Bitmap3c400x300_1_black, Bitmap3c400x300_1_red},
    {Bitmap3c400x300_2_black, Bitmap3c400x300_2_red},
    {WS_Bitmap3c400x300_black, WS_Bitmap3c400x300_red}
#else
  bitmap_pair bitmap_pairs[] = {}; // not enough code space
#endif
  if (display.epd2.panel == GxEPD2::GDEW042Z15)
      do
      delay(2000);
#endif
void drawBitmaps3c648x480()
#if !defined(__AVR)
    {Bitmap3c648x480_black, Bitmap3c648x480_red}
#else
#endif
  if (display.epd2.panel == GxEPD2::GDEW0583Z83)
      do
        display.drawBitmap(0, 0, bitmap_pairs[i].black, 648, 480, GxEPD_BLACK);
        display.drawBitmap(0, 0, bitmap_pairs[i].red, 648, 480, GxEPD_RED);
      delay(2000);
#endif
void drawBitmaps3c800x480()
#if !defined(__AVR)
    {Bitmap3c800x480_1_black, Bitmap3c800x480_1_red}
#else
#endif
  if (display.epd2.panel == GxEPD2::GDEW075Z08)
      do
      delay(2000);
#endif
void drawBitmaps3c880x528()
#if !defined(__AVR)
    {Bitmap3c880x528_black, Bitmap3c880x528_red}
#else
#endif
  if (display.epd2.panel == GxEPD2::GDEH075Z90)
      do
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].black, 880, 528, GxEPD_BLACK);
        display.drawInvertedBitmap(0, 0, bitmap_pairs[i].red, 880, 528, GxEPD_RED);
      delay(2000);
    display.mirror(m);
#endif
void drawBitmaps3c1304x984()
  if (display.epd2.panel == GxEPD2::GDEY1248Z51)
    //display.drawImage(Bitmap3c1304x984_black, Bitmap3c1304x984_red, 0, 0, 1304, 984, false, false, true);
    display.writeImage(0, Bitmap3c1304x984_red, 0, 0, 1304, 984, true, false, true); // red bitmap is inverted
    display.drawImage(Bitmap3c1304x984_black, 0, 0, 0, 1304, 984, true, false, true); // black bitmap is normal
#endif
void drawBitmaps4c168x168()
  if (display.epd2.panel == GxEPD2::Waveshare437inch4color)
    display.drawNative(WS_Bitmap4c168x168, 0, (display.epd2.WIDTH - 168) / 2, (display.epd2.HEIGHT - 168) / 2, 168, 168, false, false, true);
    delay(5000);
#endif
void drawBitmaps7c192x143()
  if (display.epd2.panel == GxEPD2::ACeP565)
    display.drawNative(WS_Bitmap7c192x143, 0, (display.epd2.WIDTH - 192) / 2, (display.epd2.HEIGHT - 143) / 2, 192, 143, false, false, true);
    delay(5000);
#endif
void drawBitmaps7c800x480()
  if (display.epd2.panel == GxEPD2::GDEY073D46)
    display.epd2.drawDemoBitmap(Bitmap7c800x480, 0, 0, 0, 800, 480, 0, false, true); // special format
    delay(5000);
#endif
void drawBitmaps7c300x180()
    display.drawNative(WS_Bitmap7c300x180, 0, (display.epd2.WIDTH - 300) / 2, (display.epd2.HEIGHT - 180) / 2, 300, 180, false, false, true);
    delay(5000);
#endif
void draw7colors()
  uint16_t h = display.height() / 7;
  do
    display.fillRect(0, 0, display.width(), h, GxEPD_BLACK);
    display.fillRect(0, h, display.width(), h, GxEPD_WHITE);
    display.fillRect(0, 2 * h, display.width(), h, GxEPD_GREEN);
    display.fillRect(0, 3 * h, display.width(), h, GxEPD_BLUE);
    display.fillRect(0, 4 * h, display.width(), h, GxEPD_RED);
