handling strings via bluetooth
greetings,
i'm trying to handle strings sent from android bluetooth to the arduino and vise versa.
for example if i send from the android string "hello" i can see it clearly at the serial port, however i can't deal with this string to "string compare" it for example to do an action or something, where i can only read single characters by serial read which are translated to asci code.
that's for recieving from the android to the arduino.
as for transmitting from the arduino to the android, i'm trying to get data from the serial port which is a hexadecimal reading of an infrared reciever and send this data as a string via bluetooth, where i use fprint to convert the hexadecimal which is "unsigned long int" to "string" but when i send this via bluetooth i get nothing or boxes.
NOTE:
   #include <SPP.h>
#include <IRremote.h>
USB Usb;
BTD Btd(&Usb);
SPP SerialBT(&Btd);
 IRsend irsend;
boolean firstMessage = true;
int i=0;
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
 irrecv.enableIRIn();
  if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while(1); //halt
  Serial.print(F("\r\nSPP Bluetooth Library Started"));
  Usb.Task();
  if(SerialBT.connected) {
    if(firstMessage) {
      firstMessage = false;
      SerialBT.println(F("Hello from Arduino")); // Send welcome message
    if(Serial.available())
      SerialBT.print(Serial.read());
    if(SerialBT.available())
    {  Serial.write(SerialBT.read());
    // delay(100);
    int a=0;
    char c;
    a=SerialBT.read();
   // c=SerialBT.read();
    SerialBT.println(a);
    if (irrecv.decode(&results)) {
    Serial.print(results.value, HEX);
    char buf[50];
   sprintf(buf, "test",results.value,HEX);
   SerialBT.println(buf);
   // i get test and nothing then//
    irrecv.resume();
Try #7 below:
http://arduino.cc/forum/index.php/topic,148850.0.html
Your code
is really
hard
to
read
White space is good to separate sections of code, but not acres of it, seemingly at
random.
It would also be better if it were in [code ] tags when pasted here. Highlight the code and click the # button above the smileys
As to your question, in order to do a comparison you need the incoming characters to be all in one variable. The preferred way to do this is to put each of them into an array as they arrive and then deal with the array as a whole when receipt of the message is complete.
I don't know much about sprintf but your use of it looks wrong to me. What you are doing looks more like an attempt to use the Serial.print syntax for printing in HEX
Actually i have put this code because it is the simplest of my attempts, but i have tried to use characters arrays and all sorts of these things for the first part but i have fialed.
this question requires c programming experience and u don't need actually to understand everything in this code like the bluetooth and infrared libraries.
