Hey guys. for my arduino project i want to make a kind of hang man thing using the serial monitor. Im fairly new, so is this possible, and if so how can i do this?
I assume you are referring to the game where parts of the image are added for every wrong answer.
I can't think how you could construct the image on the Serial Monitor.
It may be possible to do it on a "better" terminal program such as puTTY which can (I think) take codes to position characters
Some sort of graphical program on the PC would be easier - but then why use an Arduino.
...R
Hi, for the Arduino to play hangman, it would need a large dictionary of words. Arduino do not have much memory to store this, so you would need to add external memory like an sd card. This is no longer a beginner's project.
It would be better to think of another game. Perhaps noughts & crosses ("tic tac toe")? Or some other logic/numbers game where the Arduino can use its ability to work at high speed with numbers to give you a challenge?
Paul
PaulRB:
Hi, for the Arduino to play hangman, it would need a large dictionary of words. Arduino do not have much memory to store this, so you would need to add external memory like an sd card. This is no longer a beginner's project.It would be better to think of another game. Perhaps noughts & crosses ("tic tac toe")? Or some other logic/numbers game where the Arduino can use its ability to work at high speed with numbers to give you a challenge?
The challange for a hangman game could also be based on math.
For example: The Arduino generates maths problems using the random number generator: Adding, subtracting, multiplying or dividing. The user is prompted the maths problem on the Serial monitor and can enter his input. And if the answer is wrong, the Arduino adds a line to his ASCII-art drawing until finished.
Serial.println(" _________ ");
Serial.println("| | ");
Serial.println("| 0 ");
Serial.println("| /|\\");
Serial.println("| / \\");
Serial.println("| ");
To make it more challanging, the math problems created could increase in digits/difficulty or the time limit for giving the correct answer might decrease during the game.
20 words would be enough. How many times are people going to re-play the game? Plenty of memory available for that.
I like Jurs' idea for drawing the hangman. Maybe add a line at the bottom which is drawn one "-" at a time, so you can see when you're nearing the end.
