Hi There,
I have a GY-521 connected to a Uno R3 and I have it sitting on my desk not moving at all. When looking at the values being sent over, they seem very odd.
I would imagine the accelerometer and gyro's should be closer to 0 and not move so much?
Serial Output
aX = -2316 | aY = 280 | aZ = 17712 | tmp = 42.65 | gX = -72 | gY = 150 | gZ = 52
aX = -2360 | aY = 288 | aZ = 17720 | tmp = 42.60 | gX = -110 | gY = 137 | gZ = 67
aX = -2272 | aY = 240 | aZ = 17856 | tmp = 42.65 | gX = -99 | gY = 148 | gZ = 95
aX = -2236 | aY = 288 | aZ = 17784 | tmp = 42.41 | gX = -69 | gY = 141 | gZ = 77
aX = -2300 | aY = -32 | aZ = 17464 | tmp = 42.74 | gX = -122 | gY = 183 | gZ = 53
aX = -2248 | aY = 336 | aZ = 17816 | tmp = 42.65 | gX = -98 | gY = 128 | gZ = 57
aX = -2356 | aY = 340 | aZ = 17700 | tmp = 42.65 | gX = -71 | gY = 162 | gZ = 65
aX = -2312 | aY = 352 | aZ = 17808 | tmp = 42.46 | gX = -71 | gY = 131 | gZ = 89
aX = -2284 | aY = 276 | aZ = 17808 | tmp = 42.46 | gX = -26 | gY = 109 | gZ = 59
aX = -2392 | aY = 324 | aZ = 17808 | tmp = 42.60 | gX = -70 | gY = 123 | gZ = 33
aX = -2292 | aY = 260 | aZ = 17780 | tmp = 42.51 | gX = -121 | gY = 139 | gZ = 42
aX = -2248 | aY = 328 | aZ = 17880 | tmp = 42.65 | gX = -79 | gY = 168 | gZ = 87
aX = -2300 | aY = 316 | aZ = 17752 | tmp = 42.60 | gX = -103 | gY = 146 | gZ = 43
// (c) Michael Schoeffler 2017, http://www.mschoeffler.de
#include "Wire.h" // This library allows you to communicate with I2C devices.
const int MPU_ADDR = 0x68; // I2C address of the MPU-6050. If AD0 pin is set to HIGH, the I2C address will be 0x69.
int16_t accelerometer_x, accelerometer_y, accelerometer_z; // variables for accelerometer raw data
int16_t gyro_x, gyro_y, gyro_z; // variables for gyro raw data
int16_t temperature; // variables for temperature data
char tmp_str[7]; // temporary variable used in convert function
char* convert_int16_to_str(int16_t i) { // converts int16 to string. Moreover, resulting strings will have the same length in the debug monitor.
sprintf(tmp_str, "%6d", i);
return tmp_str;
Wire.begin();
Wire.beginTransmission(MPU_ADDR); // Begins a transmission to the I2C slave (GY-521 board)
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H) [MPU-6000 and MPU-6050 Register Map and Descriptions Revision 4.2, p.40]
Wire.endTransmission(false); // the parameter indicates that the Arduino will send a restart. As a result, the connection is kept active.
Wire.requestFrom(MPU_ADDR, 7*2, true); // request a total of 7*2=14 registers
// "Wire.read()<<8 | Wire.read();" means two registers are read and stored in the same variable
accelerometer_x = Wire.read()<<8 | Wire.read(); // reading registers: 0x3B (ACCEL_XOUT_H) and 0x3C (ACCEL_XOUT_L)
accelerometer_y = Wire.read()<<8 | Wire.read(); // reading registers: 0x3D (ACCEL_YOUT_H) and 0x3E (ACCEL_YOUT_L)
accelerometer_z = Wire.read()<<8 | Wire.read(); // reading registers: 0x3F (ACCEL_ZOUT_H) and 0x40 (ACCEL_ZOUT_L)
temperature = Wire.read()<<8 | Wire.read(); // reading registers: 0x41 (TEMP_OUT_H) and 0x42 (TEMP_OUT_L)
gyro_x = Wire.read()<<8 | Wire.read(); // reading registers: 0x43 (GYRO_XOUT_H) and 0x44 (GYRO_XOUT_L)
gyro_y = Wire.read()<<8 | Wire.read(); // reading registers: 0x45 (GYRO_YOUT_H) and 0x46 (GYRO_YOUT_L)
gyro_z = Wire.read()<<8 | Wire.read(); // reading registers: 0x47 (GYRO_ZOUT_H) and 0x48 (GYRO_ZOUT_L)
// print out data
Serial.print("aX = "); Serial.print(convert_int16_to_str(accelerometer_x));
Serial.print(" | aY = "); Serial.print(convert_int16_to_str(accelerometer_y));
Serial.print(" | aZ = "); Serial.print(convert_int16_to_str(accelerometer_z));
// the following equation was taken from the documentation [MPU-6000/MPU-6050 Register Map and Description, p.30]
Serial.print(" | tmp = "); Serial.print(temperature/340.00+36.53);
Serial.print(" | gX = "); Serial.print(convert_int16_to_str(gyro_x));
Serial.print(" | gY = "); Serial.print(convert_int16_to_str(gyro_y));
Serial.print(" | gZ = "); Serial.print(convert_int16_to_str(gyro_z));
// delay