    display.fillRect(0, 5 * h, display.width(), h, GxEPD_YELLOW);
    display.fillRect(0, 6 * h, display.width(), h, GxEPD_ORANGE);
void draw7colorlines()
  uint16_t h = 2;
  do
    uint16_t y = 0;
    do
      display.fillRect(0, y, display.width(), h, GxEPD_BLACK); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_WHITE); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_GREEN); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_BLUE); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_RED); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_YELLOW); y += h;
      display.fillRect(0, y, display.width(), h, GxEPD_ORANGE); y += h;
    while ((y + 12 * h) < uint16_t(display.height()));
    //display.drawPixel(0, y, GxEPD_BLACK); display.drawPixel(10, y, GxEPD_GREEN);
    //display.drawPixel(20, y, GxEPD_BLUE); display.drawPixel(30, y, GxEPD_RED);
    //display.drawPixel(40, y, GxEPD_YELLOW); display.drawPixel(50, y, GxEPD_ORANGE);
    display.fillRect(0, y, 2, 2, GxEPD_BLACK); display.fillRect(10, y, 2, 2, GxEPD_GREEN);
    display.fillRect(20, y, 2, 2, GxEPD_BLUE); display.fillRect(30, y, 2, 2, GxEPD_RED);
    display.fillRect(40, y, 2, 2, GxEPD_YELLOW); display.fillRect(50, y, 2, 2, GxEPD_ORANGE);
void drawGraphics()
  do
    display.drawRect(display.width() / 8, display.height() / 8, display.width() * 3 / 4, display.height() * 3 / 4, GxEPD_BLACK);
    display.drawLine(display.width() / 8, display.height() / 8, display.width() * 7 / 8, display.height() * 7 / 8, GxEPD_BLACK);
    display.drawLine(display.width() / 8, display.height() * 7 / 8, display.width() *7 / 8, display.height() / 8, GxEPD_BLACK);
    display.drawCircle(display.width() / 2, display.height() / 2, display.height() / 4, GxEPD_BLACK);
    display.drawPixel(display.width() / 4, display.height() / 2 , GxEPD_BLACK);
    display.drawPixel(display.width() * 3 / 4, display.height() / 2 , GxEPD_BLACK);
// NOTE: you may need to adapt or select for your wiring in the processor specific conditional compile sections below
// select the display class (only one), matching the kind of display panel
#define GxEPD2_DISPLAY_CLASS GxEPD2_BW
//#define GxEPD2_DISPLAY_CLASS GxEPD2_3C
//#define GxEPD2_DISPLAY_CLASS GxEPD2_4C
//#define GxEPD2_DISPLAY_CLASS GxEPD2_7C
// select the display driver class (only one) for your  panel
//#define GxEPD2_DRIVER_CLASS GxEPD2_102     // GDEW0102T4   80x128, UC8175, (WFT0102CZA2)
//#define GxEPD2_DRIVER_CLASS GxEPD2_150_BN  // DEPG0150BN 200x200, SSD1681, (FPC8101), TTGO T5 V2.4.1
//#define GxEPD2_DRIVER_CLASS GxEPD2_154     // GDEP015OC1  200x200, IL3829, (WFC0000CZ07), no longer available
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_D67 // GDEH0154D67 200x200, SSD1681, (HINK-E154A07-A1)
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_T8  // GDEW0154T8  152x152, UC8151 (IL0373), (WFT0154CZ17)
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_M09 // GDEW0154M09 200x200, JD79653A, (WFT0154CZB3)
