I want to use an arduino to tell when a mains-electric (220 volts) device is switched on/off.
Basically, I have a set of security lights in my yard that switch on/off automatically when something moves past them. I'd like to record when this happens. One option is to hack each light, and tap into the light-bulb circuit and note when 220 volts is present. This would require extra wiring, and involves playing with potentially lethal voltages.
The other option might be to place a hall-probe next to the supply cable and detect the magnetic field created when current starts to flow. Would this work? is it practical? Is there a better way? I've played with hall probes before, but the ones I've used only trigger when a pretty heavy magnetic field is present, would one detect the low magnetic field from a current-carrying cable?
