Hello,
This my first time working on the" gy-521" 3 axis sensor, is there a way to use it to get just the angle of a wood bar when it's placed on the wood bar. and that wood bar is connecting the top of 2 hydraulic jack's, when the wood bar is not horizontal the process of leveling should start, so once the wood bar is leveled "0 degrees" the whole process of leveling that wood bar should stop, so I need input be in angles.
I already made the whole system work by using a simple tilt switch sensor "mercury" the same that is used with cars trunks but it lack accuracy .
Thank you guys in advance
