GY-91 Sendor - avrdude errors
Hi, I'm new here.
I try to get following running:
Anyhow I don't get is even if it looks so simple to follow this instructions.
My code is a copy of the one on the page and I included both all libraries.
Arduino: 1.8.13 (Linux), Board: "Arduino Uno"
Sketch uses 17798 bytes (55%) of program storage space. Maximum is 32256 bytes.
Global variables use 773 bytes (37%) of dynamic memory, leaving 1275 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x09
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x65
option enabled in File -> Preferences.
Does anyone have a idea?
Thanks
Martin
Hi, @martinhb
Welcome to the forum.
What OS and IDE version are you using?
Are you using a UNO?
Have you loaded code to your controller before?
Can you please tell us your electronics, programming, arduino, hardware experience?
Please post your code.
To add code please click this link;
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
My OS is: Linum Mint, IDE? No idea.
Arduino Uno, correct.
I have plaied a little with Arduino a few years ago. And generally not so much experience.
Thanks
Martin
Hm, ok!
I got it, Actually I still get those errors but I get Data: It was the wrong setting on my side for the baud rate......
Many thanks
martin
