Hall Sensor Set Up
Board: Arduino Micro
Hall Sensor: U18007
Hi all,
I'm trying to build a large encoder using two hall sensors in series. I've managed to program the hall-sensors using interrupts from a previous project using the following code. But the output points at an issue with the way I set up the Hall Sensor:
const byte ledPin = 13;
const byte interruptPinA = 2;
volatile byte state = LOW; //LOW
  pinMode(ledPin, OUTPUT);
  pinMode(interruptPinA, INPUT_PULLUP); //pullup
  attachInterrupt(digitalPinToInterrupt(interruptPinA), blink, CHANGE);
  digitalWrite(ledPin, state);
  Serial.println(digitalRead(interruptPinA));
  delay(1);
void blink() {
  state = !state;
The problem I am having is: the Monitor starts printing 0s - until I approach the magnet to the sensor, after which the LED turns on and it starts printing 1s - then when I remove the magnet, the state of the sensor does not change back (keeps printing 1s), nor the LED off. How can I change the code so that it does? I tried using the RISING, FALLING, etc arguments in the attachInterrupt() with no avail. I have no resistors in the circuit.
Monitor:
0
0
0
1 // after magnet is near the sensor
1
1
1
1 // magnet is moved away
1
1
1
1
0 // magnet is near again but this time with the opposite pole near the sensor
0
0
0
The only way I can get it to change back to 0s and shut off the LED is nearing the magnet with the opposite pole that I used to trigger it.
I also tried changing it to a regular input instead of (INPUT_PULLUP) in case its not the common type of Hall Sensor - that didn't work either.
Any help is much appreciated!
Just figured out the Hall Sensor is of the latching type - therefore it stays on. Getting another one that is non-latching since I can't figure out how to make the encoder work with the oppositely charged magnets in series.
See the StateChangeDetection example.
