Hall Effect Sensor Recommendation
I have been working with a generic, inexpensive water flow sensor that utilizes a hall effect sensor. Sensor works fine, but it is drawing too much current. I need to prototype a battery operated version, so I am looking to replace the sensor with a more energy efficient chip. But, I have very limited knowledge on the Hall Sensors.
MCU is Arduino Micro
Any recommendations on specific part numbers to look at as a replacement.
If we don't know what you are using, now, how can we recommend another sensor? Are you looking for an analog sensor or a digital sensor? How do you have this one wired. And finally how much current is too much current?
Paul
The sensor is imbedded in the sensor so I don't know unless I destroy the housing. I have another broken sensor that has a W130 chip/sensor. I am guessing all these cheap flow sensors have the same or similar part.
With the sensor, SD breakout board from Adafruit, and Arduino Micro, I get about 5 days of data before my 16000mAh battery pack dies. Since I can't turn off the sensor I need something that is much ore efficient so I can get more like 1 month of data.
I have included photos of the sensor and board for reference.
You can find them on AliExpress and similar vendors. In your case I would shop for one that has a read switch. I believe Red is +, Black is -, and Yellow is output probably open collector.
**@gilshultz **
With a spinning ring magnet wouldn't the reed switch always be closed since there is always a magnetic field present?
Reed switches have limited cycles, which might be an issue.
Searching for "low power Hall switch" quickly found: https://www.allegromicro.com/en/products/sense/switches-and-latches/micropower-switches-latches/aps11700-760,
and I'm sure other manufacturers have similar devices. Another good search term would be "micropower".
@MarkT
Thanks for the link... funny enough I had just stumbled on that link. Also found a some options from Melexis.
Couple of questions... I have almost no experience in component terminology and datasheets.
  • What am I looking for on the data sheets to tell me what the current draw will be (Supply Current?)
  • Will an "Omni-polar" component work if the original was "Bi-Polar"?
  • What considerations do I need to be aware of with respect to output/signal voltage? Is there a threshold the Atmega chips need to be able to register?
  1. Supply current it is.
  2. omni-polar responds to both polarities of magnetic flux.
  3. Hall switches output a logic signal direct. Just be sure not to get an analog Hall sensor.
Note than most Hall switches have open-collector output and thus need INPUT_PULLUP
pin mode.
I ordered this TMR1202 DataSheet, and the recommended 0.1 micro cap.
Data says it has "CMOS push-pull output"... thinking this means it does NOT require the pull up resistor???
Parts won't arrive for a week or so. But thanks for the help!
lexical43:
I ordered this [
[/quote]
Correct.](http://www.farnell.com/datasheets/2814602.pdf)
