Hall Sensor False Readings
Hello and thank you for reading this.
If I get my Hall Sensor and/or Arduino within 4 ft of a large linear actuator I am using the Hall Sensor measures false readings when the sensor should read zero.
Why does this happen? They share no common power sources or electrical wiring.
Thank you.
SunFounder Switch Hall Sensor Module for Arduino and Raspberry Pi)
