Handle Bluetooth Connection Lost
Hello.
I'm developing an arduino program for control a set of WS2812 Leds with the phone.
I've made an android app that simulates the typical controller behaviours and add a couple more of funcionalities. The data is sent to the arduino throught the bluetooth using a byte buffer. Then the arduino checks if there is data available and reads it storing in a uint_16t.
All the connection works good except when this is lost, the character that is sent from the BT when the connection is lost is readed as a control code and produces errors.
So, how can i ignore that character or avoid to be sent?
The bluetooth module that i use is the JDY 31
oscarvx:
You need to post your Arduino program.
If a character is received it suggests that the connection has not actually been lost - more likely that the sender and receiver have become out of sync with each other.
...R
This is the code of the app:
private class ConnectedThread{
        private final BluetoothSocket socket;
        private final OutputStream outputStream;
        public ConnectedThread(BluetoothSocket ss){
            socket = ss;
            OutputStream OS = null;
            try{
                OS = socket.getOutputStream();
            } catch (IOException e){}
            outputStream = OS;
        public void write(byte[] bytes){
            try{
                outputStream.write(bytes);
                Log.d("Data send:", bytes.toString());
            } catch (IOException e) {}
        public void cancel(){
            try{
                socket.close();
The method write(byte[] bytes) its called when an option is selected, the codes are integers between 00010-34000
This method creates the message:
   public void onCodeToSend(short code) {
        byte [] buff = intToBytes(code);
        int newDim = buff.length + 1;
        char c = '*';
        buff = Arrays.copyOf(buff, newDim);
        buff[newDim - 1] = (byte) c;
        if(buff != null) connectThread.connectedThread.write(buff);
        else Toast.makeText(this.getBaseContext(), "Buffer null", Toast.LENGTH_SHORT);
     public byte[] intToBytes(short x){
        return ByteBuffer.allocate(Short.BYTES).putShort(x).array();
On the arduino i have this functions:
Main loop:
  if(Serial.available()){
    uint16_t code;
    code = readData();
    delay(25);
    clean_buffer();
    delay(25);
    switch(code/10000){
      case 1:
        manual(code);
      case 0:
      case 2:
        automatico(code);
      default:
        //Serial.println("Error");
        clean_buffer();
   clean_buffer();
   delay(25);
Function used to read the data from the BT:
uint16_t readData(){
  char endMarker = '*';
  byte bytes[2];
  int i = 0;
  char c;
  boolean newData = false;
  while(Serial.available() > 0 && !newData){
    c = Serial.read();
    delay(50);
    if(c != endMarker){
      bytes[i] = (byte)c;
      i++;
    else{
      newData = true;
  uint16_t val = byteToLong(bytes[0], bytes[1]);
  return val;
uint16_t byteToLong(byte byte1, byte byte2){
  return byte1 << 8
        | byte2;
Then i have code for control the stips, in some sequences that are in a infinite loop the input is checked every iteration:
while(true){
do_strip_control()
          return_to_main;
The problem becomes when I close the app or a time is elapsed and the sync is lost, some type of control message is sent.
Please just post the complete program in one piece so we don't have to join the parts.
...R
