Hi, I'm using a GY87 module (only the gyro and HMC5885 module) and my code is working, I can read the datas in the Serial Monitor, but I think there is something wrong with them. The HMC 5883 datas are always increasing instead of showing the new result. Example: in the first data x=4500, but for the 10th measure it's like 75456. There is my code, thank u in advance!
#include "I2Cdev.h"
#include "MPU6050.h"
#include "Wire.h"
//MPU6050 Accelerometer
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
//HMC5883L Digital Compass
const int hmc5883Address = 0x1E; //0011110b, I2C 7bit address for compass
const byte hmc5883ModeRegister = 0x02;
const byte hmcContinuousMode = 0x00;
const byte hmcDataOutputXMSBAddress = 0x03;
int x, y, z; //triple axis data from HMC5883L.
int mX, mY, mZ;
Wire.begin();
// eszkoz inicializalasa
Serial.println("Initializing I2C devices...");
accelgyro.initialize();
// kapcsolodas megerositese
Serial.println("Testing device connections...");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
accelgyro.setI2CBypassEnabled(true); //This sets the bypass so the HMC5883L gets a look in.
//Magnetometer inicializalasa
Wire.beginTransmission(hmc5883Address); //Begin communication with compass
Wire.write(hmc5883ModeRegister); //select the mode register
Wire.write(hmcContinuousMode); //continuous measurement mode
Wire.endTransmission();
// gyorsulas es szogsebesseg beolvasasa az eszkozrol
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
// gyorsulas es szogsebesseg kijelzese
Serial.println("gyorsulas es szogsebesseg:\t");
Serial.print("x iranyu gyorsulas: ");
Serial.print(ax); Serial.println("\t");
Serial.print("y iranyu gyorsulas: ");
Serial.print(ay); Serial.println("\t");
Serial.print("z iranyu gyorsulas: ");
Serial.print(az); Serial.println("\t");
Serial.print("x iranyu szogsebesseg: ");
Serial.print(gx); Serial.println("\t");
Serial.print("y iranyu szogsebesseg: ");
Serial.print(gy); Serial.println("\t");
Serial.print("z iranyu szogsebesseg: ");
Serial.print(gz); Serial.println("\t");
//Accessing the HMC5883L Digital Compass
//Tell the HMC5883L where to begin reading the data
Wire.write(hmcDataOutputXMSBAddress); //Select register 3, X MSB register
//Read data from each axis of the Digital Compass
Wire.requestFrom(hmc5883Address, 6);
if (6 <= Wire.available()) {
x = Wire.read() << 8; //X msb
x |= Wire.read(); //X lsb
z = Wire.read() << 8; //Z msb
z |= Wire.read(); //Z lsb
y = Wire.read() << 8; //Y msb
y |= Wire.read(); //Y lsb
mX = (mX + x) ;
mY = (mY + y) ;
mZ = (mZ + z) ;
// Print out values of each axis
Serial.println("Magnetometer tengelyek:\t");
Serial.print("x: ");
Serial.print(mX); Serial.println("\t");
Serial.print(" y: ");
Serial.print(mY); Serial.println("\t");
Serial.print(" z: ");
Serial.println(mZ); Serial.println("\t");
int angle = atan2(-y, x) / M_PI * 180;
if (angle < 0) {
angle = angle + 360;
// Reporting the Compass data to the Serial port
Serial.print("Irany(fok):\t");
Serial.print(angle); Serial.println("\t");
