Some guidance would be much appreciated.
I am making progress with a flight programme (Arduina Mega). The script occasionally secures a GPS signal (UBlox 7, HAB Supplies) and sends data on time, latitude, longitude and altitude to an SD card (Adafruit 5v Breakout Board - Serial3). However, I seem to be getting stuck on two (possibly related) issues. These are:
First, I only occasionally get a GPS signal (sometimes indoors and sometimes outdoors). When there is no signal, the Serial usually produces a readout like this: “invalid,******* **** ******* ****** ***** *** 0 0.00 *** 1947 0 27”;
Second, in attempting to sort things out, I have tried to change the GPS to ‘flight mode’, which I will need to do anyway at some point, but fail for no reason that I can readily appreciate, given my current level of understanding.
The code I have patched together and adapted follows:
//this programme (works on Mega) takes data from gps and sends string (time, lat, lon, and alt) to SD card
#include <SPI.h>//
#include <TinyGPS.h>
#include <SD.h>
#include <stdlib.h>
TinyGPS gps;
static char dtostrfbuffer[20];
int CS = 53;
int LED = 8;
//Define String
String SD_date_time = "invalid";
String SD_lat = "invalid";
String SD_lon = "invalid";
String SD_alt = "invalid";
String dataString ="";//used to concatinate string values, above
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec, int SD_val);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
pinMode(CS, OUTPUT); //Chip Select Pin for the SD Card//
pinMode(LED, OUTPUT); //LED Indicator//
delay(100);//added
//Serial interfaces
Serial3.begin(4800);
// Serial.begin(19200);
// Serial3.begin(9600);
// Serial3.begin(4800);
// Serial.begin(9600);
//Connect to the SD Card
if(!SD.begin(CS))
Serial.println("Card Failure");
return;
bool newdata = false;
unsigned long start = millis();
// Every second print an update
while (millis() - start < 1000)
if (feedgps())
newdata = true;
gpsdump(gps);
//Write the newest information to the SD Card
dataString = SD_date_time + "," + SD_lat + "," + SD_lon + "," + SD_alt;
if(SD_date_time != "invalid")
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
delay(100);//ch
//Open the Data CSV File
File dataFile = SD.open("LOG.csv", FILE_WRITE);
if (dataFile)
dataFile.println(dataString);
Serial.println(dataString);
dataFile.close();
Serial.println("\nCouldn't open the log file!");//
float flat, flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
gps.f_get_position(&flat, &flon, &age);
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5, 1);
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5, 2);
print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
print_date(gps);// DATE AND TIME
print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2, 3);//ALTITUDE
print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2, 0);
print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
gps.stats(&chars, &sentences, &failed);
print_int(chars, 0xFFFFFFFF, 6);//LED flashes
print_int(sentences, 0xFFFFFFFF, 10);
print_int(failed, 0xFFFFFFFF, 9);
char sz[32];
if (val == invalid)
strcpy(sz, "*******");
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz[i] = ' ';
if (len > 0)
sz[len-1] = ' ';
Serial.print(sz);
feedgps();
char sz[32];
if (val == invalid)
sz[len] = 0;
if (len > 0)
sz[len-1] = ' ';
for (int i=7; i<len; ++i)
sz[i] = ' ';
Serial.print(sz);
if(SD_val == 1) SD_lat = sz;
else if(SD_val == 2) SD_lon = sz;
else if(SD_val == 3) SD_alt = sz;
Serial.print(val, prec);
if (SD_val == 1) SD_lat = dtostrf(val,10,5,dtostrfbuffer);
else if (SD_val == 2) SD_lon = dtostrf(val,10,5,dtostrfbuffer);
else if (SD_val == 3) SD_alt = dtostrf(val,10,5,dtostrfbuffer);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1);
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(" ");
feedgps();
int year;
byte month, day, hour, minute, second, hundredths;
unsigned long age;
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
if (age == TinyGPS::GPS_INVALID_AGE)
Serial.print("******* ******* ");
char sz[32];
sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",
month, day, year, hour, minute, second);
Serial.print(sz);
SD_date_time = sz;
feedgps();
int slen = strlen(str);
for (int i=0; i<len; ++i)
Serial.print(i<slen ? str[i] : ' ');
feedgps();
while (Serial3.available())
if (gps.encode(Serial3.read()))
return true;
return false;
Any help on securing a consistent GPS signal and integrating a flight mode code into my script would be very helpful in moving me on. Apologies if my question lacks finesse - I am new to this!
Thanks,
Colin.
