Hi all,
I have a stand alone Atmega328p jig that lets me program smd atmega328pau chips before soldering them. I use the Atmel ICE to program
Lately, the jig started failing. When a chip is running a program, I cannot program it. What does that tell us? the ISP programmer cannot make the chip reset? Yet, the reset line is ok and the reset 10K pullup too.
avrdude: stk500v2_command(): command failed
avrdude: bad response to AVR sign-on command: 0xa0
avrdude: Target prepared for ISP, signed off.
avrdude: Now retrying without power-cycling the target.
avrdude: Failed to return from debugWIRE to ISP.
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
So I am confused, what else could be wrong? All my ISP lines are continuous and not shorted.
I know its a hardware issue with my jig because my setup works when I program atmega328pau's on manufactured PCBs
