Gyro sensor and 50m Hi-AT laser module for conditional measurement
Hai, i am developing a code to run a measurement when pushbutton is pressed and the angle must be between 0 degree and continue measure on second distance when the angle is in between 60 degree. Then use the result to compare the values. But sadly, the code is right but i guess i miss something. can anybody help me on this?
Here is the code, the part which i am having trouble.
//The measurement only occurs when pushbutton module preesed
//The gyro sensor x angle is in 0 degree, continue the second measurement
//without pressing any pushbutton while just make sure the angle angle is in 60 degree and it continue measure in the same loop.
if (digitalRead(12) == 1)         //if pushbutton pin 12 is pressed
   flatness();                            //void flatness
  if ( d2cal >= d2 + 0.1 && d2cal <= d2 - 0.1)     //compare the result of d2cal and d2 measured
      Serial.println("THE BUILDING NEED INSPECTION");
    else if ( d2 > d2cal - 0.1 && d2 < d2cal + 0.1)
      Serial.println("THE BUILDING IN GOOD CONDITION");
    delay(5000);
void flatness()
    angle();                             //run the angle loop first
    Serial.println(x);              // serial print angle x
    digitalWrite(32 , LOW);  //off the push button vcc so that
    digitalWrite(25 , LOW);  //during process, the pushbutton will not be available
    while ( x = 0)                   //only measure when the angle is in 0 degree
      d1 = measure();          //read Hi-AT 50m laser module value
      d2cal = d1 * 0.5;         // calculate for second distance
      Serial.print(d1);
      Serial.print("\t");
      Serial.print(d2cal);
      Serial.print("\t");
     while ( x > 59 || x < 61)        //continue the process only if the angle is in 60 degree
        d2 = measure();                   // measure distance 2 in 60 degree angle
        Serial.println(d2);
    digitalWrite(32 , HIGH);      //activate vcc of push button
    digitalWrite(25 , HIGH);      //so that it can enable next measurement
void angle()
//result from gyro sensor for angle measurement
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x3B);
  Wire.endTransmission(false);
  Wire.requestFrom(MPU_addr, 14, true);
  AcX = Wire.read() << 8 | Wire.read();
  AcY = Wire.read() << 8 | Wire.read();
  AcZ = Wire.read() << 8 | Wire.read();
  int xAng = map(AcX, minVal, maxVal, -90, 90);
  int yAng = map(AcY, minVal, maxVal, -90, 90);
  int zAng = map(AcZ, minVal, maxVal, -90, 90);
  x = RAD_TO_DEG * (atan2(-yAng, -zAng) + PI);
  y = RAD_TO_DEG * (atan2(-xAng, -zAng) + PI);
  z = RAD_TO_DEG * (atan2(-yAng, -xAng) + PI);
double measure()
  double distance = 999.0;
  String response = "";
  LaserSerial.println("M");
  delay(2500);
  while (LaserSerial.available() > 0)
    LaserSerial.read();
  exitloop = millis();
  while (LaserSerial.available() <= 0 && (millis() < exitloop + 2000));
  if (millis() < exitloop + 2000) {
    while (LaserSerial.available() > 0) {
      String inByte = LaserSerial.readString();
      response = response + String(inByte) ;
    if (response.indexOf('m') >= -1)
      int hi = response.indexOf(':');
      distance = response.substring(hi + 1, hi + 7).toFloat();
  return distance ;
gyro_with_pushbutton.ino (2.9 KB)
Thank you in advance.
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
Thanks... Tom.. :smiley: :+1: :coffee: :australia:
Please edit your post to add code tags.
Hi. i have edit it to code tag. Thank you
Great, thanks! Now, finish reading the "How to get the best out of the forum" post, and explain the problems you are having.
Consider adding comments to the code, for example to explain the functions of mysterious lines like this:
  if (digitalRead(12) == 1) {
A circuit diagram would be of great assistance.
How have you got your buttons wired?
If they switch the input to 5V you must have a 10K resistor on each input, between the input pin and gnd, to ensure the input is LOW when the button is open.
If they switch the input to gnd you must have a 10K resistor on each input, between the input pin and5V, to ensure the input is HIGH when the button is open.
Or in this case use your code to apply the internal pull_up resistors.
To make you code readable, instead of using pin numbers in your code.
declare them as contsant names, then use the names in the rest of your code.
For example with pin 12.
#define const startButtonPin 12  //startButtonPin have the variable constant 12
Then
 pinMode(startButtonPin , INPUT);
and so;
 if (digitalRead(startButtonPin) == 1)
It makes your code more self descriptive and if you want to change your hardware pins, all you need to do is change the #delcare statement.
okay will upload a newest post regarding this.