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_M10 // GDEW0154M10 152x152, UC8151D, (WFT0154CZ17)
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_GDEY0154D67 // GDEY0154D67 200x200, SSD1681, (FPC-B001 20.05.21)
//#define GxEPD2_DRIVER_CLASS GxEPD2_213     // GDE0213B1   122x250, IL3895, (HINK-E0213-G01), phased out
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_B72 // GDEH0213B72 122x250, SSD1675A (IL3897), (HINK-E0213A22-A0 SLH1852)
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_B73 // GDEH0213B73 122x250, SSD1675B, (HINK-E0213A22-A0 SLH1914)
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_B74 // GDEM0213B74 122x250, SSD1680, FPC-7528B)
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_flex // GDEW0213I5F 104x212, UC8151 (IL0373), (WFT0213CZ16)
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_M21 // GDEW0213M21 104x212, UC8151 (IL0373), (WFT0213CZ16)
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_T5D // GDEW0213T5D 104x212, UC8151D, (WFT0213CZ16)
#define GxEPD2_DRIVER_CLASS GxEPD2_213_BN // DEPG0213BN  122x250, SSD1680, (FPC-7528B), TTGO T5 V2.4.1, V2.3.1
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_GDEY0213B74 // GDEY0213B74 122x250, SSD1680, (FPC-A002 20.04.08)
//#define GxEPD2_DRIVER_CLASS GxEPD2_260     // GDEW026T0   152x296, UC8151 (IL0373), (WFT0154CZ17)
//#define GxEPD2_DRIVER_CLASS GxEPD2_260_M01 // GDEW026M01  152x296, UC8151 (IL0373), (WFT0260CZB2)
//#define GxEPD2_DRIVER_CLASS GxEPD2_266_BN // DEPG0266BN   152x296, SSD1680, (FPC7510), TTGO T5 V2.66, TTGO T5 V2.4.1
//#define GxEPD2_DRIVER_CLASS GxEPD2_266_GDEY0266T90 // GDEY0266T90 152x296, SSD1680, (FPC-A003 HB)
//#define GxEPD2_DRIVER_CLASS GxEPD2_270     // GDEW027W3   176x264, EK79652 (IL91874), (WFI0190CZ22)
//#define GxEPD2_DRIVER_CLASS GxEPD2_270_GDEY027T91 // GDEY027T91 176x264, SSD1680, (FB)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290     // GDEH029A1   128x296, SSD1608 (IL3820), (E029A01-FPC-A1 SYX1553)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_T5  // GDEW029T5   128x296, UC8151 (IL0373), (WFT0290CZ10)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_T5D // GDEW029T5D  128x296, UC8151D, (WFT0290CZ10)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_I6FD // GDEW029I6FD  128x296, UC8151D, (WFT0290CZ10)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_T94 // GDEM029T94  128x296, SSD1680, (FPC-7519 rev.b)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_T94_V2 // GDEM029T94  128x296, SSD1680, (FPC-7519 rev.b), Waveshare 2.9" V2 variant
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_BS // DEPG0290BS  128x296, SSD1680, (FPC-7519 rev.b)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_M06 // GDEW029M06  128x296, UC8151D, (WFT0290CZ10)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_GDEY029T94 // GDEY029T94 128x296, SSD1680, (FPC-A005 20.06.15)
//#define GxEPD2_DRIVER_CLASS GxEPD2_371     // GDEW0371W7  240x416, UC8171 (IL0324), (missing)
