Goal: Have the rfid tag on my cats collar trigger the feeder to activate
I disassembled the cat feeder and connected the motor to the Arduino. It runs off a digital out pin just fine. The LCD displays everything well. I think the error is in my code. I opted for using a series of if statements but I can also see how while statements could have been used instead.
Problem: When the code runs it ends up displaying to the LCD "wait for 429417 [minutes]"
Disclaimer: I am quite new to this language. I have experience in r, however.
//LCD
//• Displays the time until the next availble feeding
//• TIME: HH:mm
//• adjusted with an hour and minute button
// • LAST FED: HH:mm
//• When a feeding is activated, a time counts down the time until the next feeding
// • FEEDING DELAY: mm:ss
//RFID/MOTOR
//• When card is scanned
//• Motor activates for 1 second
//• deactivates for 3 minutes
//• Constraints: allow only 2 feedings every 8h
#include <MFRC522.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
#define SS_PIN 53
#define RST_PIN 5
#define MOTOR_PIN 2
const long MOTOR_ON_TIME = 1000; //1sec
const long MOTOR_OFF_TIME = 10000; //3min 180000
const long MOTOR_LIMIT = 28800000; //8 hours: The wait after MAXfeedings is reached
unsigned long lastMillis = 0;
unsigned long feedings = 0;
unsigned long MAXfeedings = 3; //set the max number of feeding for the MOTOR_LIMIT
bool scanning = false;
MFRC522 rfid(SS_PIN, RST_PIN);
lcd.init();
rfid.PCD_Init();
lcd.backlight();
SPI.begin();
pinMode(MOTOR_PIN, OUTPUT);
lcd.print("Setup Complete");
delay(5000);
lcd.clear();
unsigned long currentMillis = millis(); //set the current time
//If the time from the last feeding is more than 8h then reset feedings
if(currentMillis < lastMillis + MOTOR_LIMIT){
feedings = 0;
if(feedings >= MAXfeedings){
feedings = 0;
const int hours = (MOTOR_LIMIT - (currentMillis - lastMillis))/1000/60/60;
const long min = (MOTOR_LIMIT - (currentMillis - lastMillis))/1000/60 - (hours * 60);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Wait for: ");
lcd.print(hours);
lcd.print("h ");
lcd.print(min);
lcd.print("m");
delay(100);
return;
} else if(currentMillis >= lastMillis + MOTOR_OFF_TIME){
lcd.clear();
//print the seconds until the feeding is an option to the lcd
lcd.print((MOTOR_OFF_TIME - (currentMillis - lastMillis))/1000);
lcd.print("s");
delay(100);
return;
lcd.print("Scanning");
delay(100);
scanning = true;
if(scanning == false){
return;
} else if(!rfid.PICC_IsNewCardPresent()){
return;
feedings = feedings + 1; //increment feedings up one
lastMillis = currentMillis; //set the last feeding to now
lcd.print("Dispensing"); //print to lcd
delay(3000) ; // wait 3 seconds while lcd is on
digitalWrite(MOTOR_PIN, HIGH); //activate motor
delay(1000); //wait 1 sec
digitalWrite(MOTOR_PIN, LOW); //de-activate motor
return;
