Gyro readings
Hi guys, I'm building a self balancing unicycle, and I'm using Arduino as the brain :). I'm having a problem with the gyro reading. I'm getting good reads until I turn a led on with pwm (pin 5), when I do that, the gyro start sending a value that is different than the normal resting value. This should have something to do with the current drop, but I have no idea how to solve this...
Thanks
PS: I'll post some pics and vids after it's done...(you can see the project @ sites.google.com/site/ptunicycle/)
Code and a schematic would help us to help you...
Here it is an image. The schematic is very simple
The code is just an analogRead(0) and analogWrite(5,x)
Another thing, I tried it with digitalWrite, and it doesn't affect the gyro readings :-/
Where's your inline resistor for the LED?
Hummm, i forgot that, how many ohms should be the resistor??
I’m trying to point you at a good source at arduino.cc but surprisingly it’s not as easy to find as I first thought.
220 Ohm is a common value.
You can calculate it based on max current the Arduino can source: 40 mA. @ 5V = 125 Ohm ← this is the resistor value for which you’d expect Arduino the output to burn out.
Hope you haven’t damaged your Arduino by running this thing without a resistor up to now.
Thanks, after you point me out to the resistor i tried it, but it keeps affecting my gyro readings, maybe my ground value is not 0v when i turn on the led or something like that...
Not too critical. anything from 200 to 1,000 ohms will let you see a red LED pretty much and still not stress the Arduino output pin. Different color or higher power LED's are a different situation.
Lefty
Try it with the LED ground pin floating (no current draw), but keep the PWM code in place. Might help you understand if the problem is rooted in h/w or s/w.