//#define GxEPD2_DRIVER_CLASS GxEPD2_370_TC1 // ED037TC1  280x480, SSD1677, (ICA-FU-20 ichia 2029), Waveshare 3.7"
//#define GxEPD2_DRIVER_CLASS GxEPD2_420     // GDEW042T2   400x300, UC8176 (IL0398), (WFT042CZ15)
//#define GxEPD2_DRIVER_CLASS GxEPD2_420_M01 // GDEW042M01  400x300, UC8176 (IL0398), (WFT042CZ15)
//#define GxEPD2_DRIVER_CLASS GxEPD2_420_GDEY042T91 // GDEY042T91 400x300, SSD1683 (no inking)
//#define GxEPD2_DRIVER_CLASS GxEPD2_583     // GDEW0583T7  600x448, UC8159c (IL0371), (missing)
//#define GxEPD2_DRIVER_CLASS GxEPD2_583_T8  // GDEW0583T8  648x480, EK79655 (GD7965), (WFT0583CZ61)
//#define GxEPD2_DRIVER_CLASS GxEPD2_583_GDEQ0583T31 // GDEQ0583T31  648x480, UC8179, (P583010-MF1-B)
//#define GxEPD2_DRIVER_CLASS GxEPD2_750     // GDEW075T8   640x384, UC8159c (IL0371), (WF0583CZ09)
//#define GxEPD2_DRIVER_CLASS GxEPD2_750_T7  // GDEW075T7   800x480, EK79655 (GD7965), (WFT0583CZ61)
//#define GxEPD2_DRIVER_CLASS GxEPD2_750_YT7  // GDEY075T7  800x480, UC8179 (GD7965), (FPC-C001 20.8.20)
//#define GxEPD2_DRIVER_CLASS GxEPD2_1160_T91 // GDEH116T91 960x640, SSD1677, (none or hidden)
//#define GxEPD2_DRIVER_CLASS GxEPD2_1248     // GDEW1248T3 1304x984, UC8179, (WFT1248BZ23,WFT1248BZ24)
// 3-color e-papers
//#define GxEPD2_DRIVER_CLASS GxEPD2_154c     // GDEW0154Z04 200x200, IL0376F, (WFT0000CZ04), no longer available
//#define GxEPD2_DRIVER_CLASS GxEPD2_154_Z90c // GDEH0154Z90 200x200, SSD1681, (HINK-E154A07-A1)
//#define GxEPD2_DRIVER_CLASS GxEPD2_213c     // GDEW0213Z16 104x212, UC8151 (IL0373), (WFT0213CZ16)
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_Z19c // GDEH0213Z19 104x212, UC8151D, (HINK-E0213A20-A2 2020-11-19)
//#define GxEPD2_DRIVER_CLASS GxEPD2_213_Z98c // GDEY0213Z98 122x250, SSD1680, (FPC-A002 20.04.08)
//#define GxEPD2_DRIVER_CLASS GxEPD2_266c     // GDEY0266Z90 152x296, SSD1680, (FPC-7510)
//#define GxEPD2_DRIVER_CLASS GxEPD2_270c     // GDEW027C44  176x264, IL91874, (WFI0190CZ22)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290c     // GDEW029Z10  128x296, UC8151 (IL0373), (WFT0290CZ10)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_Z13c // GDEH029Z13  128x296, UC8151D, (HINK-E029A10-A3 20160809)
//#define GxEPD2_DRIVER_CLASS GxEPD2_290_C90c // GDEM029C90  128x296, SSD1680, (FPC-7519 rev.b)
//#define GxEPD2_DRIVER_CLASS GxEPD2_420c     // GDEW042Z15  400x300, UC8176 (IL0398), (WFT0420CZ15)
//#define GxEPD2_DRIVER_CLASS GxEPD2_420c_Z21 // GDEQ042Z21  400x300, UC8276, (hidden)
//#define GxEPD2_DRIVER_CLASS GxEPD2_583c     // GDEW0583Z21 600x448, UC8159c (IL0371), (missing)
//#define GxEPD2_DRIVER_CLASS GxEPD2_583c_Z83 // GDEW0583Z83 648x480, EK79655 (GD7965), (WFT0583CZ61)
//#define GxEPD2_DRIVER_CLASS GxEPD2_750c     // GDEW075Z09  640x384, UC8159c (IL0371), (WF0583CZ09)
//#define GxEPD2_DRIVER_CLASS GxEPD2_750c_Z08 // GDEW075Z08  800x480, EK79655 (GD7965), (WFT0583CZ61)
//#define GxEPD2_DRIVER_CLASS GxEPD2_750c_Z90 // GDEH075Z90  880x528, SSD1677, (HINK-E075A07-A0)
