Gyro MPU6050
I am using YMFC-3D_V2 code for quadcopter. while i am running setup file , gyro mpu 6050 does not search and error 3 create. all the connection are correct and I have try with other mpu6050. but result is zero. if I am using following code
//// MPU-6050 Short Example Sketch
// By Arduino User JohnChi
// August 17, 2014
// Public Domain
#include<Wire.h>
const int MPU_addr=0x68; // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
void loop(){
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Serial.print("AcX = “); Serial.print(AcX);
Serial.print(” | AcY = “); Serial.print(AcY);
Serial.print(” | AcZ = “); Serial.print(AcZ);
Serial.print(” | Tmp = “); Serial.print(Tmp/340.00+36.53); //equation for temperature in degrees C from datasheet
Serial.print(” | GyX = “); Serial.print(GyX);
Serial.print(” | GyY = “); Serial.print(GyY);
Serial.print(” | GyZ = "); Serial.println(GyZ);
delay(333);
mpu working properly. means mpu correct and wiring is correct. I cannot understand that what is problem. I am new with arduino and programing also. I can programing plc and scada.
any one can help me to solve this problem?
Start here.
That collection of words seriously needs some punctuation and proper capitalization.
