Hardware PWM
Hi, turns out the Curie device has hardware PWM counters in addition to the Timer1 counter as revealed in "variant.h" and related files and the schematic pin name PWM0/SS10_3V_IO3. Each pin has two source/destinations defined as Mode A and Mode B in "scss_registers.h" and related files. For the PWM pins 3, 5, 6 and 9, Mode B connects to a set of hardware PWM counters while Mode A connects to the GPIO. Mode A is the default setting. Intel decided for some reason to not use these counters in any of the PWM library examples. I developed a library exposing these counters: CurieHwPWM. This approach is an improvement over the ISR software driven approach. I welcome feedback on the library features or coding.
Lee
