I use it as an interrupt and the sensor works perfectly when connected and tested with the digital pin on Arduino.
Because I am already using both the digital pins of ATtiny, I am connecting the sensor to the analogue pin of ATtiny but I am not getting the expected result.
I tried to use the digital pin to debug my code. But I want to make if the sensor is intended to work with digital pin only? or it can also work with the Analogue pin ?
You can't use the analogue pin to generate an interrupt.
Can you redeploy one of your other digital signals to the analogue pins and use a real digital pin?
Any signal that works with a digital input pin (0V, 5V) will work with an analog input. The analogRead() function will return a value near 0 for logic LOW signals and a value near 1023 for logic HIGH signals. Compare the returned value with 512 (mid range) to get a logic value.
Most (but not all) analog input pins can also be used for digital inputs and outputs. I don't know if the core you are using supports this or not.
