Here is the code I tried:
- Water Flow Gauge
- Uses a hall-effect flow sensor to measure the rate of water flow and
- output it via the serial connection once per second. The hall-effect
- sensor connects to pin 2 and uses interrupt 0, and an LED on pin 13
- pulses with each interrupt. Two volume counters and current flow rate
- are also displayed on a 2-line by 16-character LCD module, and the
- accumulated totals are stored in non-volatile memory to allow them to
- continue incrementing after the device is reset or is power-cycled.
- Two counter-reset buttons are provided to reset the two accumulating
- counters. This allows one counter to be left accumulating indefinitely
- as a "total" flow volume, while the other can be reset regularly to
- provide a counter for specific events such as having a shower, running
- an irrigation system, or filling a washing machine.
- Copyright 2009 Jonathan Oxer jon@oxer.com.au
- Copyright 2009 Hugh Blemings hugh@blemings.org
- This program is free software: you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation, either version 3 of the License, or
- (at your option) any later version. Licenses - GNU Project - Free Software Foundation
www.practicalarduino.com/projects/water-flow-gauge
123456789abcdef
1239.4L 8073.4L
// Specify the pins for the two counter reset buttons and indicator LED
byte resetButtonA = 11;
byte resetButtonB = 12;
byte statusLed = 13;
//byte sensorInterrupt = 0; // 0 = pin 2; 1 = pin 3
//byte sensorPin = 2;
byte sensorPin = 2;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
//float calibrationFactor = 4.5;
float calibrationFactorHeat = 4.53.785411.1; //adjustment to gallons and calibration green wire heat pump
float calibrationFactorHot = (4.53.78541) 1.30; //adjustment to gallons and calibration white wire hot water
volatile byte pulseCount;
float flowRate;
unsigned int flowGallons;
unsigned long totalGallonsA;
unsigned long totalGallonsB;
unsigned long oldTime;
unsigned long ElapsedMilliseconds;
// Initialize a serial connection for reporting values to the host
// Set up the status LED line as an output
pinMode(statusLed, OUTPUT);
digitalWrite(statusLed, HIGH); // We have an active-low LED attached
// Set up the pair of counter reset buttons and activate internal pull-up resistors
pinMode(resetButtonA, INPUT);
digitalWrite(resetButtonA, HIGH);
pinMode(resetButtonB, INPUT);
digitalWrite(resetButtonB, HIGH);
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount = 0;
flowRate = 0.0;
flowGallons = 0;
totalGallonsA = 0;
totalGallonsB = 0;
oldTime = 0;
ElapsedMilliseconds = 0;
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
- Main program loop
if(digitalRead(resetButtonA) == LOW)
totalGallonsA = 0;
if(digitalRead(resetButtonB) == LOW)
totalGallonsB = 0;
if( (digitalRead(resetButtonA) == LOW) || (digitalRead(resetButtonB) == LOW) )
digitalWrite(statusLed, LOW);
if((millis() - oldTime) > 1000) // Only process counters once per second
// Disable the interrupt while calculating flow rate and sending the value to
// the host
detachInterrupt(sensorInterrupt);
//lcd.setCursor(15, 0);
//lcd.print("*");
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
// flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactorHeat;
flowRate = ((((millis() - oldTime) / 1000) * pulseCount) / calibrationFactorHeat);
// Note the time this processing pass was executed. Note that because we've
// disabled interrupts the millis() function won't actually be incrementing right
// at this point, but it will still return the value it was set to just before
// interrupts went away.
// added next line
ElapsedMilliseconds = ((millis()-oldTime) + millis());//corrected millis use for cals
Serial.print(millis()-oldTime);
Serial.println(" (millis()-oldTime)");
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to Gallons.
// flowGallons = (flowRate / 60) * 1000;
//flowGallons = (flowRate / ElapsedMilliseconds) * 1000; //changed to this
// Add the Gallons passed in this second to the cumulative total
totalGallonsA += flowGallons;
totalGallonsB += flowGallons;
// During testing it can be useful to output the literal pulse count value so you
// can compare that and the calculated flow rate against the data sheets for the
// flow sensor. Uncomment the following two lines to display the count value.
Serial.print(pulseCount, DEC);
Serial.println (" pulseCount");
// Write the calculated value to the serial port. Because we want to output a
// floating point value and print() can't handle floats we have to do some trickery
// to output the whole number part, then a decimal point, then the fractional part.
unsigned int frac;
// Print the flow rate for this second in litres / minute
Serial.print(int(flowRate)); // Print the integer part of the variable
Serial.print("."); // Print the decimal point
// Determine the fractional part. The 10 multiplier gives us 1 decimal place.
frac = (flowRate - int(flowRate)) * 10;
Serial.print(frac, DEC) ; // Print the fractional part of the variable
Serial.println(" GPM ");
// Print the number of litres flowed in this second
// Serial.print(flowGallons);
// Serial.println(" Flow Gallons "); // Output separator
// Print the cumulative total of litres flowed since starting
Serial.print(totalGallonsA/1000);
Serial.println(" Total Gallons A"); // Output separator
Serial.print(totalGallonsB/1000);
// if(int(flowRate) < 10)
// lcd.print(" ");
// Reset the pulse counter so we can start incrementing again
pulseCount = 0;
// Enable the interrupt again now that we've finished sending output
Serial.println(""); // Output separator
- Invoked by interrupt0 once per rotation of the hall-effect sensor. Interrupt
- handlers should be kept as small as possible so they return quickly.
void pulseCounter()
// Increment the pulse counter
pulseCount++;
