Hairless Midi "Warning:got a status byte..."
Hello!
I'm new to the forum, and attempting to trigger midi notes using an FSR. In hairless debug, I'm receiving the error:
Warning: got a status byte when we were expecting 1 more data bytes, sending possibly incomplete MIDI message 0x90
and:
Warning: got a status byte when we were expecting 2 more data bytes, sending possibly incomplete MIDI message 0xa2
I've read the other post about this, and changed the baud to 115200. Didn't help. Setting flow control to XON/XOFF seems to help for 80% of these errors. It is sending the notes, but It keeps crashing hairless. Any help would be appreciated :wink:
Code:
//credit to thedude77 & rogue
int fsrC = 0;                  //FSR is on pin 0
int fsrVal = 0;                //variable for reading FSR value
int mappedFsrVal = 0;          //variable for holding remapped FSR value
  Serial.begin(115200);            //MIDI communicates at 31250 baud
void loop(){
   fsrVal = analogRead(fsrC);         //read input from FSR
   mappedFsrVal = map(fsrVal, 0, 127, 0, 127);  //map value to 0-127
   if(analogRead(fsrC)){
     midiOUT(0xB0, 6, mappedFsrVal); //CC Volume message
     midiOUT(0x90, 60, mappedFsrVal); //MIDI noteOn message/Ply Middle C
     prevFsrVal = mappedFsrVal;
    delay(250);
void midiOUT(char command, char value1, char value2) {
  Serial.print(command);
  Serial.print(value1);
  Serial.print(value2);
I'd like to add that I'm using the serial conversion method because I've tried two different builds of the "direct-as-midi" firmware, both of which don't seem to function on the ATMega16u2.
After the flash and reset, it simply isn't recognized by the arduino compiler. So, back to the stock firmware...
Should be remapped, something like:
mappedFsrVal = map(fsrVal, 0, 1000, 0, 127);  //map value to 0-127
I received this error a lot at first while setting up my project. Make sure to try each of the settings, even all the baud rate options to see which eliminates the problem.
