https://www.youtube.com/watch?v=65ZKoxykhqs, code using form youtube, board using NodeMcu 12-E module, but getting zero, pin connect GND-GND,Vin-3.3V, scl -D1,SDAD2,INT-D0, IF I JUST CONNECT MY PROJECT with ARDUINOP it cames out values,
Vin is usually the pin that takes a voltage higher than 3.3V and converts it to 3.3V.
Which board do you have exactly? The 1st or the 3rd one on ESP8266 Pinout Reference: Which GPIO pins should you use? | Random Nerd Tutorials? Or even another one?
The ESP8266 12-E NodeMCU Kit one...
problem solved
hello..how did you solved? thank you!
how did you solved?
Can you please the code
Hello. How did you solve the problem? Can you please share your code?