//#define GxEPD2_DRIVER_CLASS GxEPD2_1248c    // GDEY1248Z51 1304x984, UC8179, (WFT1248BZ23,WFT1248BZ24)
// 4-color e-paper
//#define GxEPD2_DRIVER_CLASS GxEPD2_437c     // Waveshare 4.37" 4-color
// 7-color e-paper
//#define GxEPD2_DRIVER_CLASS GxEPD2_565c // Waveshare 5.65" 7-color
//#define GxEPD2_DRIVER_CLASS GxEPD2_730c_GDEY073D46 // GDEY073D46 800x480 7-color, (N-FPC-001 2021.11.26)
// grey levels parallel IF e-papers on Waveshare e-Paper IT8951 Driver HAT
//#define GxEPD2_DRIVER_CLASS GxEPD2_it60           // ED060SCT 800x600
//#define GxEPD2_DRIVER_CLASS GxEPD2_it60_1448x1072 // ED060KC1 1448x1072
//#define GxEPD2_DRIVER_CLASS GxEPD2_it78_1872x1404 // ED078KC2 1872x1404
//#define GxEPD2_DRIVER_CLASS GxEPD2_it103_1872x1404 // ES103TC1 1872x1404
// SS is usually used for CS. define here for easy change
#ifndef EPD_CS
#define EPD_CS SS
#endif
#if defined(GxEPD2_DISPLAY_CLASS) && defined(GxEPD2_DRIVER_CLASS)
// somehow there should be an easier way to do this
#define GxEPD2_BW_IS_GxEPD2_BW true
#define GxEPD2_3C_IS_GxEPD2_3C true
#define GxEPD2_4C_IS_GxEPD2_4C true
#define GxEPD2_7C_IS_GxEPD2_7C true
#define GxEPD2_1248_IS_GxEPD2_1248 true
#define GxEPD2_1248c_IS_GxEPD2_1248c true
#define IS_GxEPD(c, x) (c##x)
#define IS_GxEPD2_BW(x) IS_GxEPD(GxEPD2_BW_IS_, x)
#define IS_GxEPD2_3C(x) IS_GxEPD(GxEPD2_3C_IS_, x)
#define IS_GxEPD2_4C(x) IS_GxEPD(GxEPD2_4C_IS_, x)
#define IS_GxEPD2_7C(x) IS_GxEPD(GxEPD2_7C_IS_, x)
#define IS_GxEPD2_1248(x) IS_GxEPD(GxEPD2_1248_IS_, x)
#define IS_GxEPD2_1248c(x) IS_GxEPD(GxEPD2_1248c_IS_, x)
#include "GxEPD2_selection_check.h"
#if defined (ESP8266)
#define MAX_DISPLAY_BUFFER_SIZE (81920ul-34000ul-5000ul) // ~34000 base use, change 5000 to your application use
#if IS_GxEPD2_BW(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8) ? EPD::HEIGHT : MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8))
#elif IS_GxEPD2_3C(GxEPD2_DISPLAY_CLASS) || IS_GxEPD2_4C(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= (MAX_DISPLAY_BUFFER_SIZE / 2) / (EPD::WIDTH / 8) ? EPD::HEIGHT : (MAX_DISPLAY_BUFFER_SIZE / 2) / (EPD::WIDTH / 8))
#elif IS_GxEPD2_7C(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= (MAX_DISPLAY_BUFFER_SIZE) / (EPD::WIDTH / 2) ? EPD::HEIGHT : (MAX_DISPLAY_BUFFER_SIZE) / (EPD::WIDTH / 2))
#endif
// adapt the constructor parameters to your wiring
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=D8*/ EPD_CS, /*DC=D3*/ 0, /*RST=D4*/ 2, /*BUSY=D2*/ 4));
// mapping of Waveshare e-Paper ESP8266 Driver Board, new version
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=15*/ EPD_CS, /*DC=4*/ 4, /*RST=2*/ 2, /*BUSY=5*/ 5));
// mapping of Waveshare e-Paper ESP8266 Driver Board, old version
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=15*/ EPD_CS, /*DC=4*/ 4, /*RST=5*/ 5, /*BUSY=16*/ 16));
#undef MAX_DISPLAY_BUFFER_SIZE
#undef MAX_HEIGHT
#endif
#if defined(ESP32)
#define MAX_DISPLAY_BUFFER_SIZE 65536ul // e.g.
