Hack help
Hello,
I have a project at hand which is to hack a toy car. I removed the circuit, and replaced it with L298N motor driver, so as to be able to control the speed of the toy car with PWM signals.
I also want it to avoid obstacles, so I got an idea of using two Ultrasonic sensors [Parallax PING)))], one on the left and the other on the right.
My toy isn't responding to the go_forward command and the go_reverse command (these two are PWM commands). Please help me out and see if there are wrong coding in the codes I have. The code is given below.
#include <NewPing.h>
 * This code is to avoid obstacles encountered on the left or right.
 * If there is an object on the left (Robot goes to the right),
 * and if there is an object on the right (Robot goes to the left)
// PING))) on the right
const int pingPin1 =  12;  // this pin serves for triggering and receiving
                           //sonic pulse for the PING))) sensor on the right
#define MAX_DISTANCE 400
NewPing DistanceSensor1 (pingPin1, pingPin1, MAX_DISTANCE);
long duration1;           // how long it takes for the sound to rebound
unsigned int cm1;
// PING))) on the left
const int pingPin2 = 4;
NewPing DistanceSensor2 (pingPin2, pingPin2, MAX_DISTANCE);
long duration2;
unsigned int cm2;
// sensing or not
boolean right_wall_detected = false;
boolean left_wall_detected = false;
// which way to turn
boolean Right = true;
int enA = 11;
int forward_in1 = 10;
int reverse_in2 = 9;
int enB = 6;
int right_in3 = 8;
int left_in4 = 7;
void go_forward();
void go_reverse();
void forward_brake();
void reverse_brake();
void turn_right();
void turn_left();
void stop_device();
void detect_right_wall();
void detect_left_wall();
  Serial.println ("Starting");
  // initializing the digital pins as outputs:
  pinMode (enA, OUTPUT);
  pinMode (enB, OUTPUT);
  pinMode (forward_in1, OUTPUT);
  pinMode (reverse_in2, OUTPUT);
  pinMode (left_in4, OUTPUT);
  pinMode (right_in3, OUTPUT);
void go_forward()
{ //Increase speed from 0 -> 153
  for(int i=0; i<=153; i++)
    analogWrite(forward_in1, i);
    analogWrite(reverse_in2,0);
    analogWrite(enA,153);
    delay(20);
  //Hold at this speed
void go_reverse()
{ //Increase speed from 0 -> 102
  for(int i=0; i<=102; i++)
    analogWrite(forward_in1,0);
    analogWrite(reverse_in2,i);
    analogWrite(enA,102);
    delay(20);
{ //Decrease speed from 153 -> 0
  for(int i=153; i>=0; i--)
    analogWrite(forward_in1,i);
    analogWrite(enA,0);
    delay(10);
  //Hold at zero
{ //Decrease speed from 102 -> 0
  for(int i=102; i>=0; i--)
    analogWrite(enA,0);
    delay(10);
  //Hold at zero
void turn_right()
  digitalWrite (right_in3, HIGH);
  digitalWrite (left_in4, LOW);
  analogWrite (enB, 255);
void turn_left()
  digitalWrite (left_in4, HIGH);
  digitalWrite (right_in3, LOW);
  analogWrite(enB, 255);
void stop_device()
  analogWrite (forward_in1, 0);
  analogWrite (reverse_in2, 0);
  analogWrite(enA,0);
  analogWrite(enB,0);
void detect_right_wall ()
  // PING))) 1
  cm1 = DistanceSensor1.ping_cm();
  pinMode(pingPin1, OUTPUT);        // initialize the pingPin1 as output (Trigger):
  digitalWrite(pingPin1, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin1, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin1, INPUT);         // initialize the pingPin1 as an input to receive echo:
  duration1 = pulseIn (pingPin1, 10);
  Serial.print ("Duration 1:");
  Serial.println (duration1, DEC);
  Serial.print("cm1 = ");
  Serial.println(cm1);
  if ((duration1 > 4000 || duration1 == 0))
    Serial.println("There is no wall on the right");
    right_wall_detected = true;
    Serial.println("There is a wall on the right");
  // PING))) 2
  cm2 = DistanceSensor2.ping_cm();
  pinMode(pingPin2, OUTPUT);
  digitalWrite (pingPin2, LOW);
  delayMicroseconds (2);
  digitalWrite (pingPin2, HIGH);
  delayMicroseconds (5);
  pinMode(pingPin2, INPUT);
  duration2 = pulseIn (pingPin2, 10);
  Serial.print ("Duration2:");
  Serial.println (duration2, DEC);
  Serial.print("cm2 = ");
  Serial.println(cm2);
  if ((duration2 > 4000 || duration2 == 0)) {
    Serial.println("There is no wall on the left");
  else {
    left_wall_detected = true;
    Serial.println("There is is a wall on the left");
  go_forward();
  delay (5000);
  detect_left_wall();
  if (right_wall_detected == false && left_wall_detected == false)
    go_forward();
    if (right_wall_detected == true && left_wall_detected == true)
      forward_brake();
      stop_device();
      do
        go_forward();
        detect_left_wall();
        delay(3000);
      }while(cm1 > 40.00 && cm2 > 40.00);
      forward_brake();
      delay(2000);
      stop_device();
      if (right_wall_detected == false && left_wall_detected == true)
        forward_brake();
        stop_device();
        detect_left_wall();
        delay(100);
        do
          go_forward();
          detect_left_wall();
        }while(cm2 > 40);
        forward_brake();
        delay(100);
        stop_device();
        turn_right(), go_forward();
        forward_brake();
        stop_device();
        delay(250);
        if (right_wall_detected == true && left_wall_detected == false)
          forward_brake();
          stop_device();
          delay(200);
          do
            go_forward();
          }while(cm1 > 40);
          forward_brake();
          stop_device();
          turn_left(), go_forward();
          forward_brake();
          stop_device();
          delay(100);
oyegbadetunde:
Hello,
It appears you're not using NewPing at all in your sketch, only loading the library (which will do nothing).
Tim
teckel:
Tim
Ok Sir, is there any way out for me? What portion of the code should I edit that will make the NewPing work and my toy go forward and backward and sidewards? Thanks a lot for your swift response.
oyegbadetunde:
Start with the NewPing example sketches. Understand how NewPing works instead of how you're controlling your ultrasonic sensors currently. Then, you could incorporate NewPing in your sketch.
This thread would be the place to ask if you're having a problem getting NewPing to work. The logic in translating that data to motor control would be outside the scope of this thread.
Tim
teckel:
Tim
ok Sir, to be candid, I would love to see a code written for parallax PING))) as I have seen yours on HC-SR04 and others, but i haven't seen that of parallax PING))). The toy doesn't go forward, is there anyway that my PING))) sensor is interfering with PWM?
oyegbadetunde:
There's an example of communicating with a sensor using only one pin on the NewPing Library homepage:
NewPing Library Homepage - Single Pin Example Sketch
There's no difference between using a PIGN)), HC-SR04, or any other sensor. All sketches work with all compatible sensors.
Tim
teckel:
Tim
I've read the contents of the link you referred me to, and have seen where I needed to make the corrections.
Thanks for your kind help in referring me to where I was going to find all the help I needed. I really appreciate... God bless you real good.
