GxEPD2 with Waveshare 5.79” (GDEY0579T93) on Raspberry Pi Pico – Display stays blank
I'm trying to get the Waveshare 5.79" e-paper display (black & white, SPI) working with a Raspberry Pi Pico using the GxEPD2 library. The display remains blank during updates as I'm trying to run the HelloWorld example.
I see serial output and _Update_Full debug logs from the library, which suggests communication with the display driver is happening, but nothing appears on the screen.
Display Details
  • Module: Waveshare 5.79" e-Paper Display Module
  • Panel: GDEY0579T93
  • Resolution: 792×272
  • Controller: SSD1683
  • Interface: SPI
  • Voltage: 3.3V logic and power
Wiring
Using hardware SPI (SPI0) on the Pico, using suggested wiring from wiring examples:
Display Pin Pico GPIO
VCC 3V3
GND GND
DIN (MOSI) GP3
CLK (SCK) GP2
CS GP5
DC GP8
RST GP9
BUSY GP7
GxEPD2 Settings
In GxEPD2_display_selection_new_style.h:
#define GxEPD2_DISPLAY_CLASS GxEPD2_BW
#define GxEPD2_DRIVER_CLASS GxEPD2_579_GDEY0579T93
And for the Pico, the constructor is:
#if defined(ARDUINO_RASPBERRY_PI_PICO)
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)>
  display(GxEPD2_DRIVER_CLASS(/*CS=*/ 5, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
#endif
Serial output looks like this:
Serial is ready
startting setup
before init
after init
_Update_Full : 5
_Update_Full : 4009
0 test
_Update_Full : 1
1 test
_Update_Full : 2002
2 test
_Update_Full : 11011
Full sketch that I'm running:
#include <GxEPD2_BW.h>
#include <GxEPD2_3C.h>
#include <GxEPD2_4C.h>
#include <GxEPD2_7C.h>
#include <Fonts/FreeMonoBold9pt7b.h>
// select the display class and display driver class in the following file (new style):
#include "GxEPD2_display_selection_new_style.h"
// or select the display constructor line in one of the following files (old style):
//#include "GxEPD2_display_selection.h"
//#include "GxEPD2_display_selection_added.h"
// alternately you can copy the constructor from GxEPD2_display_selection.h or GxEPD2_display_selection_added.h to here
// e.g. for Wemos D1 mini:
//GxEPD2_BW<GxEPD2_154_D67, GxEPD2_154_D67::HEIGHT> display(GxEPD2_154_D67(/*CS=D8*/ SS, /*DC=D3*/ 0, /*RST=D4*/ 2, /*BUSY=D2*/ 4)); // GDEH0154D67
// for handling alternative SPI pins (ESP32, RP2040) see example GxEPD2_Example.ino
#ifndef ARDUINO_RASPBERRY_PI_PICO
#error "Incorrect board selected; please choose 'Raspberry Pi Pico' in the Arduino IDE."
#endif
//#if defined(ARDUINO_RASPBERRY_PI_PICO) || defined(ARDUINO_RASPBERRY_PI_PICO_W)
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)>
//  display(GxEPD2_DRIVER_CLASS(/*CS=*/ 5, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
//#endif
const int ledPin = 25;
int i = 0;
  while (!Serial) delay(10);  // Wait for Serial to be ready
  Serial.println("Serial is ready");
  pinMode(ledPin, OUTPUT);
  analogWrite(ledPin, 200);
  Serial.println("starting setup");
  //display.init(115200); // default 10ms reset pulse, e.g. for bare panels with DESPI-C02
  Serial.println("before init");
  display.init(115200, true, 2, false); // USE THIS for Waveshare boards with "clever" reset circuit, 2ms reset pulse
  //display.init(115200, true, 10, false, SPI, SPISettings(4000000, MSBFIRST, SPI_MODE0));
  Serial.println("after init");
  helloWorld();
  display.hibernate();
const char HelloWorld[] = "Hello World!";
void helloWorld()
  display.setRotation(1);
  display.setFont(&FreeMonoBold9pt7b);
  display.setTextColor(GxEPD_BLACK);
  int16_t tbx, tby; uint16_t tbw, tbh;
  display.getTextBounds(HelloWorld, 0, 0, &tbx, &tby, &tbw, &tbh);
  // center the bounding box by transposition of the origin:
  uint16_t x = ((display.width() - tbw) / 2) - tbx;
  uint16_t y = ((display.height() - tbh) / 2) - tby;
  display.setFullWindow();
  display.firstPage();
  do
    display.fillScreen(GxEPD_WHITE);
    display.setCursor(x, y);
    display.print(HelloWorld);
  while (display.nextPage());
  Serial.print(i);
  Serial.println(" test");
  helloWorld();
  delay(2000);
  i++;
... and you left the PWR line open?
The PWR control line needs to be pulled high to enable power to the display.
I did try pulling it high (and low just in case), apologies forgot to mention it in the post. I saw this output when pulled high to 3.3V (same line as Vcc)
Serial is ready
startting setup
before init
after init
_Update_Full : 4
_Update_Full : 1
0 test
_Update_Full : 0
1 test
_Update_Full : 0
2 test
_Update_Full : 0
// SPI
#define PIN_SPI_MISO  (16u)
#define PIN_SPI_MOSI  (19u)
#define PIN_SPI_SCK   (18u)
#define PIN_SPI_SS    (17u)
from C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\4.2.4\variants\pins_arduino.h
You need to remap SPI pins for your wiring.
Thanks, that worked!
I got too fixated on the example wiring for the same board, it matched the SPI0 pins in the pinout so I assumed that was the default. I didn’t realise the mbed core for the Pico defines its own default SPI pins, and that those need to match unless explicitly remapped. Appreciate the tip on checking the actual pins_arduino.h — that was really helpful. Learned something new!
For anyone on a Mac, the folder is:
/Users/{your_user}/Library/Arduino15/packages/arduino/hardware/mbed_rp2040/4.2.4/variants/RASPBERRY_PI_PICO/pins_arduino.h
My wiring:
VCC 3V3
PWR 3V3
GND GND
DIN (MOSI) GP19
CLK (SCK) GP18
CS GP5
DC GP8
RST GP9
BUSY GP7
