Hall count RPM meter won't reset to zero
Ive made a simple RMP meter using a hall trip counter. It outouts to a PWM line then feeds a RC filter and bar graph.
My problem is when the trip count falls to zero, the PWM output still reflects the last calculated trip.
How do i make it set to zero when the trip is zero?
int hall_pin = 2;
// set number of hall trips for RPM reading (higher improves accuracy)
float hall_thresh = 10.0;
const int outPin1 = 6;
//TCCR4B = TCCR4B & B11111000 | B00000001;    // set timer 4 prescaler to 1 for PWM frequency of 31372.5 Hz
    pinMode(hall_pin, INPUT);
  pinMode (outPin1,OUTPUT);
    float hall_count = 1.0;
  float start = micros();
  bool on_state = false;
  // counting number of times the hall sensor is tripped
  // but without double counting during the same trip
  while(true){//keeps running while true but what makes it true?
    if (digitalRead(hall_pin)==0){//every time hall is switched to 0 run if
      if (on_state==false){//already set to false so make true
        on_state = true;
        hall_count+=1.0;//count = (hall_count + 1.0) + new value of hall_count
    } else{
      on_state = false;
       if (hall_count>=hall_thresh){
    // print information about Time and RPM
  float end_time = micros();
  float time_passed = ((end_time - start)/1000000.0); //micros now - start micros/1second
 Serial.print("Time Passed: ");// in seconds
 Serial.print(time_passed);
 Serial.println("s");
  int rpm_val = (hall_count/time_passed)*60.0;
  Serial.println(rpm_val);
   delay(1);        // delay in between reads for stability
 analogWrite (outPin1, (0.0255 * rpm_val));//255/10000 max scale * rpm. USE THIS
  delay(100); //allows all serial sent to be received together
I guess when the trip goes to zero, ignore all the PWM.
Paul
Sorry Paul, Could you please explain a bit more? How do I ignore PWM?
You could add a timer to break out of the "while (true)" loop if a full second has passed:
  if (micros() - start > 1000000.0)
That way if the speed falls to less than one revolution per second it will register 0.
You really should use 'unsigned long' for 'start', and 'end_time'. The divide by 1000000.0 will convert the difference to float for you.
