Ok. I have a couple ethernet shields and I have one working with MQTT, which I bought from Radio Shack years ago. The seeed version. I bought another one to extend my home automation, but I am having trouble. I have tried several different libraries and can't get any of them to work except the EtherCard library. This library though, doesn't appear to work with the io.adafruit site. I have tried many of the examples for Ethernet, Ethernet_V2, UIPEthernet. Does anyone have any suggestions. I know the shield works, because it works with the EtherCard Library.
if it works with EtherCard Library, then it is a ENC28J60 chip. UIPEthernet should work with it.
only valid Arduino library for Wiznet chips is Ethernet library
btw. HanRan HR911105A is this:
I know exactly what it is. One that works is not the one in question which is from seeed. Referring to the enc28j60 chip. It doesn't work with the uipethernet, only with the EtherCard library. I never said it wasn't an enc28j60 chip, but thanks for trying to clarify. I probably should have made that clear in the first post.
stoneyguitar:
how does UIPEthernet fail?
you post's title say that you use a RJ45 connector by HanRan
