Gyroscope MPU-6050
Hi everyone,
I want to use a gyroscope GY 521, MPU-6050, with my arduino, I already use and make the Jeff Rowberg's librairies work but here is my problem : I want to extract the yaw, pitch and roll values without having to use the serial monitor.
Can someone know how to that ?
Thanks
(deleted)
haha you're brillant, I really need to sleep ! Thanks!!
Can't see how this is an installation or troubleshooting question.
Moving.
In fact i try it but it does not work, There is nothing more in the Serial Monitor but I still have to enter a caracter in the Serial Monitor to make it works. Any solution ?
had740:
Posting your code so we can tell what the he’ll you are on about?
Yes, here is it, It is Rowberg’s code that i modified in order to display on three led informations about yaw, pitch and roll. It only works when I turn the serial monitor on.
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 mpu;
#define OUTPUT_READABLE_YAWPITCHROLL
#define INTERRUPT_PIN 2  // use pin 2 on Arduino Uno & most boards
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
// packet structure for InvenSense teapot demo
uint8_t teapotPacket[14] = { '
, 0x02, 0, 0, 0, 0, 0, 0, 0, 0, 0x00, 0x00, ‘\r’, ‘\n’ };
// ===              INTERRUPT DETECTION ROUTINE                ===
volatile bool mpuInterrupt = false;    // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
  mpuInterrupt = true;
int yaw;
int pitch;
int roll;
const int led1 = 3;
const int led2 = 4;
const int led3 = 5;
// ===                      INITIAL SETUP                      ===
  // join I2C bus (I2Cdev library doesn’t do this automatically)
  Wire.begin();
  Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
  Fastwire::setup(400, true);
#endif
// initialize serial communication
  // (115200 chosen because it is required for Teapot Demo output, but it’s
  // really up to you depending on your project)
  while (!Serial); // wait for Leonardo enumeration, others continue immediately
// NOTE: 8MHz or slower host processors, like the Teensy @ 3.3v or Ardunio
  // Pro Mini running at 3.3v, cannot handle this baud rate reliably due to
  // the baud timing being too misaligned with processor ticks. You must use
  // 38400 or slower in these cases, or use some kind of external separate
  // crystal solution for the UART timer.
// initialize device
  Serial.println(F(“Initializing I2C devices…”));
  mpu.initialize();
  pinMode(INTERRUPT_PIN, INPUT);
// verify connection
  Serial.println(F(“Testing device connections…”));
  Serial.println(mpu.testConnection() ? F(“MPU6050 connection successful”) : F(“MPU6050 connection failed”));
// wait for ready
  Serial.println(F("\nSend any character to begin DMP programming and demo: "));
  while (Serial.available() && Serial.read()); // empty buffer
  while (!Serial.available());                // wait for data
  while (Serial.available() && Serial.read()); // empty buffer again
// load and configure the DMP
  Serial.println(F(“Initializing DMP…”));
  devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
  mpu.setXGyroOffset(220);
  mpu.setYGyroOffset(76);
  mpu.setZGyroOffset(-85);
  mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
// make sure it worked (returns 0 if so)
  if (devStatus == 0) {
    // turn on the DMP, now that it’s ready
    Serial.println(F(“Enabling DMP…”));
    mpu.setDMPEnabled(true);
// enable Arduino interrupt detection
    Serial.println(F(“Enabling interrupt detection (Arduino external interrupt 0)…”));
    attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
    mpuIntStatus = mpu.getIntStatus();
// set our DMP Ready flag so the main loop() function knows it’s okay to use it
    Serial.println(F(“DMP ready! Waiting for first interrupt…”));
    dmpReady = true;
// get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
    // ERROR!
    // 1 = initial memory load failed
    // 2 = DMP configuration updates failed
    // (if it’s going to break, usually the code will be 1)
    Serial.print(F(“DMP Initialization failed (code “));
    Serial.print(devStatus);
    Serial.println(F(”)”));
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  digitalWrite(led1, LOW);
  digitalWrite(led2, LOW);
  digitalWrite(led3, LOW);
// ===                    MAIN PROGRAM LOOP                    ===
  // if programming failed, don’t try to do anything
  if (!dmpReady) return;
// wait for MPU interrupt or extra packet(s) available
  while (!mpuInterrupt && fifoCount < packetSize) {
    // other program behavior stuff here
    // if you are really paranoid you can frequently test in between other
    // stuff to see if mpuInterrupt is true, and if so, “break;” from the
    // while() loop to immediately process the MPU data
// reset interrupt flag and get INT_STATUS byte
// get current FIFO count
  fifoCount = mpu.getFIFOCount();
// check for overflow (this should never happen unless our code is too inefficient)
  if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
    // reset so we can continue cleanly
    mpu.resetFIFO();
    Serial.println(F(“FIFO overflow!”));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
  } else if (mpuIntStatus & 0x02) {
    // wait for correct available data length, should be a VERY short wait
    while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
    mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
    // (this lets us immediately read more without waiting for an interrupt)
    fifoCount -= packetSize;
#ifdef OUTPUT_READABLE_YAWPITCHROLL
    // display Euler angles in degrees
    mpu.dmpGetQuaternion(&q, fifoBuffer);
    mpu.dmpGetGravity(&gravity, &q);
    mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
yaw = ypr[0] * 180 / M_PI;
    pitch = ypr[1] * 180 / M_PI;
    roll = ypr[2] * 180 / M_PI;
#endif
// blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
if (abs(yaw) > 90) {
      digitalWrite(led1, HIGH);
    else {
    if (abs(pitch) > 45) {
      digitalWrite(led2, HIGH);
    else {
    if (abs(roll) > 45) {
      digitalWrite(led3, HIGH);
    else {
Are you using a Leonardo? Or any other Arduino with a native serial, such as Due, Nano or Teensy? Then it will stop and wait here until the serial monitor is opened.
My preferred method…
  while (!Serial && millis()<5000); // wait up to 5 seconds for serial monitor
had740:
Hi everyone,
Thanks
Do you mean to say you want the arduino to send serial information (pitch, yaw etc) to a computer, and the computer takes (and stores) the serial information using a software like python, c++, etc?
Yes, I am using c++