#endif
#if !IS_GxEPD2_1248(GxEPD2_DRIVER_CLASS) && !IS_GxEPD2_1248c(GxEPD2_DRIVER_CLASS)
#if defined(ARDUINO_LOLIN_D32_PRO)
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 0, /*RST=*/ 2, /*BUSY=*/ 15)); // my LOLIN_D32_PRO proto board
#else
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 17, /*RST=*/ 16, /*BUSY=*/ 4)); // my suggested wiring and proto board
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ 5, /*DC=*/ 17, /*RST=*/ 16, /*BUSY=*/ 4)); // LILYGO_T5_V2.4.1
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 19, /*RST=*/ 4, /*BUSY=*/ 34)); // LILYGO® TTGO T5 2.66
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 2, /*RST=*/ 0, /*BUSY=*/ 4)); // e.g. TTGO T8 ESP32-WROVER
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 15, /*DC=*/ 27, /*RST=*/ 26, /*BUSY=*/ 25)); // Waveshare ESP32 Driver Board
#endif
#else // GxEPD2_1248 or GxEPD2_1248c
// Waveshare 12.48 b/w or b/w/r SPI display board and frame or Good Display 12.48 b/w panel GDEW1248T3 or b/w/r panel GDEY1248Z51
// general constructor for use with all parameters, e.g. for Waveshare ESP32 driver board mounted on connection board
GxEPD2_DISPLAY_CLASS < GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS) > display(GxEPD2_DRIVER_CLASS(/*sck=*/ 13, /*miso=*/ 12, /*mosi=*/ 14,
    /*cs_m1=*/ 23, /*cs_s1=*/ 22, /*cs_m2=*/ 16, /*cs_s2=*/ 19,
    /*dc1=*/ 25, /*dc2=*/ 17, /*rst1=*/ 33, /*rst2=*/ 5,
    /*busy_m1=*/ 32, /*busy_s1=*/ 26, /*busy_m2=*/ 18, /*busy_s2=*/ 4));
#endif
#undef MAX_HEIGHT
#endif
// can't use package "STMF1 Boards (STM32Duino.com)" (Roger Clark) anymore with Adafruit_GFX, use "STM32 Boards (selected from submenu)" (STMicroelectronics)
#if defined(ARDUINO_ARCH_STM32)
#define MAX_DISPLAY_BUFFER_SIZE 15000ul // ~15k is a good compromise
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=PA4*/ EPD_CS, /*DC=*/ PA3, /*RST=*/ PA2, /*BUSY=*/ PA1));
#undef MAX_HEIGHT
#endif
#if defined(__AVR)
#if defined (ARDUINO_AVR_MEGA2560) // Note: SS is on 53 on MEGA
#define MAX_DISPLAY_BUFFER_SIZE 5000 // e.g. full height for 200x200
#else // Note: SS is on 10 on UNO, NANO
#define MAX_DISPLAY_BUFFER_SIZE 800 //
#endif
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ EPD_CS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
// for Arduino Micro or Arduino Leonardo with CS on 10 on my proto boards (SS would be 17) uncomment instead:
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 10, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
#endif
#if defined(ARDUINO_ARCH_SAM)
#define MAX_DISPLAY_BUFFER_SIZE 32768ul // e.g., up to 96k
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=10*/ EPD_CS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
#undef MAX_HEIGHT
#endif
#if defined(ARDUINO_ARCH_SAMD)
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=4*/ 4, /*DC=*/ 7, /*RST=*/ 6, /*BUSY=*/ 5));
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=4*/ 4, /*DC=*/ 3, /*RST=*/ 2, /*BUSY=*/ 1)); // my Seed XIOA0
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=4*/ 3, /*DC=*/ 2, /*RST=*/ 1, /*BUSY=*/ 0)); // my other Seed XIOA0
#undef MAX_HEIGHT
#endif
#if defined(ARDUINO_ARCH_RP2040)
#define MAX_DISPLAY_BUFFER_SIZE 131072ul // e.g. half of available ram
#endif
#if defined(ARDUINO_NANO_RP2040_CONNECT)
#endif
#if defined(ARDUINO_RASPBERRY_PI_PICO)
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ EPD_CS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7)); // my proto board
// mapping of GoodDisplay DESPI-PICO. NOTE: uses alternate HW SPI pins!
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 9, /*DC=*/ 8, /*RST=*/ 12, /*BUSY=*/ 13)); // DESPI-PICO
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 3, /*DC=*/ 2, /*RST=*/ 11, /*BUSY=*/ 10)); // DESPI-PICO modified
#endif
#undef MAX_HEIGHT
#endif
#endif
I forgot that I had modified it. I extended the _busy_timeout to 20,000,000, but it proved to be ineffective. As I mentioned earlier, the display appears to be stuck in a busy state. Regardless of how long the _busy_timeout is set, the display remains unresponsive.
You could have reported you use a board package from the
Unofficial-list-of-3rd-party-boards-support-urls
Raspberry Pi RP2040 Boards: https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json
I don't have a Raspberry Pico W, so I don't have installed this package; I use the official MBED RP2040 package.
Try use a 1k pull-up on the RST line of you Waveshare board with the "clever" reset circuit.
I've experimented with Arduino Mbed OS, but it only supports one SPI channel. However, I made an interesting discovery today.
