Happy Xmas POV display
Hi folks
I thought some one might be interested in this simple POV code which spells out Happy Xmas using LEDs on D2 to D10:-
int HappyXmas[50] = {254,16,16,254,0,62,72,72,62,0,63,68,68,56,0,63,68,68,56,0,0,114,9,9,126,0,0,198,40,16,40,198,62,96,62,96,62,0,62,72,72,62,0,36,82,74,36,0,0,0};
void setup() {:
for (int i=0; i< 20; i++) pinMode(i,OUTPUT);
for (int i=0; i< 20; i++) digitalWrite(i,LOW);
for (int j=0; j< 50; j++)
int Row = HappyXmas[j];
for (int i=0; i< 8; i++)
// LEds on D2 to D10.
if (Row == (Row/2)*2)digitalWrite(i+2,LOW); else digitalWrite(i+2,HIGH);
Row = Row >> 1;
delay(2);
delay(100);
There’s a : in there that will prevent the code from even compiling.
Too many ;'s around…
Why do you initialize D0 to D19 if you only use D2…D10 ?
Here’s a slightly modified version:
#define ARY_LEN(a) (sizeof(a)/(sizeof(a[0])))
int HappyXmas[] = {
    for  (int i = 0; i < 20; i++) pinMode(i,OUTPUT);
    for  (int i = 0; i < 20; i++) digitalWrite(i,LOW);
    for  (int j = 0; j < ARY_LEN(HappyXmas); j++) {
        for (int i = 0; i < 8; i++) {
            if (bitRead(Row, i)) {
                digitalWrite(i+2, HIGH);
            else {
                digitalWrite(i+2, LOW);
            Row = Row >> 1;
        delay(2);
    delay(100);
Edit: there’s an error: D2…D10 are 9 pins, so in fact you’re only using D2…D9
Here’s a 2nd revision:
// LEds on D2 to D9.
byte ledPins[] = {
    2, 3, 4, 5, 6, 7, 8, 9
const byte NUM_PINS = ARY_LEN(ledPins);
unsigned int HappyXmas[] = {
const byte NUM_ROWS = ARY_LEN(HappyXmas);
    for  (int i = 0; i < NUM_PINS; i++) {
        pinMode(i, OUTPUT);
        digitalWrite(i, LOW);
    for  (int j = 0; j < NUM_ROWS; j++) {
                digitalWrite(ledPins[i], HIGH);
            else {
                digitalWrite(ledPins[i], LOW);
        delay(2);
    delay(100);
Also, how is it all wired up ? The leds must be moving somehow I guess…
