gy-801 accelerometers - ERROR
Hello there,
I'm using the GY-801. code below. but it gives the following error
ERROR:
Arduino:1.6.5 (Windows 8.1), Kart:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Accelerometers:25: error: variable or field 'Output' declared void
Accelerometers:25: error: 'AccelerometerRaw' was not declared in this scope
Accelerometers:25: error: 'AccelerometerScaled' was not declared in this scope
Accelerometers.ino: In function 'void setup()':
Accelerometers:35: error: 'class ADXL345' has no member named 'EnsureConnected'
Accelerometers:45: error: 'class ADXL345' has no member named 'SetRange'
Accelerometers:47: error: 'class ADXL345' has no member named 'EnableMeasurements'
Accelerometers.ino: In function 'void loop()':
Accelerometers:52: error: 'class ADXL345' has no member named 'IsConnected'
Accelerometers:55: error: 'AccelerometerRaw' was not declared in this scope
Accelerometers:55: error: expected ';' before 'raw'
Accelerometers:57: error: 'raw' was not declared in this scope
Accelerometers:62: error: 'AccelerometerScaled' was not declared in this scope
Accelerometers:62: error: expected ';' before 'scaled'
Accelerometers:64: error: 'scaled' was not declared in this scope
Accelerometers:67: error: 'Output' was not declared in this scope
Accelerometers.ino: At global scope:
Accelerometers:72: error: variable or field 'Output' declared void
Accelerometers:72: error: 'AccelerometerRaw' was not declared in this scope
Accelerometers:72: error: 'AccelerometerScaled' was not declared in this scope
Rapor daha fazla veri içermeli
"Derleme sırasında ayrıntılı çıktı göster"
Dosya > Tercihler'de etkinleştirilmiş.
ADXL345_Example.pde - Example sketch for integration with an ADXL345 triple axis accelerometer.
Copyright (C) 2011 Love Electronics (loveelectronics.co.uk)
This program is free software: you can redistribute it and/or modify
it under the terms of the version 3 GNU General Public License as
published by the Free Software Foundation.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
// Include the Wire library so we can start using I2C.
#include <Wire.h>
// Include the Love Electronics ADXL345 library so we can use the accelerometer.
#include <ADXL345.h>
// Declare a global instance of the accelerometer.
ADXL345 accel;
  // Begin by setting up the Serial Port so we can output our results.
  // Start the I2C Wire library so we can use I2C to talk to the accelerometer.
  Wire.begin();
  // Create an instance of the accelerometer on the default address (0x1D)
  accel = ADXL345();
  // Check that the accelerometer is infact connected.
  if(accel.EnsureConnected())
    Serial.println("Connected to ADXL345.");
    Serial.println("Could not connect to ADXL345.");
  // Set the range of the accelerometer to a maximum of 2G.
  accel.SetRange(2, true);
  // Tell the accelerometer to start taking measurements.
  accel.EnableMeasurements();
  if(accel.IsConnected) // If we are connected to the accelerometer.
    // Read the raw data from the accelerometer.
    AccelerometerRaw raw = accel.ReadRawAxis();
    //This data can be accessed like so:
    int xAxisRawData = raw.XAxis;
    // Read the *scaled* data from the accelerometer (this does it's own read from the accelerometer
    // so you don't have to ReadRawAxis before you use this method).
    // This useful method gives you the value in G thanks to the Love Electronics library.
    AccelerometerScaled scaled = accel.ReadScaledAxis();
    // This data can be accessed like so:
    float xAxisGs = scaled.XAxis;
    // We output our received data.
    Output(raw, scaled);
// Output the data down the serial port.
void Output(AccelerometerRaw raw, AccelerometerScaled scaled)
   // Tell us about the raw values coming from the accelerometer.
   Serial.print("Raw:\t");
   Serial.print(raw.XAxis);
   Serial.print("   ");
   Serial.print(raw.YAxis);
   Serial.print("   ");
   Serial.print(raw.ZAxis);
   // Tell us about the this data, but scale it into useful units (G).
   Serial.print("   \tScaled:\t");
   Serial.print(scaled.XAxis);
   Serial.print("G   ");
   Serial.print(scaled.YAxis);
   Serial.print("G   ");
   Serial.print(scaled.ZAxis);
   Serial.println("G");
I didn't download and install the needed libraries, and I get exactly the same errors. Why didn't YOU download and properly install the needed libraries?
