Hello friends.
Used Hardware:
ESP32 SIM800L
LiPo Battery
0815 temperature probe, wired to my ESP32
I have build myself an alarm-module for my serverfarms that i look after, to track the temperature. If the temperature exceeds an given value i will get an alarmmessage via email and SMS. Everything is quiet simple and is adjustable via a build-in webserver that i created on my ESP32. Everything works, lets say OK.
Problems that appeared: In the server-rooms isnt always a good WIFI-connection, it happens from time to time that my esp32 is not connected to the network, but its very important that the network-connection is stable.
I want to improve my little tool in that way that i replace my WIFI-connection with a solid ETHERNET port, to get rid of the instable WIFI-problem.
My question now: Can anyone recommend a microcontroller that has an ETHERNET-port, has an SIM-slot and can be programmed to create a webserver in an easy way like the esp32?. I know that there are some kind of shields etc. and i must confess that i am a bit lost with arduinos theoretical possibilities hardware-wise. So i reach my hand out for help
Has anyone an idea, recomandation or maybe knows a microcontroller that satisfies my needs? I am pretty sure that there are already complete, programmed tools out there, but want to build my own.
Thank you for the help
