Hi there,
I breadboarded this h-bridge circuit: http://www.jfunk.org/extras/labs/BipolarHBridgeSchematic.gif
with tip125's for the PNP's and tip120's for the NPN.
The h-bridge is connected to an arduino and a separate 9v battery to power a small dc motor. The h-bridge works, however the motor only receives about 2 volts and transistors get really hot.
The other problem is that when the h-bridge is connected to the power supply and the arduino is off the transistors still heat up.
Any help would be appreciated. Thanks.
