GY-80
I am trying to get data from a GY-80 sensor using I2C. I am currently trying to access the accelerometer data and have been kind of successful. I can only get 2 axes to work at a time, and I am unsure why this is the case.
XYZ_Axis_Acceleromter.ino (1.52 KB)
Could it be that you've got the Y axis read commented-out?
Please, if you only got a tiny amount of code, just POST IT, don't make us download it.
Sorry, here is the code. I commented some of it out because I was doing some testing to see what the issue was.
#include <Wire.h>
int ADXLAddress = 0x53; // Device address in which is also included the 8th bit for selecting the mode, read in this case.
#define X_Axis_Register_DATAX0 0x32 // Hexadecima address for the DATAX0 internal register.
#define X_Axis_Register_DATAX1 0x33 // Hexadecima address for the DATAX1 internal register.
#define Y_Axis_Register_DATAY0 0x34
#define Y_Axis_Register_DATAY1 0x35
#define Z_Axis_Register_DATAZ0 0x36
#define Z_Axis_Register_DATAZ1 0x37
#define Power_Register 0x2D // Power Control Register
int X0,X1,X_out;
int Y0,Y1,Y_out;
int Z0,Z1,Z_out;
Wire.begin(); // Initiate the Wire library
delay(10);
// Enable measurement
Wire.beginTransmission(ADXLAddress);
Wire.write(Power_Register);
// Bit D3 High for measuring enable (0000 1000)
Wire.write(8);
Wire.endTransmission();
Wire.beginTransmission(ADXLAddress); // Begin transmission to the Sensor
//Ask the particular registers for data
Wire.write(X_Axis_Register_DATAX0);
Wire.write(X_Axis_Register_DATAX1);
// Wire.write(Y_Axis_Register_DATAY0);
// Wire.write(Y_Axis_Register_DATAY1);
Wire.write(Z_Axis_Register_DATAZ0);
Wire.write(Z_Axis_Register_DATAZ1);
Wire.endTransmission(); // Ends the transmission and transmits the data from the two registers
Wire.requestFrom(ADXLAddress,6); // Request the transmitted bytes from the two registers
if(Wire.available()<=6) {
X0 = Wire.read(); // Reads the data from the register
X1 = Wire.read();
Y0 = Wire.read();
Y1 = Wire.read();
Z0 = Wire.read();
Z1 = Wire.read();
Serial.print("X0= “);
Serial.print(X0);
Serial.print(” X1= ");
Serial.println(X1);
Serial.print("Y0= “);
Serial.print(Y0);
Serial.print(” Y1= ");
Serial.println(Y1);
Serial.print("Z0= “);
Serial.print(Z0);
Serial.print(” Z1= ");
Serial.println(Z1);
I give up.
  while(Wire.available()<=6) { } // changed
  //  delay(1000);
    X1 = Wire.read();
    Y0 = Wire.read();
    Y1 = Wire.read();
    Z0 = Wire.read();
    Z1 = Wire.read();
    Serial.print.......... and so on
So I changed it up a bit and when I add the <=6 part, it won’t at all print to my serial monitor. I apologize, I just started learning this all a couple days ago, any help past this updated code would be great!
#include <Wire.h>
int X0,X1;
int Y0,Y1;
int Z0,Z1;
Wire.begin();
Wire.endTransmission(0); // Ends the transmission and transmits the data from the 6 registers
Wire.requestFrom(ADXLAddress,6,1); //Send stop signal at end of request which is what the 1 is
while(Wire.available()<=6); {
X1 = Wire.read();
Y0 = Wire.read();
Y1 = Wire.read();
Z0 = Wire.read();
Z1 = Wire.read();
Serial print…
“<=” should ofcourse be “<”
