GY-MAX30100 BPM and SP02 sensor on arduino
Hello, I got a GY-MAX30100 BPM and SP02 sensor to use on my project but unfortunately there’s little information about it, especially used on Arduno boards, turns out the only 2 libraries I found so far have some examples but none of them compiles (there’s always an error).
For example this code initially says: “macro passed 3 arguments but it takes only 2” and when I fix it another error comes…
I cannot even test the sensor.
Any help is appreciated. I just want to get O2 in a percentage reading and BPM.
Arduino-MAX30100 oximetry / heart rate integrated sensor library
Copyright (C) 2016  OXullo Intersecans <x@brainrapers.org>
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program.  If not, see <http://www.gnu.org/licenses/>.
// Grapher helper for the Arduino MAX30100 library
import processing.serial.*;
// NOTE: when using PULSEOXIMETER_DEBUGGINGMODE_RAW_VALUES
// set this to -1 to enable the auto range mode
final int ABSMAX = 800;
// Adjust to the serial port. Under OSX, UNO platforms and alike are auto-detected.
final String serialPort = "/dev/tty.usbmodemFD13131";
final int WIDTH = 1200;
final int HEIGHT = 600;
final int CHANNELS = 2;
final color[] colors = {color(0, 0, 0), color(255, 0, 0), color(0, 255, 0), color(0, 0, 255)};
float[][] series = new float[CHANNELS][WIDTH];
float heartRate = 0;
int spO2 = 0;
int redLedCurrentIndex = 0;
boolean beatDetected = false;
int ptr = 0;
Serial myPort;
void settings()
  size(WIDTH, HEIGHT);
void setup ()
  String attemptPort = serialPort;
  for (int i=0 ; i < Serial.list().length ; ++i) {
    String port = Serial.list()[i];
    if (port.matches(".+tty\\.usbmodem.+")) {
      attemptPort = port;
  println("Opening port " + attemptPort);
  myPort = new Serial(this, attemptPort, 115200);
  stroke(0);
  fill(0);
  textSize(8);
void draw ()
  if (beatDetected) {
    background(255, 200, 200);
    background(255);
  stroke(30);
  line(0, height/2, width, height/2);
  float maxv=0, minv;
  for (int s=0 ; s < CHANNELS ; ++s) {
    float[] samples = series[s];
    maxv = max(maxv, abs(max(samples)), abs(min(samples)));
    if (ABSMAX != -1) {
      maxv = min(maxv, ABSMAX);
  // Avoids map() errors
  if (maxv == 0) {
    maxv = 1;
  minv = -maxv;
    stroke(colors[s]);
    float seriesMax = max(samples);
    text("ch " + s + " cur:" + samples[ptr] + " max:" + seriesMax + " min:" + min(samples), 0, 8 + 10 * s);
    boolean maxDisplayed = false;
    for (int i = 0 ; i < WIDTH ; ++i) {
      if (i > 0) {
        float ipy = HEIGHT - map(samples[i-1], minv, maxv, 0, HEIGHT);
        float iy = HEIGHT - map(samples[i], minv, maxv, 0, HEIGHT);
        if (abs(samples[i] - seriesMax) < 0.001 && !maxDisplayed) {
          text("v=" + samples[i], i, iy);
          maxDisplayed = true;
        line(i - 1, ipy, i, iy);
  text("Rate: " + heartRate, 200, 8);
  text("SpO2: " + spO2 + "%", 200, 18);
  text("RLI: " + redLedCurrentIndex, 200, 28);
void serialEvent (Serial myPort)
  String sLine = myPort.readStringUntil('\n');
  if (sLine == null) {
    return;
  if (sLine.substring(0, 2).equals("R:")) {
    String[] sValues = split(sLine.substring(2), ',');
    for (int i=0 ; i < sValues.length ; ++i) {
      float sample = float(sValues[i]);
      if (Float.isNaN(sample)) {
        continue;
      series[i][ptr] = sample;
    ptr = (ptr + 1) % WIDTH;
  } else if (sLine.substring(0, 2).equals("H:")) {
    heartRate = float(sLine.substring(2));
  } else if (sLine.substring(0, 2).equals("B:")) {
    beatDetected = true;
  } else if (sLine.substring(0, 2).equals("C:")) {
    println(sLine);
  } else if (sLine.substring(0, 2).equals("O:")) {
    spO2 = int(float(sLine.substring(2)));
  } else if (sLine.substring(0, 2).equals("I:")) {
    redLedCurrentIndex = int(float(sLine.substring(2)));
I made it work with SparkFun's library, I suspect that libraries and codes are sensible to sensor model variants. The library is called SparkFun MAX3010x. I also found out that 2 of 3 sensors I bought were defective :confused: .
