Hae . am having trouble ending the while loop, when the sensor value reaches threashold the lcd displays fire alarm but when the value is less than threshold the lcd still display the same text
Flame_detected =analogRead(Flame_sensor);
digitalWrite(relay_pin, HIGH);
while (Flame_detected <=threshold)
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("!ALERT!ALERT!");
lcd.setCursor(0, 1);
lcd.print("Fire in the house");
delay(2000);
myservo.read();
if ( pos == 0) {
  myservo.attach(10);
  myservo.write(100);
  delay(200);
  myservo.detach();
  myservo.write(0);
  delay(200);
Serial.println("Flame detected...! take action immediately.");
while (sms_count < 2) //Number of SMS Alerts to be sent limited at 3
  alertMessage(); // Function to send AT Commands to GSM module
key_pressed = keypad_key.getKey();
if (key_pressed == '#')
change();
if (key_pressed)
password[i++] = key_pressed;
lcd.print(key_pressed);
tone(buzzer, 800, 200);
if (i == 4)
delay(200);
for (int j = 0; j < 4; j++)
  initial_password[j] = EEPROM.read(j);
if (!(strncmp(password, initial_password, 4)))
  delay(300);
  lcd.clear();
  lcd.print("Pass Accepted");
  digitalWrite(relay_pin, LOW);
  delay(2000);
  lcd.print("Pres # to change");
  delay(2000);
  lcd.clear();
  lcd.print("Enter Password:");
  sms_count = 0;
  i = 0;
    passMessage(); // Function to send AT Commands to GSM module
  lcd.clear();
  lcd.print("Wrong Password");
  lcd.print("Pres # to Change");
  delay(2000);
  lcd.clear();
  lcd.print("Enter Password");
  i = 0;
void change()
int j = 0;
lcd.clear();
lcd.print("Current Password");
while (j < 4)
char key = keypad_key.getKey();
if (key)
  new_password[j++] = key;
  lcd.print(key);
key = 0;
if ((strncmp(new_password, initial_password, 4)))
lcd.clear();
lcd.print("Try Again");
j = 0;
lcd.clear();
lcd.print("New Password:");
while (j < 4)
  if (key)
    initial_password[j] = key;
    lcd.print(key);
    EEPROM.write(j, key);
    j++;
lcd.print("Pass Changed");
lcd.clear();
key_pressed = 0;
void initialpassword() {
EEPROM.write(j, j + 49);
Please follow the advice given in the link below when posting code. Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
You don't appear to be updating Flame_detected inside the while loop
shouldn't there be two actions depending on the value of the flame sensor.
the condition of the while will never change once it's true because the sensor is not read within the loop
consider
const byte pinSensor = A2;
const int  Threshold = 500;
int   sms_count = 0;
    if (Threshold < analogRead (pinSensor))  {
        Serial.println ("all clear");
        sms_count = 0;
    else  {
        Serial.println ("Alert");
        if (sms_count++ < 3)
            Serial.println (" send sms");
    delay (500);
void setup ()
    Serial.begin (9600);
