Hall effect Speedometer, Help to understand code or Bug ?
I'm using Arduino nano
I'm using Code that i've adapted from this topic/post :
https://forum.arduino.cc/index.php?topic=345156.msg2820766#msg2820766
The goal of this application is to determine the speed of a wheel from a HALL effect sensor
On the previous link 4 magnets have been used to detect the speed,
in my code, i'm using 2 magnets.
and here's the code that i'm using :
const byte LED_pin = 13;
// wheel radius in mm * 100 * 2 * ( pi * 10000 ) = 94.248000 mm circumference.
// 6 0's were used in scaling up radius and pi, 6 places are divided in the end
// and the units work out. You can use integers more accurate than float on
// Arduino at greatly faster speed. Both type of long can hold any 9-digits.
// Arduino variable type long long can hold any 19 digits is 19 place accuracy.
// if you work in Small Units and scale back later, integers are plenty accurate.
// remember, this value has to be divided by microseconds per turn.
const unsigned long wheel_circumference = 310000UL * 2UL * 31416UL; // = 94,248,000
// wheel circumference gets divided by microseconds, 1,000,000/sec (usec or us).
// wheel turns once for 94248000 mm/100 in 1000000 usecs =
unsigned long Speed = 0;
unsigned long PrevSpeed = 0;
volatile byte hall_rising = 0; // interrupt flag
volatile unsigned long irqMicros;
unsigned long startMicros;
unsigned long elapsedMicros;
unsigned long ledFlashStartMillis;
const unsigned long ledFlashWaitMillis = 10;
unsigned long displayStartMillis;
const unsigned long displayWaitMillis = 200;
void wheel_IRQ()
  irqMicros = micros();
  hall_rising = 1;
  pinMode( 2, INPUT_PULLUP ); // pin # is tied to the interrupt
  pinMode( LED_pin, OUTPUT );
  Serial.begin( 9600 ); // can this be faster? faster would be better
  Serial.println(wheel_circumference);
  delay( 1000 );
  attachInterrupt( 0, wheel_IRQ, FALLING ); // pin 2 looks for HIGH to LOW change
  static unsigned long loopCount = 0; // I expect loop() runs > 33KHz
  if ( hall_rising == 1 )
    digitalWrite( LED_pin, HIGH );
    elapsedMicros = irqMicros - startMicros;
    startMicros = irqMicros;
    ledFlashStartMillis = millis();
    hall_rising = 2;
  else if  ( hall_rising == 2 )
    if ( millis() - ledFlashStartMillis >= ledFlashWaitMillis )
      digitalWrite( LED_pin, LOW );
      hall_rising = 0;
  if( elapsedMicros != 0 )
    Speed = (wheel_circumference * 0.0018) / elapsedMicros;
    //Speed = (wheel_circumference * 0.0009) / elapsedMicros;
 //. here i added a coefficient that means i'm converting to km/h so it's micrometers *3600 / 10^6 and /4 (num of //.magnets)
    if ( Speed != PrevSpeed )
      Serial.print( Speed ); // this now shows mm/sec with no remainder
      Serial.println( "km/h" );
      loopCount = 0; // HERE IS THE FIX JUST THIS ONE LINE ADDED
    PrevSpeed = Speed;
if(elapsedMicros > 200000)
  Speed = 0;
the code itself is quite understandable but i'm a bit lost with maths calculus...
my wheel radius is 31 cm so i've adapted wheel_cirumference like so :
and i've adapted coefficient for 2 magnets :
4 magnets =  Speed = (wheel_circumference * 0.0009) / elapsedMicros;
2 magnets =  Speed = (wheel_circumference * 0.0018) / elapsedMicros;
the output looks correct, but i've a bug :
Example :
1452 km/h
19 km/h
1454 km/h
19 km/h
1520 km/h
19 km/h
1458 km/h
19 km/h
1460 km/h
i could simply, on a dirty way remove all values >100 km/h and get a clean output but i'd like to understand the cause.
Thank you,
4 magnets = Speed = (wheel_circumference * 0.0008) / elapsedMicros;
So, 8 * 2 is 18 in your world?
What is the purpose of loopCount? You only assign it a value of 0.
Your code is incomplete.
my bad,
yes, it was wrong typing
Speed = (wheel_circumference * 0.0009) / elapsedMicros; for 4 magnets
Speed = (wheel_circumference * 0.0018) / elapsedMicros; for 2 magnets
loopcount is not used anymore, it was a previous statement to printf/counter the number of wheel loop...
Please edit your post to put the code inside code tags, not quote tags.
