Hi All,
I'm starting to get the hang of this but hit a slight snag on my WEMOS D1 Mini.
I'm a little lost on how to get the desired output format of some data from a GET processed by ArduinoJson.h
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
The code parses a data string returned from a url in on eof the following formats:
Positive percentage:
{"percent":"1.464","firstId":3411890,"lastId":3433557,"count":21668}
Or Negative percentage:
{"percent":"-0.382","firstId":3411890,"lastId":3433557,"count":21668}
JSON Code:
// Get JSON data
jsonAnswer = answer.substring(jsonIndex);
//Serial.println();
//Serial.println("JSON answer: ");
//Serial.println(jsonAnswer);
jsonAnswer.trim();
int newIndex = jsonAnswer.indexOf("percent");
String chgString = jsonAnswer.substring(newIndex + 11, newIndex + 15);
Serial.print("chgString = ");
Serial.println(chgString);
In the first instance (positive), I get the string chgString set correctly to "1.46"
However, when the string is negative and has a "-" in front of it I obviously lose a character to that and get "-0.3" instead missing a decimal point.
My question is how do I handle this issue?
The only way I can think of currently is to allow for an extra character so take characters 11-16 from string then do some kind of check to see the starting character of the string then if it starts with a "-" somehow print 4 characters of the string else print all 5 characters?
Is this the best way or is there something better?
Any chance of some pointers? and to push my luck maybe some basic code thrown in too?
Thanks
P