I compared the WaveShare library EPD_2in13_V3.c with your library GxEPD2_213_BN.cpp. It turns out that in GxEPD2_213_BN::_InitDisplay(), the display is reset only when _hibernating is True. So, I decided to remove the if condition and run some tests. To my surprise, the display started working!
As I delved deeper into the issue, I noticed that _reset() is already called in GxEPD2_EPD::init. Therefore, there seems to be no need to call _reset() in GxEPD2_213_BN::_InitDisplay().
I decided to conduct another test. I reinstated the if condition in GxEPD2_213_BN::_InitDisplay() and moved _reset() behind _pSPIx->begin() in GxEPD2_EPD::init. Interestingly, the display worked well with this setup too.
It appears that there might be something amiss in _pSPIx->begin(), but I'm uncertain about the exact reason.
GxEPD2_213_BN.cpp
  _writeCommand(0x01); //Driver output control
EPD_2in13_V3.c
void EPD_2in13_V3_Init(void)
	EPD_2in13_V3_Reset();
	DEV_Delay_ms(100);
	EPD_2in13_V3_ReadBusy();
	EPD_2in13_V3_SendCommand(0x12);  //SWRESET
	EPD_2in13_V3_SendCommand(0x01); //Driver output control
	EPD_2in13_V3_SendData(0xf9);
	EPD_2in13_V3_SendData(0x00);
It seems like the issue has been resolved, although I don't quite understand why. I hope my discovery can be helpful to others, and I greatly appreciate your help.
It only has one global SPI channel instance. But you can use the other channel, as shown in GxEPD2_Example.ino.
It causes a delay, I think.
Your findings may look interesting. But I think you just introduce some delay, that helps to cope with the "clever" reset circuit. Did you try with the pull-up on RST?
https://files.waveshare.com/upload/1/1c/Pico-ePaper-2.13.pdf
i have tried. but the whole board will be stuck. even the com port on pc disappeared. i don’t have debug probe. so i don’t know what happened.
i have very few hardware knowledge . :joy:
the pico-paper-2.13 display is designed for raspberry pi pico. i cannot make any hardware modification.
but i don’t think it just introduce some delay.
i can do more test by add more or few delay and see what will happen.
Made sure all pins in the constructor belong to the same SPI channel?
But I don't care which package you use. I just wondered where these strange methods come from.
I will check it and make update tomorrow.
It's already late at night here. :night_with_stars:
which methods?
post #2
I modified the SPI pin definitions to ensure they belong to the same SPI channel, but the display still didn't work. I even removed the if condition and moved _reset behind _pSPIx->begin(). The Pico board appears to become unresponsive after the _writeCommand(0x12) call.
I purchased a Pico debug probe, but unfortunately, I discovered that the Raspberry Pi Pico doesn't support debugging under Arduino Mbed OS.
#define SPI_MISO 14
#define SPI_MOSI 11
#define SPI_SCK 10
  // init serial
  delay(15000);
  // init spi
  MbedSPI SPI(SPI_MISO,SPI_MOSI,SPI_SCK);
  display.epd2.selectSPI(SPI, SPISettings(4000000, MSBFIRST, SPI_MODE0));
  // init display
  helloWorld();
works well : Add 5s delay after _reset
  //_reset(); //original
  if (_busy >= 0)
    pinMode(_busy, INPUT);
  _pSPIx->begin();
  _reset();
  delay(5000); //add some delay
works well : Add a 5s delay after _reset() and another 5s delay before _reset()
  if (_busy >= 0)
  _pSPIx->begin();
  _reset();
not work (Busy Timeout!) : remove all of the delay and move _reset before _pSPIx->begin();
  if (_busy >= 0)
  _reset();
  _pSPIx->begin();
not work (Busy Timeout!) : add 5s delay before _pSPIx->begin();
  if (_busy >= 0)
  _reset();
  _pSPIx->begin();
not work (Busy Timeout!) : add another 5s delay after _pSPIx->begin();
  if (_busy >= 0)
  _reset();
  _pSPIx->begin();
GxEPD2_EPD.cpp of GxEPD2 release up to 1.5.2 doesn't work as intended on RP2040 (and maybe other processors, too).
Please download and replace this file, if you encounter this issue, until it is fixed in next release.
-jz-
