Handling multiple datatypes received from serial connection. ?
The Sketch I'm working on is receiving the following data:
(StartBit)(DataType,Item,CurrentValue,MaxValue)(StopBit)
The First two values are always integers, but the last two could be other types Ints, Floats, Doubles, Bool, or null.
Depending on what the second element (Item) is I was going to switch case for display on various components (some are OLED, some are LED Bar graphs, some are just plain LEDs)
I have code working at the moment that assumes everything received is an integer, however I need to change it and am running into a wall as to the best method since I don't know the data types until the first element of each series is processed.
/*-----( Import needed libraries )-----*/
/*-----( Declare Constants and Pin Numbers )-----*/
int led = 13;
/*-----( Declare objects )-----*/
/*-----( Declare Variables )-----*/
const byte numChars = 32;
char receivedChars[numChars];
boolean message = false;
  pinMode(led, OUTPUT);      // sets the digital pin as output
  Serial.begin(115200);  //set serial to 115200 baud rate
                      //Serial String Format (StartBit)(DataType,Item,CurrentValue,MaxValue)(StopBit)
                      //StartBit = "\x02"
                      //DataType = Integer value starting from 1. Indicates if values are Int, Float, Bool, etc.
                      //Item = Number begining with 1. Indicates what the value is i.e. Health, speed, dampers.
                      //CurrentValue = can be any type as indicated by DataType
                      //MaxValue = can be any numeric as indicated by DataType
                      //StopBit = "\x03"
	recvData();
	processMessage();
void recvData()
	static boolean recvInProgress = false;
	static byte ndx = 0;
	//char startMarker = 0x2;
	//char endMarker = 0x3;
        char startMarker = '<';
	char endMarker = '>';
	char rc;
	// if (Serial.available() > 0) {
        while (Serial.available() > 0 && message == false) {
		rc = Serial.read();
		if (recvInProgress == true) {
			if (rc != endMarker) {
				receivedChars[ndx] = rc;
				ndx++;
				if (ndx >= numChars) {
					ndx = numChars - 1;
			else {
				receivedChars[ndx] = '\0'; // terminate the string
				ndx = 0;
				message = true;
		else if (rc == startMarker) {
			recvInProgress = true;
void processMessage()
          char delimiter[]= ",";
          char* valPosition;
          int integerarray[] = {0};
          int dataType = 0;
          int i=0;
          String serialDebug = "";
	if (message == true)
		            Serial.println(receivedChars);
                //This initializes strtok with our string to tokenize
                valPosition = strtok(receivedChars, delimiter);
                 //if(valPosition == 1)
                 // dataType = atoi(valPosition);
            //here is where I'm stuck
                 while(valPosition != NULL)
                    integerarray[i] = atoi(valPosition);
                    valPosition = strtok(NULL, delimiter);
                    i++;
                    //serialDebug = " Array of ";
                    //serialDebug +=  i,DEC ;
                    //serialDebug += " integers created.";
                    //Serial.println(serialDebug);
		message = false;
    //Message received:
                digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
                delay(1000);               // wait for a second
                digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
What do you mean "could be"? Don't you KNOW what you are sending?
So, what is the problem? The simplest thing to do is to read the data, starting to store data when the start of packet marker arrives, stopping when the end of packet marker arrives. When the end of packet marker arrives, start parsing the stored data.
During parsing, call atoi() or atof() depending on what you have received as the packet type.
Another solution would be to send everything as an integer. Your bool can be an integer.
To send a floating point type, multiply it by 1000, round to an integer, send the integer, divide by 1000 at the other end. Depending on your requirements.
Have a look at serial input basics. I think the 3rd example will meet your needs. There is also a parse example.
Unless you have to send data very quickly it is easiest just to send numbers as Ascii characters - and it makes debugging much easier.
...R
michinyon:
That is a good idea, and consequently why I didn't minor in math :wink:
