Hello everyone, I’m new in forum and I need to your guidance about my problem. I use GY-87 board which is 10DOF sensor board and it has MPU6050, HMC5883L and BMP180. I use I2CDev Library for connect to GY-87. I have the code and it works for MPU6050 and BMP180 but it doesn’t work for HMC5883L. I looked a few tutorial and I saw that they use these code lines before connect HCM5883L;
accelgyro.setI2CMasterModeEnabled(false);
accelgyro.setI2CBypassEnabled(true) ;
accelgyro.setSleepEnabled(false);
So I added these lines but it still doesn’t work for HMC5883L. You can find all of my code below. Can anybody help me about this problem. Thank you for your interest.
GY-87 Test
Tests basic functionality of the GY-87 sensor board.
Connections:
|== GY-87 ==|== Arduino ==|
| VCC_IN | VCC |
| GND | GND |
| SDA | SDA |
| SCL | SCL |
Requires the I2CDevLib library, which can be found here: https://github.com/jrowberg/i2cdevlib
by Tom Kuehn
26/06/2016
#include "I2Cdev.h"
#include "MPU6050.h"
#include "HMC5883L.h"
#include "BMP085.h"
#include "Wire.h"
static const float ACCEL_SENS = 16384.0; // Accel Sensitivity with default +/- 2g scale
static const float GYRO_SENS = 131.0; // Gyro Sensitivity with default +/- 250 deg/s scale
// Magnetometer class default I2C address is 0x1E
// specific I2C addresses may be passed as a parameter here
// this device only supports one I2C address (0x1E)
HMC5883L mag;
int16_t mx, my, mz;
// Accel/Gyro class default I2C address is 0x68 (can be 0x69 if AD0 is high)
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
// Barometer class default I2C address is 0x77
// (though the BMP085 supports only one address)
BMP085 barometer;
float temperature;
float pressure;
int32_t lastMicros;
boolean state = HIGH;
unsigned int count = 0;
while (!Serial && (count < 30) )
delay(200); // Wait for serial port to connect with timeout. Needed for native USB
state = !state;
count++;
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
// ==================== MPU6050 ============================
accelgyro.initialize();
Serial.print("Testing Accel/Gyro... ");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
// ==================== HMC5883L ============================
mag.initialize();
Serial.print("Testing Mag... ");
Serial.println(mag.testConnection() ? "HMC5883L connection successful" : "HMC5883L connection failed");
// ==================== BMP085 ============================
barometer.initialize();
Serial.print("Testing Pressure... ");
Serial.println(barometer.testConnection() ? "BMP085 connection successful" : "BMP085 connection failed");
Serial.println("Setup Complete");
static unsigned long ms = 0;
static boolean state = HIGH;
// Serial Output Format
// === Accel === | === Gyro === | ======= Mag ======= | === Barometer === |
// X Y Z | X Y Z | X Y Z Heading | Temp Pressure |
if (millis() - ms > 100)
// read raw accel/gyro measurements
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
// display tab-separated accel/gyro x/y/z values
Serial.print(ax / ACCEL_SENS); Serial.print("\t");
Serial.print(ay / ACCEL_SENS); Serial.print("\t");
Serial.print(az / ACCEL_SENS); Serial.print("\t");
Serial.print(gx / GYRO_SENS); Serial.print("\t");
Serial.print(gy / GYRO_SENS); Serial.print("\t");
Serial.print(gz / GYRO_SENS); Serial.print("\t");
// read raw heading measurements
mag.getHeading(&mx, &my, &mz);
// display tab-separated mag x/y/z values
Serial.print(mx); Serial.print("\t");
Serial.print(my); Serial.print("\t");
Serial.print(mz); Serial.print("\t");
// To calculate heading in degrees. 0 degree indicates North
float heading = atan2(my, mx);
if (heading < 0) heading += 2 * M_PI;
Serial.print(heading * 180 / M_PI); Serial.print("\t");
// request temperature
barometer.setControl(BMP085_MODE_TEMPERATURE);
// wait appropriate time for conversion (4.5ms delay)
lastMicros = micros();
while (micros() - lastMicros < barometer.getMeasureDelayMicroseconds());
// read calibrated temperature value in degrees Celsius
temperature = barometer.getTemperatureC();
// request pressure (3x oversampling mode, high detail, 23.5ms delay)
barometer.setControl(BMP085_MODE_PRESSURE_3);
// read calibrated pressure value in Pascals (Pa)
pressure = barometer.getPressure();
// display measured values if appropriate
Serial.print(temperature); Serial.print("\t");
Serial.print(pressure / 100); Serial.println("\t");
ms = millis();
state = !state;
delay(5000);
