Handling TCP Data stream
I'm using ESPAsyncTCP with an ESP8266. I want to modify the program to send a larger amount of data. currently it is setup to send a single string but i want to send an array or struct. I need a way to orginize the data. I have a list of variables i would like to send to another esp module but how would i do this?
this is the example code im using i added a structer called sampleStruct this is the data i would like to send over tcp.
#include <ESP8266WiFi.h>
#include <ESPAsyncTCP.h>
extern "C" {
#include <osapi.h>
#include <os_type.h>
#include "config.h"
struct sampleStruct {
  int var1;
  float var2;
byte Array[20];
  unsigned long var3;
  unsigned long var4;
  unsigned long var5;
  unsigned long var6;
  unsigned long var7;
  unsigned long var8;
  bool var9;
static os_timer_t intervalTimer;
static void replyToServer(void* arg) {
	AsyncClient* client = reinterpret_cast<AsyncClient*>(arg);
	// send reply
	if (client->space() > 32 && client->canSend()) {
		char message[32];
		sprintf(message, "this is from %s", WiFi.localIP().toString().c_str());
		client->add(message, strlen(message));
		client->send();
/* event callbacks */
static void handleData(void* arg, AsyncClient* client, void *data, size_t len) {
	Serial.printf("\n data received from %s \n", client->remoteIP().toString().c_str());
	Serial.write((uint8_t*)data, len);
	os_timer_arm(&intervalTimer, 2000, true); // schedule for reply to server at next 2s
void onConnect(void* arg, AsyncClient* client) {
	Serial.printf("\n client has been connected to %s on port %d \n", SERVER_HOST_NAME, TCP_PORT);
	replyToServer(client);
	delay(20);
	// connects to access point
	WiFi.mode(WIFI_STA);
	WiFi.begin(SSID, PASSWORD);
		Serial.print('.');
	AsyncClient* client = new AsyncClient;
	client->onData(&handleData, client);
	client->onConnect(&onConnect, client);
	client->connect(SERVER_HOST_NAME, TCP_PORT);
	os_timer_disarm(&intervalTimer);
	os_timer_setfn(&intervalTimer, &replyToServer, client);
I've had a hard time trying to find documentation on this AsyncTCP server. Would i send each variable 1 at a time? How can i achieve what im trying to do?
I really need some advice please.
Looks to me like you would change:
		char message[32];
to:
client->add(ArrayOfStructs, sizeof ArrayOfStructs);
johnwasser:
		char message[32];
to:
I tried "client->add(sampleStruct, sizeof sampleStruct);"
when i try to compile if gives me this error,
expected primary-expression before ',' token
so i tried "client->add(&sampleStruct, sizeof sampleStruct);"
and got the same result. I have not found any documentation how to use the library either
I also tried this,
  int var1;
  byte Array[20];
  float var2;
  unsigned long var3;
  unsigned long var4;
  unsigned long var5;
  unsigned long var6;
  unsigned long var7;
  unsigned long var8;
  bool var9;
sampleStruct st;
	// send reply
//		char message[32];
//		sprintf(message, "this is from %s", WiFi.localIP().toString().c_str());
//		client->add(message, strlen(message));
//		client->send();
client->add(&st, sizeof(sampleStruct));
i get a different error,
exit status 1
no matching function for call to 'AsyncClient::add(sampleStruct*, unsigned int)'
Yes. Apparently you have to cast the pointer:
  // send reply
    client->add((char *)&st, sizeof(sampleStruct));
    client->send();
The error message tells you the line and character at which the error was detected.
Your previous error ("expected primary-expression before ',' token") was caused by trying to use a data type as a variable. The type 'enum sampleStruct' doesn't have an address. The variable 'st' does.
johnwasser:
// send reply
    client->send();
Thankyou that did the trick. I really really really appreciate the help
