Handheld cordless phone
Hello guys,
I am trying to build a walkie talkie. My idea is to be able to communicate with 10 people or 7 at least, without any interference from other then the guys who has the device.
(Q1) What transmitter should i use that willl achieve high range ? ...
i was looking up FM transmitters and i thought at 433MHz will be the highest range, with the proper antenna. but now am confused ?!
(Q2)iIsnt FM in the range of 87.5 to 108.0 MHz ? why then 433MHz , 315 , 868MHz availability ?
(Q3) will arduino be suffecient for such project ? i already built the amplifiers and such , just the transmitter is missing and if i will use arduino , then i have to do dsp programming
Peace
A few concepts:
FM (Frequency Modulation) can be used at any RF frequency; 88-108Mhz is commercial FM broadcasting in USA.
Many different modules that operate at many different frequencies are available. You probably need to experiment.
And Questions:
  • What is "Highest Range"??
  • What would the Arduino do?
  • What Digital Signal Processing do you expect to need? Why?
  • How many users? How would you organize "Who is talking now"??
Usual Engineering: More questions at the start!
terryking228:
A few concepts:
And Questions:
  • What is "Highest Range"?? more then 500meters is good, the highest the better . so if 2 km line of sight i think it will be perfect but if less then it is ok .. As far as i understand the lower the frequency the higher the range (with factors like :antenna gain , Rx sensitivty , tx gain)... the factor i want to avoid is an ugly big antenna,
  • What would the Arduino do? The arduino will work to process the voice (ADC in ) (DAC out) and program the transmitter... if you have a better option then that please enlighten me
    if you mean by modulation techniques such as FSK ,PSK, frequency hopping .. then i cant decide yet.. whatever that can give secure communication and reduce or prevent interference.... i think so far frequency hopping is the best , but i have 0 experience programming any actually..
    users upto 10 ... the one who switches first the talk button (transmit) the rest must listen
Thanks dear terryking228 for the quick smart response. please check my answers above
