Hardware SPI in Arduino framework not work on ESP32-P4
Hi, I tried to use a ST7789 SPI 320*240 lcd screen on ESP32-P4 with Arduino TFT_eSPI and Adafruit ST7735 and ST7789 Library, and found they both don't work on ESP32-P4.
After some testing, I found the software SPI mode in Adafruit T7789 Library works good on ESP32-P4 but with very slow speed,
and it also works good with ESP32-IDF framwork's esp_lcd component with hardware SPI.
It just doesn't work with the Arduino's hardware SPI on ESP32-P4.
The Arduino core that I used is lastest 3.2.0.
Finally I found that, the same simple code below lights up the ST7789 LCD with messy colors on ESP32-S3/ESP32-C3, but not work on ESP32-P4 with only a black backlighted screen.
// Works on ESP32 S3/C3 with hardware SPI
    pinMode(TFT_CS, OUTPUT);
    pinMode(TFT_DC, OUTPUT);
    pinMode(TFT_RST, OUTPUT);
    digitalWrite(TFT_CS, HIGH); // Chip select high (Inactive)
    digitalWrite(TFT_DC, HIGH); // Data/Command high = data mode
    digitalWrite(TFT_RST, HIGH);// NO Reset
    SPI.begin(TFT_SCLK, TFT_MISO, TFT_MOSI, -1);
    digitalWrite(TFT_CS, HIGH); // Chip select high (inactive)
    delay(200);
    digitalWrite(TFT_RST, LOW);
    delay(20);
    delay(200);
    // Sleep out
    GPIO.out_w1tc.val = (1 << TFT_CS);
    GPIO.out1_w1tc.val = (1 << (TFT_DC - 32));
    *_spi_mosi_dlen = 7;
    *_spi_w = ST7789_SLPOUT;
    *_spi_cmd = SPI_UPDATE;
    while(*_spi_cmd & SPI_UPDATE);
    *_spi_cmd = SPI_USR;
    while(*_spi_cmd & SPI_USR);
    GPIO.out1_w1ts.val = (1 << (TFT_DC - 32));
    GPIO.out_w1ts.val = (1 << TFT_CS);
    delay(120);
    // Display on
    *_spi_w = ST7789_DISPON;
    delay(120);
    pinMode(TFT_BL, OUTPUT);
    digitalWrite(TFT_BL, HIGH);
My pin Settings on ESP32-P4
It works good with esp_lcd component in IDF framework but not work with Arduino framework.
#define TFT_MOSI   29
#define TFT_SCLK   30
#define TFT_CS     28
#define TFT_DC     49
#define TFT_BL     23
#define TFT_RST    50
#define TFT_MISO   -1
#define ST7789_DRIVER
#define TFT_RGB_ORDER TFT_BGR
#define TFT_WIDTH  240
#define TFT_HEIGHT 320
Any suggestions will be appreciated. I just want to use TFT_eSPI library for all
my LCDs on ESP32 C3/S3/C6/P4 with the same code.
