I got a Arduino Leonardo board to be able to use a hardware serial while debugging with the pc. Uploading the program works fine and the led gets switched on/off.
The USB "Serial" works.. but the HW "Serial1" talks jiberish (see attached image). Switching baud doesn't help. Also tried all baud rates on the arduino for Serial1
Tried several serial->usb converters to connect to the pc (prolific and ftdi).
haha, I see it in the photo.. but the debugging was done before I changed the header to the other part
The jiberish does come at the expected rate used by the delay.
Yes, ground is also properly connected. Measured everything again, but can't find a wiring fault.
The board is being powered by a USBtinyISPv2.0, so both sides are connected to USB of the same pc.
Also with that the photo I took is a bit misleading, because the cable on the right just provides power. It does not show the cable connected on the left.. The board is connected with the mini USB connector for debugging and with the wires on the bottom for the second serial.
